Question about Olevia 332V LCD TV
On olevia tv, channel scan will not pick up channels 3 to 13
When I scan for channels ,olevia tv will not locate channels 3 to 13 .uhf is detected
  • 77 Answers
I think the low band on your tuner has failed
Posted on Nov 17, 2014
SOURCE: I cannot get my Olevia 226 T11 to do an auto
Check the Power Up setting to be sure it is starting up in HOME mode rather than SHOWROOM mode. In showroom mode, many settings cannot be changed.
Posted on Feb 15, 2010
freetek
  • 5568 Answers
SOURCE: Channel Scan
If you have not discarded your old conventional TV or can borrow one, I would connect it to the same signal source you are using with the Olevia. If you get reception with the substitute set, then the Olevia is defective. If you live in a metropolitan area, you could also try sticking a piece of copper wire into the input of the Olevia and selecting antenna input as the source from inside the Olevia's setup menu. If you still get no signal indications (quality is not important for this), then the Olevia is defective.
I'm disappointed to see you having trouble with this set as we own one too. Also disturbing is Olevia's current state; they are in bankruptcy so I would start complaining soon and loudly if you have satisfactorily   identified the Olevia as the problem.
Posted on Nov 28, 2008
  • 34 Answers
SOURCE: My Olevia TV will not change channels using the remote or buttons
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
Posted on Apr 09, 2009
  • 20 Answers
SOURCE: where do i get olevia 537h firmware
funny things like channels changing of there own accord ,volume going up and down and other strange goings on are usualy down to the batteries in the remote no longer being of full strenght hope this helps
Posted on Jun 13, 2009
  • 9 Answers
SOURCE: After I reset my Olevia 542-B11 with
unplug televison for about 1 minute.
Go into menu picture>mode> powerup> and switch to home mode
Posted on Sep 05, 2009
I cannot set up my tv, after it had cable. when i try the setup program the tv will not accept any channels and sap appears on the screen. i want go back to uhf/vhf, can somebody help me.
If you are in the US, there is no logical reason to go back to UHF/VHF as there are no broadcasting stations using the analog frequencies anymore. Those old tuners will not decode anything that is coming over the airwaves. Thus their channel scans will not detect ant channels, making you think there is something wrong. You would need one of the digital converter boxes sold during the transition period and then you will only get your local channels, much as you would have before.
Oct 03, 2016 | Televison & Video
I have a Olevia 532-H that I am unable to scan under the channel set up.
A Converter hdtv box... is the SOOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Apr 22, 2010 | Syntax Olevia 532H 32 in. LCD HDTV
VHF channels come in however UHF channels are not
uhf and vhf tuning is performed in one board(tuner brd) there are some on line part stores that can help you with the number and price, you'll need to provide the model number. partstore.com is one of them, but there are more.good luck.
Jan 09, 2010 | Vizio GV46L 46 in. LCD Television
The tuner's not working and won't let add channels.
no channels? blue screen? no signal?
Solution:
A Converter hdtv box... is the SOLUTION!!! try it..youll see!!!
Olevia tv fixed!!!
Oct 19, 2009 | Syntax Olevia 527-S11 Television
OLEVIA LCD TV: can't get setup to auto scan air channels
worked for me thanks. Don't know how it go in the showroom mode?
Oct 16, 2009 | Televison & Video
Olevia 237V S11 Firmware
for all firmware updates you must go to this site http://www.olevia.com/en-us/Support/Firmware.aspx
and follow the directions...............(note you must have a blank usb flash drive)
Jun 20, 2009 | Syntax Olevia 537H Television
Olevia is not picking up my cable channels. Anyone know how to do a channel search or scan on this TV
pick up the remote turn on tv....press menu...setup....tv....then channel scan....(note your tv should also be on cable broadcast not air)...hope this is helpful
No tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Jun 19, 2009 | Syntax Olevia 226T 26 in. LCD Television
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
Olevia 332V LCD TV Logo
172 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
