Question about Refrigerators
Where can I purchase a replacement drawer for a Bush fridge freezer?
I have broken the very bottom drawer of the above make appliance.
    Problem Solver:
  • 14 Answers
Http://www.partmaster.co.uk/bush/fridge-freezer/catalogue.pl?shop=bush&path=592117
http://www.buyspares.com/bush/fridge-freezer/catalogue.pl?shop=bush&path=592117
Posted on Nov 16, 2014
zeusfaber
  • 247 Answers
SOURCE: fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
Posted on May 16, 2007
fridgetech
  • 473 Answers
SOURCE: Fridge freezer KIM 29473GB/01
Liners are not able to be replaced. Will need to buy a new unit if the liner is a problem.
Posted on Oct 07, 2007
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
  • 834 Answers
SOURCE: I have a Hotpoint fridge
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
(Air flow through the evaporator core and cold air circulation and re-circulation through the refrigerator is performed by the air circulation fan and it also must be functioning)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl or kick panel at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed. The deforst timer on newer digital models can be built into the circuit board and is not a seperate timer mechanism.
Here are some images that should be similar to your situation to help assist you and the operation principal is the same for either an over-under, or a side by side refrigerator, and let me know if you require any further assistance.
Posted on Oct 06, 2010
Freezer drawer on Kitichen aid french door stuck shut. Been of for 24 hours still won't budge.
tough question
by the look of the picture it should not have that problem
something jammed or fallen on both openings
that stop doors from opening
call a fridge repairer first
those doors cost a lot to replace
maybe the fridge guy can you undo the top hinge of the french doors
if the freezer draw handle is broken you might need his help with that anyway
Sep 26, 2016 | Refrigerators
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Ondesit fridge fridge freezer biaa134fh fridge not cold
It seems lots of people have the same problem with this appliance....including myself......I took the drawers out of the freezer.....removed the iced up plastic cover which houses the fan assembly.....some water had settled in the bottom and froze, therefore stopping it from turning.....just spin it and it with start up again.....hope it helps ;)
Mar 13, 2014 | Indesit BIAA134F White 9.5 Cu Ft Fridge...
Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
If you need any further assistacne please feel free to comment me.
Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Cleaning the base of a GE Profile with a bottom freezer drawer.
Click Here=> PDS22MHR and go to page 11 in the PDF. I believe that will answer your questions of removal. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 18, 2010 | GE Profile PDS22MHR Bottom Freezer...
My frost free fridge freezer is too cold and freezing the food in the bottom drawer there is some ice around the bottom drawer
You may have an issue with the temperature control assembly. Check the temperature settings (ideally at "one-half way" for both fresh food and freezer compartments).
Contact an appliance service company.
Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
Water under vegetable drawers
Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
Nov 19, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Fridge bottom has water under vegetable drawers
May 16, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
120 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
