Question about Vehicle Parts & Accessories
My car doesnt chug in the summer or warmer weather, but when it gets cold it chugs at 70mph, what could cause this
Changed a few spark plugs in it a year ago, it didnt chug all summer, now that its 29 degrees outside, its chugging again not all the time
    New Friend:
    Problem Solver:
  • 12 Answers
Possibly airflow meter should get check out
Posted on Nov 20, 2014
My 1995 Volvo 940 wagon won't start right up in cold weather (below freezing).
You stated that it was hard to start. Did it crank over more slowly than usual? If so the motor oil may be too thick for below zero temperatures. If it cranked normally, there are a number of things that can cause this.This car has fuel injection controlled by the computer(ECM). If the temperature sensor for the ECM is out of specifications, then the ECM will not fuel the motor properly when cold starting. Old age, lots of miles can lower compression and cause hard starting. the fuel injectors may be worn, defective or clogged, delivering the fuel pooly. Was there a check engine light on? This is before mandated ECM monitoring, but if there is a light on, there is a way to check what it is causing it. There are other things like cracked vacuum hoses that can affect the starting. Worn spark plugs and wires can have an effect. When it chugged coughed and spit, was there black or blue smoke coming out of the tailpipe? Black smoke is too much fuel and blue smoke is oil consumption. I know that it is hard to decide where to go for repair, but the dealer has trained personnel, and a warranty for repairs. In my experiance as a dealership technician and an independant shop owner that some things are better off at the dealer, unless the independant shop has factory trained people and lots of information available, you may be charged with them trying to learn on your car. I had a 1987 LeSabre that when the temp was way low, the coil pack failed to spark the car.
Jan 20, 2014 | Volvo Cars & Trucks
My car is chugging it feels like the fuel isn't getting through. I have changed the spark plugs and about to change the fuel filter.
dont just change parts without knowing--scan car at a parts place 1st-------it cud be a failin fuel pump or pressure regulator----or an egr valve--dirty injection system-----worn plug wires------fuel system pressure test or ignition inspection may be in order
Apr 03, 2012 | 2004 Ford Focus
Car chugs and wants to stall
Change the fuel cap. It may not be venting properly.
Jun 15, 2017 | 1989 Buick Century
I have a 2007 ford freestar minivan. My van is chugging I changed the spark plugs, fuel filter, air filter, oil change and its still chugging. The engine light went on that said to change spark plug #2,...
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya Gurus. Have a good look at the sources of the page. Go through the sources to find your solution. Hope it will help.
View Count:2
Aug 11, 2011 | 2007 Ford Freestar Limited Minivan
The car is chugging and also blowing out dark smoke
I do not know much about this vehicle but if it is diesel it sounds like you should clean and or replace air filter and or glow plugs or grid heater... if it is a gas vehicle changing the fuel filter and checking spark plug gaps and plugs and wires also the cap and rotor may have where witch will cause intermittent and weak spark so you could be getting to much fuel and running rich. also if it has a catalytic converter you may want to check if it is partially clogged and if it is have it replaced hope this helps good luck
Apr 28, 2010 | 2004 Renault 181
1995 buick skylark custom ran great now it chugs and acts like a spark plug isnt firing. runs rough and chugs at low speed under 35mph. rough idle.what would cause this?
start by checking the plugs, then see if you got spark at all the plugs, check for vacuum leaks, worn wiring, fuel pressure,
Nov 23, 2009 | 1995 Buick Skylark
'95 4.0 liter grand cherokee chugs in 80 degree or higher weather
Change the mass air flow sensor (maf) . Summer months tend o be humid, this could cuz the sensor to react strangly and alter the Stoch/richness or the air-fuel mixture....Check it out tell if it its helpsful, if not There are acouple others we can look at..
Jun 24, 2009 | 2000 Jeep Wrangler
96 toyota tacoma manual turns over but will not start
Sounds like the system lacks fuel pressure, check the fuel pump pressure.
Nov 27, 2008 | 1995 Toyota Tacoma
Vehicle Parts & Accessories Logo
69 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
