Question about Casio aw-80-1aves
Is Casio AW80-7AV Wrist Watch water resistant?
Can it be used in the swimming pool and see?
SOURCE: my light keeps coming on when i move my wrist, wearing down the battery
press and hold the light button and it will turn off the auto back light.
Posted on Jan 03, 2008
  • 4 Answers
SOURCE: how to adjust metal wrist band on casio watch?
  1. Pop out one spring pin to disconnect the band from the watch or from itself at the clasp. If you don't have a special tool for this, a needle or a pin will probably work. A straightened paper clip may be too thick, but they are cheap so you could try it. Now the watch and band can sit flat on the work table.
  2. Examine the links. If some of them have little arrows on them (usually the ones closest to both sides of the clasp), they are removable.
  3. These removable links are held together by a "U" shaped (actually a squared off "U" - sort of like this |_| ) pin that is inserted into the link. There may should be some kind of window-like opening in the link into which you can insert a narrow screwdriver or similar tool or even a small nail (around 6-penny size) and push out the |_| shaped pin. A straightened paper clip is probably not sturdy enough, but you could try it. Push in the direction of the arrow (from tail to point). The links that were joined by the |_| pin can now be separated.
  4. Remove a second such pin from another adjacent link. Now a single link is free and can be discarded (or kept). Reconnect the remaining adjustable links with one of the |_| pins and re-attach the spring pin from step 1 so the band is reunited with itself or with the watch.
  5. Try it on. If it is still too long, repeat the process. Good luck.
Posted on Mar 24, 2009
escapement
  • 2334 Answers
SOURCE: user manual
Try this link:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Posted on Mar 29, 2009
escapement
  • 2334 Answers
SOURCE: i cant set analogue time on casio hd wrist
Follow this link:
Rate, please.
Posted on Mar 31, 2009
  • 2501 Answers
SOURCE: My Casio G-shock says water 20BAR resist
1 bar = 10 meters (approximately).
So a 20 Bar watch is resistant to 200meters.
Posted on Apr 17, 2010
Testimonial: "very good"
Can I swim laps w/ my ebel 30 meter watch? The watch has 4 screws on the back and the crown does not screw down.
Thank you for contacting FixYa.
Water Resistant is a common mark stamped on the back of wrist watches to indicate how well a watch is sealed against ingress of water. It is usually accompanied by an indication of the static test pressure that a sample of newly manufactured watches was exposed to in a leakage test. The test pressure can be indicated either directly in bars, or (more commonly) as an equivalent water depth in meters (in the United States sometimes also in feet).
An indication of the test pressure in terms of water depth does not mean a water resistant watch was designed for repeated long term use in such water depths. For example, a water resistant watch marked at 30 meters depth cannot be expected to withstand activity for longer time periods in a swimming pool, let alone continue to function at 30 meters under water. This is because the test is conducted only once using static pressure on some of the newly manufactured watches. The test for qualifying a diving watch for repeated usage in a given depth includes safety margins to take factors in account like aging of the seals, rapidly changing water pressure and temperature, as well as dynamic mechanical stresses encountered by a watch. Also every diving watch has to be fully tested for water resistance.
Hope this helps.
Jewel
Sep 02, 2010 | Ebel Classic Wave 9090F249725 Wrist Watch
How water resistent is watch??? Anyone with experience?? How about after battery replacement?
mcdevito 75 here, Usually 50--100 meters of water resistance on brand new watches. However after a battery change, unless you also change the gasket (rubber ring) on the cover, you could loose all water resistance capability.
May 28, 2010 | Casio AWS90D-2AV Wrist Watch
Looking for user guide for model 4511 Desert Falcon Zodiac watch
Clearly a screwdown crown is better for water resistance but most watches maintain a seal without it. I wouldn't test out the 100m claim but it should be safe in the pool.
Apr 29, 2010 | Watches
F-117 Nighthawk 6402 series, moisture has entered watch face after swimming in pool on holiday.
This watch is resistant to 200m so shouldn't allow water in at swimming pool depths.
It looks as though one of the seals has failed.
If it still under warranty (less than 2 years old), then contact your nearest authorized dealer
To find your nearest dealer or their service center, go to Luminox.com. At the top of th epage you will see a list of links.
Feb 23, 2010 | Luminox Evo F 117 Nighthawk 6402 Watch
I bought a Timex H/R/M and on my first swim workout, it kept slipping out of place. This happened everytime I pushed off the wall to swim freestyle. Any suggestions?
Timex watches are not designed for swimming, snorkel or diving unless it is stated on the watch itself. All the info about water resistance is mend to be when the watch is in still/motionless position submersed in water. If you are looking for the watch to withstand your swimming activities - you have to by any watch with the marking 50 or100 meters at least.
rate me, plz
Jan 09, 2010 | Timex 5G971 Heart Rate Monitor Ring Watch
Can you tell me what 50M water resistant really means in a Tissot watch that uses a crown to set the time? PRS 516 Quartz, Chronograph. So can I swim with it?... (never mind the leather strap) Will it...
hi its a bit of a grey area as some cheap watches boast 50m water resistant but as its a tissot you should be fine but id rather you went to tissots website to make sure, just as long as you dont go diving it should be fine, good luck
Aug 21, 2009 | Tissot PRS 516 T91.1.486.51 Wrist Watch
Guess Steel Water resistant is not water resistant!!!
Water resistant does not mean water proof. You should never wear this watch while bathing, swimming or in sauna.
Any watchmaker will be able to remove any condensation and dry out your watch - no matter you are in the U.S.A. or Romania.
Find your nearest watch repair shop and ask for help.
Rate, please.
Jul 20, 2009 | Guess G66355L Wrist Watch
My Polar F6 is not water resistant like it's supposed to be??????
Your watch is water resistant...not water proof...which means if you get a little water on it, fine..but certainly not wearing it in the pool!
Jun 28, 2009 | Polar F6 Wrist Watch
Can i dive with this watch?
You definetely CAN NOT dive with this watch. It is good for swimming and snorkeling only. Real divers watches withstand at least 200 meters of depths and are specialy designed for it.
One of the best affordable divers watch manufacturers novadays is Seiko. Check Seiko website and learn about divers watches and all the features they have. List of waterproof markings and explanations are also available.
Do not forget to rate, please.
Feb 12, 2009 | Casio W752V3AV men's watch
Casio aw-80-1aves Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
