Question about Dryers
My dryer does not blow hot and will not shut off and no digital reading will display.
  • Dryers Master
  • 744 Answers
Hello Bryan;
My name is Peter. I am a retired field service appliance technician.
So, here are the probable causes:
1.) The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may be plugged up or not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft. Check the blower hot air discharge manifold for blockage.
2a.) If the dryer won't stop, the gas valve solenoid coils might be defective. Over time these coils will fail, causing the burner to run intermittently. If the dryer is not heating properly it may not stop. Replace the coils as a set.
2.b) The heating element warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element isn't working - which greatly increases the drying time. Check the heating element for continuity.
3.) Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
4.) Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or shorted
5.) If the dryer won't stop, check the high limit thermostat. If defective, the high limit thermostat can turn off the heat prematurely, lengthening the time it takes to dry a full load. This is not common.
6.) The cycling thermostat regulates the temperature of the air in the dryer. If the dryer won't stop, it may be caused by a defective cycling thermostat turning off the heat too early. This is not common.
7.) The thermistor senses the temperature of the air in the dryer and cycles the heat on and off. If the dryer won't stop, the thermistor may be defective. This is not common.
Posted on Nov 17, 2014
The LCD display screen is cloudy on one side so difficult to read part of display. Is there a way we can remove it and clean the glass?
I don't have your model number to look up but I'll try to answer. Most digital displays have 2 parts to the display cover. The actual display and sometimes a clear or green plastic cover to help protect the actual display. That type system can usually be removed and cleaned. Some of the newer systems have eliminated the extra cover, so if moisture is getting behind the display you can't clean it. If it is actually moisture, applying heat from a hair dryer may help get rid of some of it but be careful you don't get it too hot and melt the display.
May 13, 2015 | Electrolux WaveTouch Perfect Steam 8.0 cu....
I recently had a water leak in the crawl space of my house. It is being dried out with several fans,and a dragon, blowing hot air under the hose. This will continue to go on for another week. Now I&#
Very likely.
Here's why.
Because of the real danger of overheating and fire, dryers are "loaded" with overheat switches which will shut thr dryer off if they get hot.
One reason is that lint catches fire so easily.
Here's hoping you problem will resolve soon!
Be blessed
Jan 27, 2013 | Kenmore Dryers
Crockpot digital display
I think that you might have ruden it by being in water, Try a blow dryer to help dry it out, other than that you might need a new one.
Dec 29, 2012 | Crock Pots & Slow Cookers
Display reads E11
E11 error code means that the dryer thermostat is faulty.
Apparently it overheats if you use it too much or the motor of the fan (blowing hot air in the tumble) got stuck.
Check it and keep us updated.
Apr 18, 2011 | Hoover Washing Machines
Dryer got hot and shut down. Cleaned out the vent and now it won't do anything. I check the power and breakers and all it good there. Is there a reset on located inside the dryer somewhere?
no u blew out ur thermal fuse on the backside if its a wirlpool built .... its white part number 3392519 u can see a pi of it at repairclinic.com...... this blows due to overheating its a safety thing it blows and is caused by the vent is either kinked, blocked or ur venting is clogged or vents a long distance.....you must take of the back of the dryer and can check that fuse with a meter for continuity, unplug the unit first though. if it reads sometin is good if nothin dead,, check the thermostats back there as well if its not the fuse... hope this helps
Jan 30, 2010 | Dryers
Just bought a new HE5 dryer three days ago and used it for the first time---the sides of the HE5 dryer are extremely hot (could burn hand), is that normal and what could be the cause?
check the vent line,could be clogged with lint if you never cleaned it,you should clean out your dryer every year by taking off and cleaning out the duct that the lint filter slides into,vac out the inside of dryer and clean out the vent line,if it's a long run from the wall to the outside vent hood blow it out with a leaf blower,go outside and make sure the air is blowing out with force,all a dryer does is move air and if something is blocking the air flow the dryer will get hot,you'll start blowing thermostats or the thermal fuse because they are safety switches so if the dryer does run to hot they pop and shut down the dryer so hopefully you don't have a fire or damage the dryer
Jan 10, 2010 | Kenmore HE5 Electric Dryer
Dryer gets really hot, blows circuit breaker, vent is clean and clear, circuit breaker replaced, seems to be something that controls the heat isnt working..
Howdy: In back of the dryer is a thermostat (inside) that lint hangs to. If it reads too hot it should stop heating. If not working then blows breaker. Inspect please, we do not want a electric fire. Good luck - Doug
Dec 09, 2009 | Kenmore Dryers
Dryer doesn't get hot
unplug dryer,take bottom panel off and take out the lint filter,remove the blower wheel duct and clean out the lint,while you have the cover off read out the thermal fuse located on top of the blower wheel housing,remove one of the wires when you read it out, if the air isn't moving outside it will pop the fuse.vac out the inside of dryer and if you have a shop vac switch it on blow and blow off all the lint off of the motor,you should do this once a year so you don't have a fire.if the fuse is good,read out the ignitor,sensor and gas coils.when you get it running go outside and make sure the air is blowing out strong,if it isn't you could have a blocked vent line,if it's a long run use a leaf blower to blow out the vent line.
Nov 28, 2009 | Kenmore Dryers
My fridge is not working, the freezer still does, though. Front panel displaying ''Er and FF''
sounds like the return air duct is completely blocked with ice
shut unit off for a couple of hours leave a blow dryer blowing hot in the freezer with the doors open
Oct 09, 2009 | Refrigerators
Dryer will not start, has power on display
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 21, 2009 | Dryers
Dryers Logo
Top Dryers Experts
