Question about Irulu 7" Touch Screen 2gb Android 2.3 Tablet Pc 256m Imapx 210 Wifi3g Bundles Case
Hi when i turned my tablet on it got to the android screen and would not do anything so i try to reset it but it shows the little android guy on his back with and ! coming out of his belly what should
Hi when i turned my tablet on it got to the android screen and would not do anything so i try to reset it but it shows the little android guy on his back with and ! coming out of his belly what should i do now?
Where is the reset button on a zeki windows tablet located at
Hi Brenda, The link below is a youtube video showing you how to fix your tablet, Also there's video's down the right side you can check out as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
Apr 24, 2016 | Tablets & eReaders
USED WRONG CHARGER ON RCA TABLET AND NOW SCREEN MALFUNCTIONING.HOW DO I FIX?
Try a factory reset of your tablet first. Here is a link to the procedure:
http://www.rcatablets.com/how-completely-reset-your-rca-android-42-tablet
Apr 29, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
My tablet will not respond to touch nor will it turn off to reboot. What should I do ?
Greeting Annette
Sorry to hear this so lets see what we can do. First what kind of tablet do you have? Does it show anything on the screen like an app or the android guy ? Can you try holding down the power and volume buttons to see if it will go into restore mode? If this doesnt work try connecting the power apter for few minutes then see if it will then let you power it off. Some tablets have a reset button in back that with a paperclip can reset it back to life.
If these dont apply post type and make for us to assist you further.
Good luck
Chadman
Feb 24, 2015 | Tablets & eReaders
How do i get it off the android screen so it will show the lock screen?
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up.
May 12, 2014 | Shopnbc Zeki 10.1" LCD Android 4.1 8GB...
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
Tablet is stuck on the screen that says android
You may have to reset the tablet to factory settings. This may be the only way. It will wipe all the data on it.
To factory reset:
1. Press and hold power plus volume up until an android menu appear 2. Use the volume keys to navigate and option key or power to select. 3. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
Feb 04, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My tablet wont turn on it continues to blink but wont turn on
Try using a paperclip to reset it on the back, hold it in for 5 seconds, if that doesnt work:
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 20, 2013 | Coby kyros Tablets & eReaders
Kurio kids tablet is froze
Kurio won't come off blank screen, i've used the reset button, and the power with volume+ button and it's still the little kurio guy making the smiley face. i took the cover off, it's not hot. Any other suggestions as to re-boot it?
Nov 12, 2012 | Techno Source Kurio Kids Tablet With...
My ematic eglide steal 7 is stuck on the android screen can i do something
I HAVE AN IRULU 10.1" TABLET AND THE SCREEN SHOW CALIBRATE AFTER TAP BUT DON'T DO ANYTHING ELSE WHAT I SHOULD DO
Aug 31, 2012 | Ematic eGlide Steal 7" Android Tablet with...
Irulu 7" Touch Screen 2gb Android 2.3 Tablet Pc 256m Imapx 210 Wifi3g Bundles Case Logo
240 people viewed this question
Top Irulu Tablets & eReaders Experts
David Clark
David Clark
john smith
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
