Question about Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer
The machine stops working and flashes symbols
Washing machine works fine then without warning, stops working will not drain, agitate and flashes symbols and beeps sometimes it will work if it is restarted at the rinse cycle
    Habit-Forming:
  • 77 Answers
Level sensor stuck
Posted on Nov 17, 2014
  • 121 Answers
SOURCE: machine leaks at beginning of rinse cycle
have you checked the rubber seal round the door might be torn
Posted on Mar 03, 2008
appldoctom
  • 311 Answers
SOURCE: Hi... My washing machine... samsung
nf is the failure code for [no fill].check your water valve screens for a mineral buildup/blockage.they are where the fill hoses attach to your washer.make sure water is present at washer[run the water from each hose into a bucket].i live in ohio its 0 degrees out side now.i did't know it but there was an air leak near my dishwasher drain hose in the house and water froze in it blocking the drain.i hope this info helps you fix this washer, God bless ,tom
Posted on Jan 16, 2009
SOURCE: Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Posted on Mar 21, 2009
SOURCE: samsung silvercare washer stopped working, won't unlock
here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
Posted on May 26, 2009
  • 380 Answers
SOURCE: The cycle will not finish. It gives an reading of
LE is a water level issue. Make water is supplied correctly and turned on. Check the waters valves and the water level sensor.
Suds is just letting you know that the machine sensed to much suds. Reduce the detergent you are using and make sure it's HE detergent.
Posted on Dec 23, 2009
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
Feb 16, 2015 | KitchenAid Washing Machines
Washing machine wont drain
Does the washer spin when in spin cycle ? If it does spin and there is no water coming out of the drain then you most likely have a bad wa
Aug 07, 2012 | GE Washing Machines
Washing machine won't drain but it will spin.
sounds like a motor problem, the motor turns 1 way to agitate and the other way to drain and spin
Feb 16, 2010 | Kenmore Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washing machine won't spin or agitate
Hi.
Sounds to me that you have a faulty motor from the symptons.
Does it work without the belt on?
Nov 23, 2008 | Washing Machines
Washer will fill, drain, and run a complete cycle but will not agitate or spin
sounds like the motor control board is bad. you could test the motor to see if it ohms out ok, the diagram has the readings. The diagram should be on the side panel (inside the cabinet) on the lt side in a brown envelope.
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer Logo
258 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
