Question about Honeywell T827K1009 Mercury Free EconoStat Non-Programmable Thermostat, Heat On
Replace a honeywell t822l1000 with a programmable unit
I want to replace this with a programmable honeywell thermostat that mounts on the wall box
    Master:
  • 602 Answers
Match the thermostat wires to the letters on the new thermostat terminals R Red Y yellow ETC.
Posted on Nov 17, 2014
5 Suggested Answers
pendletonhea
  • 144 Answers
SOURCE: looking for an owners manual
you can get that online at honeywell,local hvac supply houses, and by calling the 800 # that should be online and in your stat please rate my comment and give me a vote I just started this
Posted on Sep 15, 2010
  • 25 Answers
SOURCE: Hi, I have a Honeywell Thermostat
if you thermostat doesnt use batteries and it has no power, that means there is a problem with the air conditioing system itself. 90% of the time it is a safety switch such as a float switch (drainage problem), which cuts the power to the system to prevent damage to your house from condensate water leakage or just further damage to the system itself. Call the a/c guys, this is going to require expertise.
Posted on Oct 09, 2009
koolbreezes
  • 540 Answers
SOURCE: I'm replacing my wall thermostat.
Its got 3.... Find the r==red--or power..OK.
Posted on Sep 08, 2008
BarrettDenCo
  • 1772 Answers
SOURCE: The wall mounted thermostat in a condominium unit
i think you may have a fan/control board problem, if the thermostat turns on the fan, and you dont touch it, then the fan stops in a short time...
plus the fan is connected to a control board, like i said those thermostats hardly go bad...
Posted on Dec 19, 2010
Replacing a Honeywell T822l1000 thermostat.
The W terminal is used for heating and goes to a small electric valve in the water line to your baseboard. The Y terminal is for a cooling system. The T822 is wired wrong and is not working. The wiring between R and W is corect for a heating only application. The R terminal is the power source.
Nov 10, 2013 | Heating & Cooling
How do I remove a Honeywell DT92E Thermostat from the wall mount ?
turn off power to thermostat. should be a small flat head screw located on the bottom of the unit. release screw and lift face from the bottom, out and up. you will then need to identify wiring before removal of back plate unless the wiring is redundant.
Nov 07, 2011 | Honeywell Programmable Thermostat Heater
My honeywell t8400c also went blank. I can not find a battery anywhere and if plugs into the wall to get electricity. Everything works but the digital read out. Any suggestions
it should take a battery and it has wires coming from the unit for power as well the stat splits open from the wall leaving some of it mounted on the wall the batteries are in the part that pulls off the wall and the wires are on the part that stays on the wall the power wire is red on r terminal
Sep 23, 2010 | Honeywell Electronic Programmable...
Yes im putting in a honeywell cool 2665 thermostat that my brother give me with no guide. I have R,Y G, and W wires comming in the wall. the unit has a jumper on Y and W on the left bank and a jumper from...
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 16, 2010 | Honeywell Programmable Thermostat Heater
I have an old honeywell thermostat which does operate correctly apart from the fact that the heating will never cut out for more than 1-2 minuters even when the rooms are at their correct temperature. it...
If this is an old on/off thermostat it's probably bad. If it is a programmable thermostat, it may have a jumper to set the on/off delay to 2 min or 5 min. Also, if the thermostat is mounted on an outside wall this can happen.
Feb 12, 2010 | Honeywell Programmable Thermostat Heater
How do I " snap off" the cover of my Honeywell Thermostat to see if I need to replace the battery? The digital numbers don't show anymore and I am getting cold! I don't want to force the cover off and...
There is a seam around the edge of the Thermostat , a small screwdriver or butter knife should do the trick , if not then its mounted to a plate on the wall that has 4 corners basically...Gently squeeze the bottom and pull the bottom out , they are pretty sturdy and you shouldn't have a problem,...the wall plate may flex a little while doing this
Oct 26, 2009 | Honeywell Electronic Programmable...
Rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Dec 28, 2008 | Honeywell Electronic Programmable...
Replacing Honeywell heating progrmmer
yep the wires will hook up to the same designations, just write down what color was connected where. You will need to set the thermostat up for your particular situation...gas, electric, heat pump, ect. The installation maunel is very clear on this aspect so you should not have a problem.
Oct 30, 2008 | Honeywell Programmable Thermostat Heater
Honeywell st7000
what type of system do you have? cool/gas heat, heat pump, electric cool & heat. split system or package unit?
Mar 14, 2008 | Honeywell Programmable Thermostat Heater
Honeywell T827K1009 Mercury Free EconoStat Non-Programmable Thermostat, Heat On Logo
162 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
