Question about Garden
The tractor will move forward but has difficulty engaging reverse
Stepping on the reverse pedal repeatedly might engage reverse but usually doesn't. what is the problem? is it a linkage issue?
Have you fited it yet, my little tractor snaped a chain link in side transmission, I just open it up and put new clip on, looks the same as a bike chain master link. Also check for bent lever from peddle
Posted on Nov 16, 2014
2 Suggested Answers
mickey813
  • 472 Answers
SOURCE: After stopping, tractor does not engage in forward or reverse
sounds like the by pass rod has been pulled out
Posted on May 08, 2010
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
Audi a3 auto reverse gear doesn't move
run fault codes and look for faulty TCM and reverse servo .
Nov 29, 2013 | Audi Cars & Trucks
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Transmission will not engage.
The transmission belt is probably loose or the clutch is faulty.
Apr 29, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Mower dies when directional pedal ( F/R) or engageing blades
check the safety switches start with the one on the pedal
May 16, 2012 | Garden
JD 855 the idle spring broke and th hydrostatic pedals would not return to their neturel position . before I new what had happene I pushed the reverse and the tractor lunged backward then I pushed the...
Yes there is a safety switch.And this safety switch has to be engaged.If its not engaged then the JD tractor will not start. On JD 855 the safty switch is located under the seat, There is a rod that must be depressed before engage Somehow that rod is bent or its not pressing the switch to the point that the seat would not fully engage the safty switch.In some cases the switch itself is faulty.It has to be checked . Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jul 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
