Question about Saeco Talea Touch 14-Cup Coffee Maker
<!-- from fixya rte -->What to do when prime water curcuit comes on - Saeco Talea Touch 14-Cup Coffee Maker
  • 55 Answers
When prime water circuit comes on turn on the steam/water valve may need to select hot water the machine will run water until primed
Posted on Dec 30, 2014
How to prime a jsp100 onga pump
Check if there is a plug that can be removed to pour in water, if not the outlet pipe may have to be removed to prime with water, hope the non return valve in the tank has not picked up any rubbish . if it can't be primed that could be the case.
Dec 03, 2017 | Plumbing
What does it mean to "prime" m kuerig?
A solution for priming problems for many Kuerig coffee makes.
I have read many different priming solutions, but this one that I developed seemes to be the most "permanent fix", for me. I believe that the problem is a desighn flaw and I am a little disapointed with the company for not "stepping up to the plate" and permanently resolving the issue on thier own since it seems to be a comon problem that you can read about on the internet from years gone by..
The solution? Try this, First when you fill your reser
voir, leave the cover off or set it on top of the tank so that it is not sealed compleatly with the covers lip, let the tank breath. Second , if this works for you and your priming issues are not occuring, then just drill a small, ( 1/8th inch or so) hole on the rear right inside pottion of the cap (just so that it is not visible, cosmetics), Be sure that it is above the lip part that fits into the tank, so that when the cover is properly inserted, the hole can still have an open access to the outside air.
I believe that as the water is drawn out of the tank, the tank is so sealed that air cannot enter the tank fast enough thus causing a slight vacuum inside the tank, The air is then pulled down the "breather" at the back of the tank during the pumping operation. When the pump shuts off enough air remains in the pump to prevent it from drawing in more water.
This solution may not solve everones priming problems, sometimes a cleaning with this fix may be required, all I know is that the above totaly solved my issues. I hope this solution resolves your issues too. Reguards.
Steve1907
Sep 26, 2011 | Keurig Platinum B70 Coffee Maker
Initially when the unit said need to prime, no water would flow out of the steam unit. After pulling the pump out and cleaning it, not sure what was blocking water the steam unit now has water pressure,...
I fixed the same issue by pushing in the water knob "in" towards the machine. Machine than primes normally as the water flow is restored and it resets itself.
Dec 13, 2010 | Starbucks Saeco Italia Digital Barista...
Toro Z Master Cooling fan will not turn on.
i would check water temp sender in engine block or thermostat housing.take wire off with key switch in on position touch wire to clean ground tis completes ground curcuit to relay fan should come on if so test sender with test lite or ohm meter. should be open curcuit or no lite when cold and go complete or lite when comes up to temp. clamp test lite to sender and probe to positive. hope this helps
Jul 17, 2010 | Toro 60" Cut Zero Turn Rider Diesel...
How do i prime the water circuit? nothing is working.
take it the water curcuit apart an see if any thing is alose and make sure evrythanq is tite
Jan 17, 2010 | Saeco VIA Venezia
Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Noy working
Well, ok, I found that I just needed more water to prime it.  Apparently, a self-prime pump needs to be primed pretty well to use the first time.
May 23, 2009 | Dynamo Garden
I have a Saeco Incanto RS Espresso Machine. The prime light is on, but the machine won't prime. Very little water of steam comes out of the wand.
You need to manually prime it using the priming bulb that came with it. Instructions are in the manual. Remove water tank. Fill priming bulb. Hold priming bulb on water inlet. They don't inter-connect, so just hold it on there as best you can. Turn the machine on, turn steam knob on, and gently, slowly squeeze the bulb to force water into the machine. It works best when the machine is cold, because you want to get liquid water in there, and not have it displaced by steam.
Jun 30, 2008 | Saeco Incanto Classic Espresso Machine
WR480 ERROR CODE H20
h20 fault code means you have a water supply problem.
check you have suficiant water pressure coming into your appliance,and also check that you have no blockages at the sump of the apliance and if plunbed to the sink check for blockages there.
f08 code means that the heater relay is stuck or open curcuit,check connections on your module and check your heater is not open curcuit,if these are ok you will require a module.
May 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
No instruction on how to prime a saeco caffe charisma machine. looked in the book that came with it but there is no instructions for this process
Prime = letting some water out from the water/steam nozzle. Priming means that the machine has not water in the lines. By letting water come out, you are making sure that water fills all the components and is ready to use.
Apr 28, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Talea Touch 14-Cup Coffee Maker Logo
573 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
