Question about Coffee Makers & Espresso Machines
I need charcoal filter for GE model16929
I need charcoal water filter. Bought them at Wal-Mart once but havn't been able to find them for the past 6 mos.
freetek
  • 5568 Answers
SOURCE: GE coffee maker model # 169164 making too much steam, not coffee
If you look at the bottom, you'll probably find 'China' on it.
The problem you are having normally doesn't show up for a couple of months after the lime has had a chance to roughen the ball in the check valve that makes up the pump. Your pump isn't pumping.
I suspect you have some particulate matter that has made its way to the primitive check valve and the ball is not moving freely as it should. The copious amount of steam you are getting is from the bit of water that makes it to the heating element before the (yet to fail) thermal switch that cycles the heater element.
If you have a clean turkey baster, you may be able to flush whatever crud there is in the water path through to the outlet over the coffee basket by sticking the tip into the water chamber's exit hole. We have a large veterinarian's hypodermic that does the job nicely when it is time to flush it again and soaking the water path with vinegar every few weeks overnight will help keep it pumping properly too.
If the flushing doesn't work, take it back before GE gets completely out of the appliance business.
(Whatever happened to Silex??)
Posted on Sep 28, 2008
freetek
  • 5568 Answers
If it failed after working a short while, the thermal fuse used in all drip coffee makers is frequently failing and we have had exactly the same experience with another brand. Our toxic Chinese friends are making crappy thermal fuses along with about everything else.
Replacing these is impractical since they are in a small metal case, pointed on one end with two coaxial leads permanently attached. Further, they are welded  to wiring under the warming plate to the heating element. The area is too hot for solder and ceramic wire nuts have to be used to replace the fuse and these are tough to find anymore.
Bypassing them is a really bad idea since I know of one case where the thermal switch that causes the machine to cycle, failed, the heating element melted through the aluminum plate on the bottom and set fire to a kitchen counter.
With the cost of labor being what it is, hardly any of these drip coffee makers are worth repairing.
SOURCE: GE 4 cup coffeemaker Replacement Pots
The pot that came with my GE 169184 dripped when I poured so I replaced it with an old pot from an old Mr Coffee 4 cup unit. It works perfect and it does not drip. Also, the pour-n-serve feature works as it should. The glass envelopes have a slightly different shape but the height, base diameter and capacity are identical.
Posted on Nov 01, 2008
SOURCE: new charcoal filter for GE COFFEEE-MAKER MODEL NUMBER 169164
Call your local Wal Mart Stores..... even if you have to call 2 or 3 stores..... after several attempts to call the customer support phone number (what a joke) I did not want to waste my time on hold.
I decided to call all of the local Wal Mart Stores in my ares.and I found the filters for the 12 cup digital coffee maker model number 169164.......... (they come in a pack of 2) at the Wal Mart store in West York PA.....
I may end up purchasing 2 packs.........
I hope this email with help you with your search.............Good luck. They are out there, it just takes alittle searching and with no thanks to our wonderful GE help line.
Barb
Posted on Feb 07, 2009
  • 33 Answers
SOURCE: I want a new GE 4-cup cofee maker model no. 169184
try this link
It's the same model you gave me
http://www.walmart.com/catalog/product.do?product_id=9447213
eric
Posted on Feb 16, 2009
Dealer claims cause of malfunctioning indicator light is a $400.00 charcoal filter if this is the case where on the vehicle would I find the filter.Any help would be appreciated.
This would be your cabin air filter (charcoal is not required, you can go to Wal-Mart and purchase a FRAM equivelant and it will not void your warranty [as per law]). Most CAFs are located either behind the glove compartment (you may have to remove the compartment), or on the passenger side of the firewall or on the vent panel above, under the hood.
Aug 19, 2011 | 2005 Toyota ECHO
I need a bowl and lid for Model #168956 GE Food Processor purchased at Wal Mart. Where can I find one?
I found this phone number for repair parts on the GE housewares website:
"In 2000, GE housewares products became available through Wal-Mart. For repair or parts, you may call 877-207-0923 (for US) 877-556-0973 (for Canada) or you may return your product to your local Wal-Mart."
http://www.gehousewares.com/Contact_Us.aspx
They also have downloadable manuals there.
Hope this helps
Jan 29, 2011 | GE Food Processor
How much charcoal should be used? How do you regulate the temperature?
the temperature is regulated by airflow and you can use as much or little charcoal as desired. They do make a charcoal starter chimney you can purchase at wal-mart. You just fill it and start the coals.
Aug 10, 2010 | Weber One-Touch Gold 18.5 Grill
Where can I get a new pwer cord for my GE cool touch deep fryer model 106789
call GE customer sva for replacement parts (877) 207-0923
Mar 29, 2010 | GE 106789 Deep Fryer
Where can I get a fiter for my GE Combination Bagless Vac model 106687
Greetings,
Your GE is actually made by Eureka for Wal-Mart. Wal-Mart owns the GE brand for vacuum cleaners, and they have different manufacturers (most always Eureka) make vacuum cleaners specifically for Wal-Mart, but in actuality it's really a Eureka vacuum cleaner in terms of the parts (most of the time, in this case for sure).
Your GE model 106687 uses Eureka Dust Cup Filter Part Number 61518. Here's a link to Amazon for the filter;
http://www.amazon.com/Eureka-Model-106687-Filter-61518/dp/B001DPLYAG/ref=sr_1_1?ie=UTF8&m=A13YM4FUDXTJG6&s=generic&qid=1269298852&sr=1-1
The parts Diagram for your vacuum cleaner can be found here;
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/GE106687.pdf
This will give you all of the Eureka part numbers for your GE Stick Vac. I hope that this was helpful to you. If you found this helpful, please be sure to rate the answer as helpful by clicking the 4 thumbs up icons in the top right hand corner.
If you need any other parts, please feel free to contact us.
Thank you very much,
Chris Jones
GoVacuum
Mar 22, 2010 | GE Combination 106687 Upright Vacuum
HP 5610v All in One Copy Fax. Several numbers on the keypad ( Fax) don't work. When you're trying to fax, the numbers 2, 4 and 9 don't work. The HP is only 6 months old, bought at Walmart. Called HP...
Chances are pretty good that it is indeed a hardware problem. I'm not sure how Wal-Mart handles their warranty services, seeing as it's only 6 months old you should still have the 1-year manufacturer's warranty for the unit. I would either give Wal-Mart a call, or even bring it directly to them and see how they want to handle the warranty service on it.
May 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Control knob
You can either try the GE web site or replacements.com. If those two fail, try eBay.
Please remember to rate my solutions! Thanks
Aug 25, 2008 | GE 106851 6-Quart
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
