Fisher and paykel gwl 11 fill problem,when cycle start its filling up ok but after minute or two starts filling very slow
  • 579 Answers
Check the valve where water inlet hoses attach to back of machine. If you have hard water mineral deposits tend to clog up this valve. You can remove and clean this valve or just replace. GOOD LUCK FRIEND.
Posted on Nov 17, 2014
SOURCE: Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Posted on Jan 11, 2008
  • 351 Answers
SOURCE: fisher & paykel slow to fill?
if its the cold water (most common) replace the valve remove the two screws on the top of the control panel then you will see the valve i think its the right one looking from the front.its an easy job .hope this helps.
Posted on Mar 20, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher paykel gwl10us wont fill
Both of you most likely are getting a "RPS Sensor Fault"
On a GWL10, when the motor rotor position sensor fails, it will act exactly like you describe. Many techs incorrectly replace the machine control or the water inlet valve(s). The RPS sensor is much cheaper. If you consult the tech sheet located under the control panel, you will see the fault code for RPS failure and I would bet the farm that the sequence of LEDs displayed when your washer faults out matches exactly with the RPS fault code.
The RPS sensor for GWL10 and GWL11 models is a part # 420296P and canbe purchased direct from Fisher Paykel Parts:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=5
The procedure to replace it is a little involved but a handy person can do it. It would be best to consult the factory service manual and again, that can be purchased from Fisher Paykel Parts direct here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=15
Posted on Dec 15, 2008
SOURCE: Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Posted on Jul 20, 2009
SOURCE: Washing Machine Wont Fill and cycles unresponsive, Help :/
My comment is generic to all washing machines in which there is a fill problem. Finally I remembered that when we did an upgrade on our basement I installed the type of fill hose that will prevent flooding. Sure enough, when I interchanged the hoses the problem switched from no hot to no cold. A flood prevention mechanism had malfunctioned on one hose and the reset feature did not work. A return to Home Depot will complete the solution to my problem - but I feel humbled to have overlooked the possibility that this simple malfunction had caused the grief.
Posted on Dec 07, 2009
My fisher&pakel gwl 11 wont drain/spin
Your motor controller board needs three 332k resistors replaced to make it spin again,Only on Series 11 Models
Jan 28, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel Washing Machine Model GWL 11
The power supply needs three resistors removed,R129,R130,R131.
and one 1megOhm put in it's place.
Feb 25, 2012 | Fisher and Paykel Washing Machines
GWL 11 takes forever to fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Suddenly the spin cycle won't work. The motor makes a funny noise. The drum just remaiins still. Model GWL 11. The lights are on and there is no alarm.
Hi just read your posting.Now, does the machine drain?What lights are on?Does the machine fill with water and agitate?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 I replace diverter valve which side is the drain NO or NC I ran the pump test everything ok there is no fauth codes wax motor test ok with 120 volts but it will not run in wash cycle
Hi just read your posting.Could you please supply additional information on your machine.In your posting you mentioned the machine does not wash.Does it fill with water?Does the machine drain the water when it is washing.Why did you replace the diverter.Was the original burnt out.In my experience when the diverter goes faulty it usually makes the control module go faulty as well.Please reply with additional information and I am sure I can help you.
Sep 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
My gwl 15 ecosmart
having the same problem myself i am replacing the soliniod when it get here. in the mean time the hot water runs in normally so i swapped the hoses over on the back and and now i can wash just that the hot is now the cold button
Dec 04, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
