Where can I get a power supply cord for my electric railking model "G" scale set by New bright
  • 781 Answers
Visit any second hand or charity shop in your area they generally have all sorts of cord may have 1 to suit your product
Posted on Nov 17, 2014
What scale is this train set? I mean 1:24, 1:22.5, etc.
depends what the railway is representing. It matters, for example, whether you are in the US or Europe.
I recommend that you contact the company to get an unambiguous answer
Contact New Bright
Further reading on G-gauge can be found here
scale Wikipedia the free encyclopedia from which you will understand why it is not straight forward to answer your question with information available. In the US, the article says,
" 'Gauge One' scaled at 1:32 (3/8" to the foot) used to model standard gauge trains of 4 ft 8 1?2 in (1,435 mm) standard gauge gauge."
hope this helps (a bit)
May 22, 2016 | New Bright Bright Holiday Express Train...
When an I find a power supply cord for my electric railing model G by new bright
All desktop pc's have the same power cord. Try using one from your kettle if it is the plug in type. If not, try Ebay, Preloved or Gumtree. Power cords are ten a penny so you should be able to get one from virtually any online seller. Good luck!
Nov 16, 2014 | Computers & Internet
Am/fm tuner no power
Try changing the cable/transformer for a new one. you should be able to find a new cable online easily enough, or maybe a friend has one you could borrow.
Try a different power outlet.
Make sure your multi-plug (if you're using one) is functional.
Try plunging something that you know works, in the outlet, to see if you have power at that plug.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
It could be a fuse in the Tuner, replace the fuse for a new one.
Get your Multi-meter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 10, 2014 | Sony Audio Players & Recorders
Compresor on and off
Its normal for it to start and stop.
Check the mountings are tight
Some of this might help...
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
Note: Electricity can cause serious injury even Death.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 10, 2014 | Refrigerators
How to repair
A wire might have come loose inside the Vacuum head.
Remove/Dismantle the Vacuum head and locate the wires.
Check the wires at the terminals and at pinch points
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 08, 2014 | Hoover S3670 WindTunnel Bagged Canister...
U5445-900
This is a good start, try this link...
Product Manual Search
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Feb 02, 2014 | Hoover U6630-900 WindTunnel Bagless...
My hoover vacuum does not power up
Here s a link to the manual
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 15, 2014 | Hoover S3330 / S3332 Straight Suction...
How to replace power cable on hoover jc3157t
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jan 04, 2014 | Hoover Vacuums
Wiring
If not you could...
A set of leads.
3: Polarity
What to check:
What to check:
- Active and Earth
- Neutral and Earth
A set of leads.
Jun 11, 2013 | Yamaha RX-V757 Receiver
I need a new power supply cord for my Cafe Collection electric skillet Model SY-101K or LPH-5
try an appliance repair shop as most have replacement cords for most appliances
contact the manufacturer on line in their spare part section and order one
Jan 23, 2012 | Wolfgang Puck Kitchen Appliances - Others
Computers & Internet Logo
David Payne
David Payne
