When I plug in the Motorola 55316 001 00 it for some reason scrambles my HD channels. Any ideas?
4 Suggested Answers
arquetteg
  • 37 Answers
SOURCE: HD Picture is Scrambled, but Has Sound
A Sure fire way to fix this is to see if your cable box has a HDMI output and your TV has a HDMI input. If they both do , get a HDMI cable to solve your resolution issues. A plus for this also is better signal quality than component cables. Also, the HDMI carries audio so no need for the RCA cables.
If your cable box does not have a HDMI- go to Comcast and trade it for on e that does. Should be free.
Posted on May 27, 2009
kklare
  • 85 Answers
SOURCE: I HAVE A SUMSUNG THAT IS HD, BUT IT'S NOT HDMI,i
I assume you have cable. The cable HD and digital channels are usually sent in Quadrature Amplitude Modulation (QAM). The cable companies are required to send local channels in the clear but not so for any others. Regular (basic) channels may be clear or scrambled. USA many not be but HBO will be.
So you have 1 of 2 problems: (1) your TV does not do QAM or (2) they have scrambled the channels you want to see. Questions: (1) Have tried direct Over-the-Air (OTA, ATSC) reception for your locals? (2) Can you see the HD local channels on cable? (3) Are you paying for an HD box from the cable company to have the channels decoded? If in doubt contact the cable company.
Current Samsung TVs do do QAM and OTA HD. Alternatives are Dish or Direct to get satellite with an HD receiver using HDMI or 5-cable RCA. Costs are comparable but OTA wins, hands down. -Ken
Posted on Aug 18, 2009
urbanhookupz
  • 213 Answers
SOURCE: HD channel picture is clear, but regular digital picture scramble
o.k. check all your connections
if you have a newer house check to see if you have a main hub in a closet somewhere and check all connections. Check your hd receiver and you may be able to chage the DPI the receiver receives in.
I have this problem on some of my non HD channels, also. So much for going digital. I get fuzz and pixel problems "from time to time", but, if it is really bad and consistent your should call your service provider.
Things to ask also ? are you using cable or satellite.
If satellite T.V. there are other reasons you could be experiencing problems.
hope this helps!
Posted on Mar 26, 2010
Two sets of Motorola Walki Talki radios will not communicate.
In addition to the channel and privacy codes, some Motorola two-way radios have a feature called Eavesdrop Reducer where you have 3 scramble settings available; perhaps you have this set on one of sets of radios but not the other. It should be something like that because otherwise there is no reason that by setting the radios to the same channel and privacy code they wouldn't be able to send/receive to each other.
Nov 24, 2013 | Motorola Walkie Talkie 2-Way Radio
I have a Motorola E815 phone. The screen looks scrambled.
take out the sim card and format or restore to fabrik settings
May 16, 2010 | Motorola Mobility E815
I have a motorola xts 2500 800 mghz. Im gettin a circle with a line through it symbol on the dispay on 1 talkgroup only and getting a "key fail" when I push to talk. Any ideas?
The circle with a line through it emblem indicates your radio is scrambling the channel chosen. Your key fail message likely indicates your radio has a programming problem or other problem requiring dealer assistance.
Best regards.
May 14, 2010 | Motorola Walkie Talkie 2-Way Radio
hope this helps!
Mar 26, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
I HAVE A SUMSUNG THAT IS HD, BUT IT'S NOT HDMI,i GET REGULAR CHANNELS, BUT WHEN I SWITH TO A HD CHANNEL, IT IS ALL SCRAMBLED? WHY?
Aug 18, 2009 | Samsung Televison & Video
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
Mitsubishi WS-55809 Upconvert Stopped working
your problem is the 2hdw board is located in the signal board.
Feb 02, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
