Question about Haier XQG50-11 Front Load Washer / Dryer
I get an error message 13. the clothes are not drying properly I resently
  • Haier Master
  • 5,380 Answers
Posted on Nov 16, 2014
Error Code B1275 13
Fix the water leak first. Got a sun roof? Water in the BCM will cause all sorts of funny things, to included not letting you car start and run. Fix that leak first( Like today or tomorrow), then find your BCM(body control module) , pull it out and remove the cover around it. Wipe it off with a cloth, use a blow dryer and dry it up use the dryer to dry out the plugs also, then wipe it off again with another cloth. You let moisture set in it too long, it could kill it...
Apr 16, 2014 | 2010 Honda Accord
Message resent! Please verify your account by carefully following the instructions in the email. Message Code: CA3
hello Zynga poker as you see error ca:3 and its say change my fb pass an if i change pass its not working all you know its now work see massage
Mar 22, 2013 | Zynga Texas HoldEm Poker
Joy stick malfunction, error messages
hi, it could be that there is a small amount of water still in there, Please remove the unit and place where you dry your cloths etc? somewhere warm but not hot, warm and dry only, now leave for 24 hours. Also check the cable connections making sure they are clean and fit well.
RegardsGeWiz.
Feb 12, 2013 | Invacare Mk6 Mpj Ts1136885 Joystick...
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Pictures will not go to my memory card on my pandigital kodak p811 personal photo scanner. I have tried a different card and it still does not work
pilipino ba 2 , try mo linisin nang dry cloth or dry paper ung area whre you plug in the memory card make sure its clean because it might be the area whre the memory card is plugged .is not working .Is there any error message .Make sure the card is properly plug in .
May 22, 2011 | Office Equipment & Supplies
I have a Sony-shot DSC- P200, which is showing a message "Memory Stick error' and code C:13:01. I have two memory sticks which both work in my computer, but not in my camera. I have cleaned the...
This may sound lik an odd solution, but first try this, first:
Make sure the card is inserted properly, use the camera's Format Utility; instead of the computer (Always Use The Camera, with Sony).
Using a pencil eraser (new/clean) gently rub the contacts with the eraser, and use a dry and lint free cloth to wipe any shavings of (don't blow it off with your mouth)..
If the error still presents, try inserting and removing as many as 10 times or more (the contacts, both inside the camera and on the card may have a film on them) to both align and clean the contacts against one another.
I said it sounds odd but here's where Sonystyle.com  says it too:
DCS-P200 error code 13:xx  (all 13 code errors are memory stick related)....
Don't Forget To Vote ;-)
Thank You For Choosing FixYa~!
Mar 18, 2011 | Cameras
My brother MFC-410CN has an error message "Unable to Clean"
Suggestion.
MFC-410CN unplugged from the surge protector. Open the printer case. It opens in the middle. This is how you get to the ink cartridges.
I suggest at this point, to don a pair of dishwashing rubber gloves.
Remove the ink cartridges. Take a clean, lint free cloth, and soak one end in real warm water. Almost where you can't touch it. Wring the cloth out until it's just damp. No drips will form. Take the damp portion of the cloth, and wipe the area of the cartridges that ink comes from.
This should be where you see a thin copper strip.
After you wipe across once, use a different area of the damp cloth that is clean, and wipe again.
What you are trying to do, is to clean the tiny, tiny, little holes of this ink cartridge, where the ink comes out. What has transpired, is that ink has dried in these tiny holes, and ink cannot come out now.
I also advise doing the same to the area where these holes line up in the printer 'body'. Ink may have dried there also, and cannot pass through.
Once you are finished wiping with damp cloth, and no more dried ink is present, and you are satisfied that it isn't, then use a dry, lint free cloth, and wipe these areas.
Let the ink cartridges set out, until you are satisfied that they are dry. Those copper strips of metal must not contain any moisture.
Same thing for the printer itself. Leave it open to dry out. Probably about an hour. Using a hairdryer set on low heat, and constantly moving it back and forth, while keeping it at a distance of about a finger length, will speed up the process. (For the printer. This is not advised for the ink cartridges)
When you are satisfied that all is dry, reinsert the ink cartridges. Make sure they are properly seated. Close the printer case. Plug the printer back into power. Wait one minute, or until the printer goes through it's setup. (If it does one. Some printers do, some printers don't)
Now press the Power On button for the printer. Let it align itself.
Go to the Brother self diagnostic program for the printer, and use it.
Let it print out a test piece of paper after aligning.
Apr 15, 2009 | Brother MFC-410CN All-In-One InkJet...
Dryer will not stay running through entire cycle or it will just stop before clothers are dry and sometimes get a E1 error message. Mostly it will just stop and clothes are not dry, times that is runs...
Most customer manuels have a code listing in the back? Have you checked to see what E1 is? It sounds like its not sensing properly. the sensor works off the vent...so the most common problem is the vent or venting. Please check and advise
Jan 02, 2008 | Kenmore Elite HE4 Electric Dryer
X5470
Cartridge left for long time ink gets dried thrn you get this message...try this
Cleaning procedure
Turn the cartridges up side down u will find the print nozzles
Remove the print cartridges.
Moisten a clean, lint-free cloth with water.
Gently hold the cloth against the nozzles for about three seconds, and then wipe .
Using another clean section of the cloth, gently hold the cloth against the contacts for about three seconds, and then wipe
With another clean section of the cloth, repeat steps 2 through 4 above.
Allow the nozzles and contacts to dry completely.
Reinsert the print cartridges.
Print the document again.
If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times.
Dec 24, 2007 | Lexmark X5470 All-In-One InkJet Printer
Open Questions:
See all Haier XQG50-11 Front Load Washer / Dryer Questions
Haier XQG50-11 Front Load Washer / Dryer Logo
247 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
