Question about Home
My alarm monitoring service tells me they are getting multiple sensor error readings from my smoke detectors. This occurs at the same time each morning. I have checked the voltage at the alarm panel
My alarm monitoring service tells me they are getting multiple sensor error readings from my smoke detectors. This occurs at the same time each morning. I have checked the voltage at the alarm panel where they are wired and it reads 3.7 volts. I checked the voltage at the last detector in the line with the 2k resistor and it measured the same voltage at 3.7 volts. Is this the cause of faulty sensors? They are and are 4years old and are GE model 511c. Any help would be greatly appreciated.
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 93 Answers
Before I can really try to answer, I would like to know what make/model control panel you have (ex: Honeywell Vista20P), the zone number of the affected smokes, and whether or not you get an indication of a problem on your keypad.
Posted on Nov 19, 2014
  • 2920 Answers
SOURCE: multiple misfire
it could be in the timing...you might have it checked
Posted on Jan 29, 2009
  • 158 Answers
SOURCE: Car Idles Hot Temp
I don't know how the above could have any effect on temperature. Is the vehicle full of coolant? In my opinion you have two different issues
Posted on Apr 03, 2009
localwonder
  • 6784 Answers
SOURCE: KNOCK SENSOR KEEP GOING OUT
Make sure you are not over torquing it. if you screw it in to much, it will give false readings and if it is not screwed in enough, it will also give false readings.
There's a delicate balance to be known and, if this sensor is over torqued or, not torqued enough, it will malfunction.
Posted on May 24, 2009
SOURCE: 1994 Chevy Astrovan. v6 . Running very rich, black smoke.
If this van uses flow meter? If does, replace it.
Posted on Jul 09, 2009
  • 37 Answers
SOURCE: no power, lots of smoke code p1247 neddle lift sensor
JUST A SUGGESTION 4 ELIMINATION ON THESE MODELS THE AIRFLOW METER CAN B APROBLEM A SIMPLE TEST WILL ELLIMINATE THIS DISCONNECT AIRFLOWSENSOR DRIVE UP ROAD IF CAR DRIVES BETTER THEN REPLACE AIRFLOW METER GOOD LUCK
Posted on Oct 09, 2009
My detector start to beep once a while, seem to react to the fat the electric plate is starting.
It's possible that your smoke alarm is mounted too close to the kitchen, which can cause false alarms. Most household smoke alarms are the ionization type, which respond to the presence of gases in the air which are caused by combustion, as opposed to visible smoke, but kitchens are better protected using heat sensors to prevent false alarms. Many companies now make heat sensors that can tie into the existing smoke alarm system...check with the manufacturer, an electrician, or your local hardware store.
Jan 12, 2016 | Home
The sensor Honeywell TC807A 1036 (Smoke Detector), is compatible with a NFS-320 Fire Alarm Control Panel?
I don't know if that particular smoke is compatible or not, but the NFS-320 is a commercial rated UL864 Revision 9 fire panel, which means the documentation is part of the UL listing. This means that in order for a device to be compatible with the system, it must be listed in the Installation Instructions as compatible. I couldn't find any mention of that particular smoke in any of the documentation I found for that alarm panel.
Oct 23, 2012 | Honeywell Tc807a1036 Smoke Fire Detector...
I have a kidde i12020 ac wire in smoke alarm and i can't get it to stop beeping
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (Its not worth to buy just a sensor). Take a look on amazon Amazon com smoke alarm detector (watch out on reviews). I hope this was helpful. cheers
Jan 04, 2012 | Kidde Kiddie Ac Wire-in Smoke Alarm I12020
Two first alert smoke detectors go off for no reason. All are on 110 with good batteries. Have had these for approx. 12 years with no problems until now when 2 of the 7 have gone off many times in the last...
There may be dust built up in the sensing chamber. This can cause alarms to go off for no reason. Try vacuuming the alarm off particularly around the sensor if the cover is removable. These alarms should be replaced however, as they are more than 10 years old.
Apr 07, 2011 | First Alert Brk / First Alert Smoke...
Are there any reported problems with the Firez 21007624 carbon monoxide detector false alarms?
I do not know of any reported problems specific to the Kidde CO/smoke alarm, but I spent a significant part of my career servicing toxic gas sensors and can give you some general advice:
1- Most important: treat an alarm as a REAL alarm and DO NOT suspect that your alarm is a "false alarm". My experience has been that most "false alarms" ARE REAL and the source needs to be identified! With Carbon Monoxide detectors, it is usually a blocked vent for a gas fired appliance- a hot water heater, furnace, or oven. Call your fire department or a service professional to make sure that there is no carbon monoxide. They have portable detectors that will be able to double check your alarm.
My advice to you at this moment is to act as if you have a real alarm condition and do not place you or others in a life threatening situation. Ventilate the room/ apartment/house IMMEDIATELY!
I will post more after I send this because you may be in a life threatening situation!
Mar 22, 2011 | Kidde Firex 21007624 Ac Carbon Monoxide...
Goes off only at night with NO warning cleaned & changed batt. 4 times so far !!!!
These types of smoke detectors are PHOTOELECTRIC, the way it works, there is a IR transmitter and a IR receiver placed in a dark chamber aligned at a 45degree angle, when smoke enters the chamber IR light bounces of the smoke and than generating an alarm, so in conclusion if there is a lot of DUST in the chamber it reflects the IR light just like smoke, than can generate an alarm, try blowing air in the smoke detector (gentely) if it does not work replace the smoke detector...
Feb 04, 2011 | System Sensor 2100rfadt Wireless Smoke...
I could not get to battery compartment of the first alert smoke alarm. Please tell me how to replace with new battery.
Hold the entire smoke detector,turn it to the left or right,u will able to take the smoke detector out.The battery compartment is in the back.
Sep 09, 2010 | First Alert SA302 Dual System Smoke...
Our carbon monoxide dectector model CO910, bought several years ago (10+) beeps every 30 seconds with an "err" message. All windows where it is are open. No one is feeling ill. Is it just an error on...
CO2 and Smoke detectors have an internal sensor that has a design life of 5 years from the date of manufacture. After the 5 years you start getting false alarms due to the sensor itself exceeding its average life span. On the combination CO2 and Smoke deterctors you will often see a manufacture date or a replace by date inside the cover on the main board.
On AC powered models such as this one you will just get the error when the sensor fails. If you got the full 5+ years out of your CO2 sensor then you should be happy that it served a full life expectancy.
Some Wiki data on CO2 detectors:
http://en.wikipedia.org/wiki/Carbon_monoxide_detector
This paragragh appears under installation
The gas sensors in CO alarms have a limited and indeterminable life span, typically two to five years. The test button on a CO alarm only tests the battery and circuitry not the sensor. CO alarms should be tested with an external source of calibrated test gas, as recommended by the latest version of NFPA 720. Alarms over five years old should be replaced but they should be checked on installation and at least annually during the manufacturers warranty period.
Thanks for choosing FixYa.
Kelly
Aug 02, 2010 | Vacuums
Home security alarm keeps beeping
Most wired-in smoke detectors work off of two sources of power, electric and battery. If the beeping occurs every 30 seconds or so it most likely means you need to replace the battery in the detector. On the other hand if by beeping you mean the alarm is going off, I would first try cleaning the unit with your vacuum. If that doesn't solve the problem then the next step would be to replace the unit. Hope this helps.
Apr 08, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Sep 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
Home Logo
81 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
