I need to find a user manual or know location of furnace filter on my mobile home furnace. There is no filter in the unit currently and I need to get one put in ASAP.
    Problem Solver:
  • 14 Answers
There is a good chance it is supposed to be in the door to the furnace and held in with thin metal rods like coat hangers. the air pulls through the door. you but the cut to fit style filter element. good luck
Posted on Nov 20, 2014
  • 2920 Answers
SOURCE: mobile home furnace
you probably have a bad thermostat if it wont shut down id replace the thermostat first and then have the thermocoupler checked...replace the thermostat
Posted on Aug 20, 2008
  • 659 Answers
SOURCE: how do I find the filter on a lennox G8Q3904 furnace?
If you don't have a filter "rack" installed then you have to remove the blower housing door. Usually the filter is there if it is not located in the house where the return air supply is. Some units have a filter in what is called a return air filter grill. If there isn't a filter already installed in the unit then you will have to measure the inside dimensions and then use one that is similar in size. It's not imperative that you use the exact same size. You just want to cover the opening of the unit. If you don't have central air conditioning, then it's not necessary to use a filter.
Posted on Mar 30, 2009
  • 10 Answers
SOURCE: Where are the furnace filters in my older furnace?
On these of Furnaces the filters mount on the door. Remove the door you will notice grill on front. There should be a track on the back of the front door to slide filters down. Should take 2 filters.
Posted on Dec 06, 2009
Testimonial: "drifterray really helped. way to go apprentices!"
  • 415 Answers
SOURCE: Where are the filters located on the Intertherm
There are a couple of places to start looking.......the first place is in the return grille. If it is not in the return grille, then the filter should be in the Intertherm unit itself.......look for an access panel marked "filter".
Posted on May 18, 2010
  • 6 Answers
SOURCE: Where can I find a manual for my coleman cam II
Check the website for Coleman/Intertherm for a manual, you will need the model and serial numbers of the unit. The filters for these typically sit on top of the unit, some come with frames, some lay directly on the coil. If you can't find a manual on the website or by contacting the company, check the yellow pages some towns have a mobile home supply house that would be able to help.
Posted on Aug 30, 2010
How do I replace filter panels on Coleman mobile home gas furnace after I have changed filters on them? They won't go back in easily
one post only,please delete copied posts,http://www.mobilehomerepair.com/mobile-home-furnace-maintenance-troubleshooting/
Oct 07, 2016 | Coleman Heating & Cooling
I need to know if the Ruuduaka-042jaz 3.5 is good for a mobile home
The outside unit will work,but not the matching furnace!
you have to have a specific manufactured home furnace, because off Co
Nov 15, 2015 | Ruud UAKA042 Air Conditioner
I have a mobile home furnace and I have no manual. I think it needs a filter but I can't tell where it is supposed to go or what kind of filter I should use. Is there a diagram available I could look at?...
The filter is usually located in the door or front cover. If you have trouble finding material you can measure opening and get one or more 1 inch thick high effiency filter. You can set these filters on their sides or upright,it really does't matter as long as you have direction of air flow going the right way. Arrows pointing into blower compartment. I have taken two or more filters and duct taped them together to get the right size. Not pretty, but it works.Hope this helps. Thanks
Nov 14, 2010 | Intertherm Heating & Cooling
Where can I find a manual for my coleman cam II central air conditioner for a mobile home? I recently purchased the mobile home and would like to know what steps to ntake to make it work at its best. ...
Aug 30, 2010 | Coleman Heating & Cooling
I have a intertherm furnace and need to know how to tell the proper filter size this is a mobile home
The best thing to do is buy a washable horsehair filter from home depot and cut it to fit. They are green in color and you cut any size you want. They slide in the door of a gas furnace or along each side of the A coil in an electric furnace. That is your best bet. Most of the time the furnaces comes witha washable filter and it is thrown away after afeew times. Rus
Dec 06, 2009 | Refrigerators
Open the door to the airhandling unit inside the closet by lifting upward on them. There should be two filters located on top of the A coil.
Dec 05, 2009 | Heating & Cooling
Where are filters installed
check panel at rear of unit by return duct open panel look for slide tracks for filters around fan usually one above fan and one on an angle in front of fan
Oct 06, 2009 | Intertherm Heating & Cooling
I also need a wiring schematic for a Coleman 3500A816 furnace
What are you wiring? Possibly we can help.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 24, 2017 | Coleman Heating & Cooling
I have an old 1985-86 coleman central heat and air need manual
The filter is located before the blower if your Coleman is in a mobile home it will be in the door facing. If it is a standard ac/heat application and a regular residential furnace the blower in the cabinet on down flow (ducts in floor) will be above it and possible in the duct connecting in the top. If its the other way (ducts in ceiling) it could be right under the blower. Either of these could have a filter cabinet on the furnace or could have a filter grille at the end of the return air duct (where the air is sucked in).
Mar 10, 2009 | Coleman Heating & Cooling
Short cycling
There are a few reasons why your furnace is restarting after it reaches temp. and shuts off. First, if you have a mercury bulb thermostat it needs to be level and the heat anticipator needs set properly. If you have an electronic thermostat then you need to make sure the DIP switch settings inside are set properly for propane. If you have a digital thermostat there are also settings to be made for your type of heating. These settings will be explained in the thermostat installation instructions. Also, Make sure your furnace filter is clean. If this does not help then there are some other things to check which may need to be done by a technician depending on your mechanical aptitude. Hope this helps!
Dec 08, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
