Question about Hardware & Accessories
I cannot get #1 receiver to work with the transmitter. #2 and #3 work. I took a set back and exchanged it for this reason and not the new set is acting the same way. What am I doing wrong with the #1
Item 26316
  • 5,245 Answers
I put new batteries in Transmitter and never got any temp reading.The unit is less than 2 years old and is not working. Is there anything I can do?
  • Remove all batteries
  • Install new batteries in transmitter
  • Wait for transmitter to initialize and begin transmitting temperature data
  • Install known-good batteries in receiver
  • Observe outdoor temperature reading
If this doesn't work, the transmitter or receiver or both may be defective. I find in very cold weather the transmitter stops sending the temperature.
Dec 08, 2016 | Measuring Tools & Sensors
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
I can't receive my mail.
What type of server that your e-mail account works with?
If you are using POP3 or IMAP account, please configure Incoming mail server.
You should try the given below solution to resolve the occurred issue:
Sol 1:
Open "Microsoft Outlook" >> Click on "File" tab >> "Account Settings" >> "Account Settings", locate your account and click on change.... then click on "More Settings" to configure Incoming mail server.
If you are using Microsoft Exchange account, check if you use cached exchange mode. If not, enable it. Click on "File" tab >> "Account Settings" >> "Account Settings" locate your exchange account and click on "change...."
Under server settings, check Use cached exchange mode.
You can check another setting to help resolve being able to send but not receive e-mail messages.
You can set up Microsoft Outlook to check for new e-mail messages at intervals of one minute to 1,440 minutes (one day).
On the "Send/Receive" menu, point to "Send/Receive Groups", and then click on "Define Send/Receive Groups".
Select the group that contains the e-mail account that you want to regularly check for messages.
Under Setting for group "group name", select the Schedule an automatic send/receive every x minutes check box.
Enter a number from 1 to 1440 in the minute's box.
Click on "Close" button. On the Send/Receive menu, click Send/Receive All folders.
Sol 2:
Open "Microsoft Outlook" >> Click on "File" tab >> "Account Settings" >> "Account Settings" >> Click on "Change Folder" button >> Change from whatever it was to: Outlook Data File - Inbox
Close the dialog, click on send/receive or press F9 button and see if it works.
Thanks & Regards
Captain Ashish
Nov 06, 2015 | Microsoft Outlook 2010
My remote is beeping on my gas fireplace model Vff-PH32DR
Check the batteries. in the receiver and remote.
Jan 23, 2014 | Pleasant Hearth Home
We just got a new Weather Channel wireless temperature sensor 9245. It seems that the transmitter isn't working. We followed the directions and put new batteries in the transmitter first, then the...
The new batteries could be defective or installed incorrectly. Remove all batteries and start over again. Be sure to let the transmitter initialize and begin sending data before you install the batteries in the receiver. If you can't receive a signal, the transmitter may have failed.
I have an Oregon Scientific receiver that is within line of sight of the transmitter and receives nothing......
May 17, 2017 | La Crosse Technology WS9245UBKITCBP...
We installed a 27185 remote kit in a hunter fan, and factory settings. The fan light goes on and off by itself. I changed the dip switches( matched them to the remote to the controller), and the fan and...
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
Jul 09, 2010 | Hunter 27185 Remote Control
SHIFT-3-WIRELESS-INDOOR-OUTDOOR-SPEAKER
it comes with a transmitter. so put batteries in the transmitter and plug the included (white) audio plug in the back of the transmitter, (the hole that says direct input), turn transmitter on. Plug free end of audio cord into headphones jack on ur computer. put batteries in the speaker or plug it in to wall and push power button. push reset button on front of speaker and it should work. start playing music
Apr 09, 2009 | Audio Players & Recorders
Using the device from the cable outlet
Not a stupid question. You should have received all the cables you need with the Leap Frog. To hook up your tv, take your transmitter and one set of a/v cables, usually red, white and yellow. Do one cable at a time. Your tv outputs should be color coded. You should have one set of three jacks completly open on the back or side of your tv, i.e. labeled component 1, component 2, aux 1, etc. First plug select one set of jacks. Plug a yellow plug into the yellow jack on your tv labeled video out. Plug the white plug into the white jack labeled audio L out. Plug the red plug into the red jack labeled audio R out. Now do the same on the transmitter but the jacks should say in. Yellow, white and red to video, audio L and audio R. Now take your receiver into the other room and do the same thing with the other tv. The cables go from the receiver out jacks to one set of jacks labeled Aux, component, etc like before. Pick a set that has all three open. Red to red, white to white, yellow to yellow. Make sure you then have the transmitter and receiver plugged in. Your remote is supposed to work from your other room. If this solved your problem please rate this as fixed. If you need more help with this just add a comment and I'll be glad to help you. Thanks.
Apr 13, 2008 | Terk LeapFrog LF30S
D60 not firing Paul Buff flashes by cord or wireless set up...
Here is the main support number.You can call them up and find a closest repair center in your location.
1 800 828-4040
If you are in USA you can find a service center from HERE
Goodluck..
Feb 29, 2008 | Canon PowerShot EOS D60 Digital Camera
Hardware & Accessories Logo
74 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
