Question about Seaward Princess Model 2276, 2 burner drop-in gas cooktop blk glass Seaward
Our clicker does't work on our left burner but the gas comes on. Does it need replaced or filed?
Ge cooktop
Usually, any burner makes the same system "click". I'd try to light the one that does work, leave it clicking then turn on the one that doesn't click. This should be just a tempory fix. The switch that turns on the "click" is bad, possibly dirty or the wire to the clicker is bad.
Mar 29, 2015 | GE Cooktops
I am not sure of the model number but the gas cooktop was purchased in 1998. The 2 burners on the left side all of a sudden are not ingiting. There is no gas and the igniters are not sparking. the other...
Hello Sharon,
are the two left hand burners "simmer burners" that low come on and go off to simmer a pot?
and the right side just set on and turn off without the simmer option?
if yes this pretty much describes your cooktop the part called the potentiometer is going the be the problem.
Aug 26, 2011 | Thermador SGS36GS Gas Cooktop
SGCS304RS The two left burners work. The two right burners, spark but no gas comes out.
The regulators are clogged and so there is no gas flow due to this. use a good brush to clean the burner tops so as to get the mixture of gas /air correct. Use pressurized air to clean the valve, clean the JETS and reset.
Jun 14, 2011 | Thermador 31 in. SGSX304Z Gas Cooktop
We have a whirlpool gas cooktop, Model SC8720EDB, Serial FMG1005626. When the left two side burners are lit, either one or both, the suction fan automatically cuts on. When the right side burners are...
It does this by design. It is a safety feature on this model because it was designed to have a gill module on the left side. I don't know if you can change it without replacing the two left control valves with valves like it has on the right burners.
Nov 24, 2010 | Whirlpool 30 in. SC8720 Gas Cooktop
Whirlpool gas cooktop will only spark on left front burner
i made this video to help you troubleshoot kitchenaid and whirlpool cooktops
Apr 01, 2010 | Whirlpool GLT3615 Gas Cooktop
We have a Jenn-air JGC8430ADS. The rear left
WE have a Jenn-Air JGC8430BDW gas cooktop. How do i replace a broken ignitor?
Feb 13, 2010 | Jenn-Air Cooktops
I cleaned the gas top and the two left side burners do not ignite
Take the burners out, then take a needle and stick in the small hole where the gas comes thru.
Jul 15, 2009 | Maytag MGC5430BDS Gas Cooktop
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Nov 29, 2007 | Cooktops
Seaward Princess Model 2276, 2 burner drop-in gas cooktop blk glass Seaward Logo
79 people viewed this question
Top Seaward Cooktops Experts
Paul Carew
Are you a Seaward Cooktop Expert? Answer questions, earn points and help others
