Question about Garden
16hp vanguard pressure washer sputtering while running what need to be done for smoother running
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Sounds like the engine choke is "ON" or the air cleaner is dirty. Engine may be running "Rich".
Posted on Nov 24, 2014
3 Suggested Answers
psycodelek
  • 202 Answers
SOURCE: I have a 16hp pressure washer not putting out
On the bottom of the body is where the valves are. Sounds like its blocked so you can take the covers off them and clean and put them back
Posted on Jul 26, 2014
  • 21 Answers
SOURCE: I have a 16hp pressure washer Briggs how do I
There will be a an adjustment on the loafer valve on the pump itself. You may find it under a protective cap located on the pump.
Posted on Sep 06, 2014
Pressure washer stalls out when wand nozzle is released
Remove the hose and run the machine. If the machine works and the flow of water is ok. Start checking the hose for a restriction and trigger. Make sure this is correct before you start taking the pump to bits
Feb 23, 2016 | Simpson WS4050V Water Shotgun 4000 Psi...
I have a 16hp pressure washer not putting out presur
Jul 26, 2014 | Garden
I have a 16hp pressure washer Briggs how do I adjust the pressure?
They are set at the factory if its dropped in pressure it couldhave popped an O . Ring. Check out.
Jul 26, 2014 | Cam Spray 4000BT 16HP Briggs 4000psi 4GPM...
16hp horz vanguard, only starts with pull start,when running the lights won't work......
have a load test done on the battery as it appears to fail when the current draw is high as in starting taking the current needed to run the ignition syatem
Mar 16, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Will not start. but if I pour gas in carburetor it will. stop after the gas is burn of carburetor
Could be that the needle is stuck in carb, or else the fuel pump diaphragm is bad. Check the pump, thats what I would check first.
Jan 24, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton 16HP carb small hose purpose? Have a Snapper riding mower with 16HP Briggs & Stratton16 HP V-TWIN OHV Vanguard, Model 303777 Type 1145-A1 4750 Code 97021011. It started...
Should go to the valve spring access cover. Is the PCV line and keeps engine from building up pressure internally.
To clean the carb you will have to remove it from the engine and give it a through cleaning with small diameter wires run through the ports and blowing out the gunk with low pressure air or WD40's little red tube. From your description, you need to do this as the ports are clogged and not letting proper amounts of fuel through to the engine.
good luck.
Sep 16, 2012 | Tools & Hardware - Others
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
No fire canged magnito & checked magnet
could be a low oil safety switch on the briggs & stratton gone bad. Try disconnecting it and fire it up.
Apr 26, 2009 | Briggs & Stratton Pressure Washer...
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
