Question about Dryers
How do I change the light bulbs inside the log cabin on top of the fan?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
Does this fan have bulbs built into the motor base?
Posted on Nov 25, 2014
How do I change the lamps in the log cabin on the top of the fan?
Since I don't know what fan you have all I can say is use a ladder.
Nov 17, 2014 | Dryers
Minks aire mojo ceiling fan light will not come on
Try changing the bulb. Make sure the bulb is touching the connector in the bulb socket.
Aug 15, 2014 | Minka Aire Ceiling Fan
Blower stuck high & cabin lights out
The blower motor resistor is most likely what needs to be replaced on your car, but there is the possibility that the fan speed switch may not be good but is usually not the problem, usually is the Blower Motor Resistor.
Check the Fuses for the interior light Bulbs, as it maybe blown, also the bulbs maybe burned out.
The air bag being on means you may have problem with the airbag(s) / Safety Restraint System ( SRS ) or could be a false code but do go to a service garage and have that checked out, you would not like the air bag to not deploy at all or deploy at the wrong time, because you never know when you'll need to work properly, when it matters the most, at that critical moment.
Jan 24, 2014 | 2007 Hyundai Entourage Limited Minivan
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson microwave oven with grill mwg9115sl
You need to remove the top cover and the light could be seen mounted on the side of the cabin. You can access this by removing the guard and the bulb can be replaced with the same type rating. If the bulb has not fused then check on the door switch and power from the board.
Jan 31, 2013 | Microwave Ovens
Need to know how to replace the rear window brake light bulb in a 2009 hyundai sonata. Thank-you.
Unplug the connector in the trunk.
Remove the 2 gold-colored screws from inside the trunk. They can be seen from the trunk. One of them is thru the larger square opening where the wire connects to the high-mount brake light. The second is on the right side thru a small (screwdriver width) hole covered by a piece of foam tape.
After removing the 2 screws, go inside the cabin and the brake light housing pops right up.
Disconnect the bulb from the housing while inside the cabin.
Back in the trunk, remove the wire and bulb. The wire from the connector to the bulb socket should be about 5 inches long.good-day !
Oct 25, 2011 | Hyundai Sonata 09 2009
Light bulb has gone, can't see where it is located or how to change the bulb
Do as follows. Do not connect the microwave oven to mains while doing the following activities. Even the accidental switching ON will harm you from the microwaves. Open the top cover by unscrewing side screws & the screws at the back. Lift the top cover by tilting upwards from rear end. Remove the wave guide of magnetron & there you will find the bulb. Wave guide is rectangular small ducting (pipe enclosure) to guide the microwaves from the magnetron.
Sep 17, 2011 | Microwave Ovens
How do i change the cabin air filter in my 2003 ford expidition
Locate the cabin air filter container on your Ford Expedition. If you are standing in front of the vehicle, looking at the engine, it will be on the back, left side of the engine, next to the heater fan. You will see a black cover over the top of the container. The air filter is approximately 6" x 9" and about 2" deep. Look for a black casing that will be about 10" across and 8" high. The box sits vertically against the firewall of the vehicle.
Step 2
Remove the cover of the cabin air filter by lightly prying on it with a screwdriver. The cover is secured with plastic tabs that pop off quite often. If this happens, you can buy replacements at your local automotive store.
Step 3
Remove the cabin air filter, and vacuum out the container to remove any dust or debris. Wipe it down with a clean damp cloth and let the inside of the container dry before inserting new filter.
Step 4
Place new cabin air filter in container and secure the cover, replacing tabs if needed. Remove tools from engine compartment and close hood.
Step 5
You are now able to enjoy driving with clean air flowing through the inside of your car.
May 25, 2010 | 2003 Ford Expedition
Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
May 17, 2009 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
42 people viewed this question
Top Dryers Experts
