Question about Vehicle Parts & Accessories
Is there another PVC valve in the back of the motor?
My vehicle is waisting lots of gas and the spark plugs were changed to the AC Delco but now we are trying to replace the second PVC valve and can not find it which I think might go in the back of the motor.
    Sergeant:
  • 243 Answers
OK, first of all, you havent told me or anyone what kind of vehicle it is, so I will give you the same advice i give most of the people i help, get a haynes or chiltons manuel at the auto parts store. it will give you the info you seek as well as many useful helps, as far as parts, check Rockauto.com.
Posted on Nov 18, 2014
What spark plugs are cross refrence for a champion plug RN4C
Oct 12, 2014 | Champion International Champion& Small...
Craftsman won start
Need a lot more info. Did you add oil? Did you hit anything. Take the plug out and check the spark by holding the base of the plug to the frame (metal) pulling the cord and see if the is spark. Is there a gas shutoff valve? Need the model of mower too.
Sep 01, 2014 | Garden
Ngk cross reference chart
The cross reference to the ac deco spark plug 41-993 to a ngk plug is PTR4G15.
Jul 27, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
What spark plugs for a 2000 jimmy v6
Part Number: 4188-05005375 AC-delco sprarkplugs
should be able to find at:
autozone or where ever they carry ac-delco products
Oct 03, 2012 | 2000 GMC Jimmy
Just had a new fuel pump, fuel filter, spark plugs and coil pack put in, was getting 27miles to the gal, now I am getting 15!!!
possible problem is that you did not put ac delco plugs in the vehicle and now you are getting bad gas mileage.gmc vehicles only require that you put ac delco spark plugs any other type and you get bad gas mileage or poor performance
Feb 12, 2011 | 2003 Oldsmobile Alero
What number and type of acdelco spark plug fits a 2000 s10 pickup with 4.3 motor ,4x4
2000 Chevrolet Truck S10 P/U 4WD 4.3L SFI 6cylSPARK PLUG ASM
Part Number: 12
Product Notes:
[Rapidfire Spark Plug]; .060 GAP
Per Vehicle: 6; Years: 1996-2001
SPARK PLUG ASM
Part Number: 41-993
Product Notes:
[Platinum Spark Plug]; .060 GAP
Per Vehicle: 6; Years: 1996-2002
From acdelco-catalog
Hope helps (remember to rate this answer).
Jan 04, 2011 | Chevrolet S 10 Cars & Trucks
I have a 98 S-10 with a 4.3 v6 motor. I have change the cap, rotor, wires and spark plugs about every 3 months. The motor keeps fouling and carbon building up on the 3 driver side plugs. Do you have any...
Nitrogen purging the poppet valves. This is very common on these vehicles. Also, remove a piece inside the rotor if you used a dealer part. There is a screen inside for marine use, problem is it get gunked up and traps moisture, just remove this screen, its not necessary. If you find the rotor gets greenish, this is probably your problem here. High tension wires now days last over 80-100kms, no need to replace these and use AC delco spark plugs. It does make a difference which plugs you use.
Nov 29, 2010 | 1998 Chevrolet S-10 Pickup
Dumps raw gas into engine
Just a few things to check. Take off the fuel filter and make sure there is no water in it. If you have put in different spark plugs than AC Delco, then change them to AC Delco. If you haven't looked at the plugs or the fuel filter, then it is way past time to replace the filter and new AC Delco spark plugs only. These places that insist that you use Bosch plugs or split fire plugs don't know ****. The Delco plugs are made especially for your engine and will out last those cheap non-working Bosch plugs.
If the fuel filter and plugs don't fix it, make sure your air filter intake isn't stopped up with a bird's nest. Happens a lot. If it still misses after new plugs, you may have a fuel injector sticking.
The bad smoke is the gas-thinned oil passing the rings and unburnt fuel smoke. The missing really bad is most likely fuel soaked spark plugs. Make sure you change the oil while changing the plugs or you will have a redo. Let us know if any of this helps. Dale
Dec 19, 2008 | 1998 Chevrolet S-10 Pickup
Changed spark plugs and wires. car is running very rough now.
check to see if the wires are in right order and if the plugs and wires are the correct ones for vehicle
Jul 18, 2008 | Buick LeSabre Cars & Trucks
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
