Question about Kitchen Ranges
Hardwire fridigaire electrolux gallery series stove top. Hooked black and red from branch to black and red from stove top. Neutral side hooked green and white from from stovetop to neutral side. Ho
Hardwire fridigaire electrolux gallery series stove top. Hooked black and red from branch to black and red from stove top. Neutral side hooked green and white from from stovetop to neutral side. Hooked white from branch to neutral side. Will not heat what did I do wrong?
  • 1,169 Answers
Should be correct. Maybe it power supply problems.
Have you verify that the line you connected are receiving power on both hot legs ( Red and Black) and that neutral White wire) is actually connected to ground? Use a voltage meter and ohm meter to to do your tests.
Posted on Nov 16, 2014
    Problem Solver:
  • 14 Answers
Green AND White is normally a ground wire and not a neutral. [At least in the USA and I believe is also the same in Europe. Not sure where you are in the USA or Europe, the colors you give sound more like the USA RED is a 120 leg, and Black is a 120 Leg (Hot Legs) white being the neutral. In Europe Blue is normally neutral with Black and Brown being the Hot legs.
Testimonial: "I am in the US and my terminology is not great. I know the hot side is correct. I hooked the green and white from the stove wiring to neutral side. I hooked the white from the branch to neutral side is this the reason it is not heating?"
  • 7 more comments
  • stixoffire Nov 17, 2014
    OK if you have a cheap meter, here is what you can do.
    1: Check RED to White with a voltmeter set meter on AC Volts tRange 300 VAC or 600 VAC should be 120V.
    2: Check Black to White with a voltmeter set meter on AC Volts tRange 300 VAC .or 600 VAC should be 120V.
    Check RED and BLACK - should read anywhere from 208 to 230. VAC
    If this is an older home the wiring is probably 3 wire, in newer homes you have a 4 wire system. Safety wise you will connect a ground from the home to stove incoming wiring to the stoves ground - most likely connected directly to the frame. That should be your Green/yellow or G/W. The white should go to the white line.
    If any of your line voltages are low between RED or BLACK to the white line something is wrong with the house wiring. Also there should not be any voltage Between white and Ground (maybe 1to2Vac MAX is normal) Your house wire might have a simple bare COPPER wire for the ground - this would be the stoves Green/white. Others should be color for color.
    Post a pic of the house wires and the stove wires, if you need some more info.
    BTW: Homes built in the 90's and later should be 4 wire. RED , BLACK, WHITE, BARE COPPER(or green). If your house has 4 wires connect the stove using 4 wires ..There is a safety reason for this. Wear gloves and sneakers when testing live wires (no rings watches etc..) just incase you get too close to a live wire.
    BTW some panels have ganged breakers, and one of the breakers is broke, or the ganging mechanism is broke and allows one breaker to be tripped and the other not tripped. This would show up as very low to no voltage on either the RED [aka L2] or the BLACK [aka L1] line.
  • 83 Answers
SOURCE: GE Easycare Wiring Specs
Not sure what part of the machine component you are referring to but generally the colours mean the following using 240 volts:
Red=Active
Black=Neutral
Green or Green/Yellow=Earth (ground)
White=Switched Active (Become active via a switching component).
I think you should clarify what your attempting to wire up before proceeding.
Posted on Sep 15, 2008
rickzilla
  • 706 Answers
SOURCE: wiring directions for Kenmore 800 Dryer
Hello mynexthome,
Sounds like you did everything correctly however it is possible the wall receptacle may be miswired. The white wire is the neutral, black and red are the line feeds ( hot ) and green is ground. If you are sure the receptacle is wired correctly and that the power cord is wired as you say it is, then there may be an internal issue with the dryer..or some packing material was not removed and is burning off. ( make sure the drum can spin freely and you aren't smelling a belt burning) The red and black are normally on either side of the neutral but you should match the color code on the terminal block on the dryer. Hope that helps...
Regards,
Rick
Posted on Jan 03, 2009
  • 9 Answers
SOURCE: changing a 3prong plug to a 4prong plug on samsung dryer
leave the wire where it was. its a ground wire
Posted on Apr 01, 2009
  • 20 Answers
SOURCE: Moved dryer, hooked up wrong, not working now after re-hooked up
have you check outlet with a voltmeter or even checked breaker? Is your new rect' a 3 or 4 prong outlet? If you hooked up red's to black and black to reds it still should have worked. The 220 volt heating element is between the red's and blacks the 110 circuits would be between a red or black to white wire.
Posted on May 21, 2009
jsrock516
  • 5911 Answers
SOURCE: I need to change the dryer power cord on my Amana
The two wires on either side of the power cord are your HOT leads. They are the voltage carrying conductors. These two wires will connect to the terminal block on the RED and BLACK wires. The middle wire is NEUTRAL and goes to the WHITE wire at the terminal block. Now...with a 3-wire configuration you will need to connect a grounding strap to the neutral wire and ground it to the grounding lug of the appliance. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference between 3 and 4 wire configuration is how the neutral and ground wires are installed. In a four wire configuration these two are independent of each other. In a 3 wire configuration ground and neutral are connected together.
If you have any questions about this repair, please ask me. I hope this helps you.
Posted on Jul 17, 2009
I have a 4 prong stove plug in my trailer.the wires are green,red white and black.the stove only has a space for 3 wires.how do i hook it up?
you have to put on a 4 prong plug on the stove . not difficult not sure of the year it was put into code for trailers . two of them go to ground .
Jan 28, 2015 | GE Kitchen Ranges
Need to know how to hook up to 220 power supply what wires go where we got a red wire,black,white, and green which is ground can u help?
L1
L2
L3
Neutral
Earth
North America
Black
Red
Blue
White
Green
There is no blue cable in a 220V, so you have only; white, black, red and ground always green colored wire.
Looking your plug frontal side.
Green Ground on top (semi-circle)
black on left
red on right
white on bottom (neutral).
Jan 10, 2011 | Miller Bobcat 3 Phase Welder Generator...
Need the positions for a 4 wire hook up on a Maytag dryer PYE2300AYW
Red and Black will be the hot wires and the green will ground ..white wire is your neutral..
Green will be the top , White will be at the bottom red and black will side by side.. Hope this help
Dec 18, 2010 | Dryers
My house wires from the electic stove top has 3 wires and my new bosch electric top has 4 on red, white, green, yellow?
hook the red and yellow off the new stove to the two hot phases-then connect the white on the new unit to the neutral power connection and finally the green wire can hook to the same neutral wire also as long as the power comes directly from the main electrical panel in the home, but not a sub-panel
Nov 15, 2009 | Bosch 30 in. NET7452UC Electric Cooktop
Frigidaire self cleaning stove mod FEF369cgsb ser vf94422321 was originally wired direct and it shows 4 wires. Now I want to use a plug and outlet, 3 prong. How do you connect the 3 prong plug? thank you...
Vivian
the original wiring probably had a red, white, black, and green wire. It is 240 volts. The red is hot, carrying one leg of 120 volts. The black is also hot, carrying 120 volts. The white is neutral, and the green is the ground.
I am against altering this, but you can wire the red and black each to a hot leg, and wire the white and green to the bottom ground. This then introduces a ground wire to your neutral bar in the circuit panel, which is not the best way to do it, but will work.
Best to get an electrician to wire a 4 wire cable to a four prong outlet, and then use a four wire pigtail with a 4 pronged plug.
Lots of people modify it, they ground the green wire to the stove, where the wire originates,and to the box with the outlet in it where it hooks onto the plug if it is metal. Then you have a part ground. And that is assuming you have a cable with wires sticking out to wire to a plug.
Boils down to your decision. If the above isn't the case, get a four pronged outlet and wire the red and black to the top two prongs, the white to the neutral, and the green to the metal box it sits in.
Sirwriter
May 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Wiring directions for Kenmore 800 Dryer
Hello mynexthome,
Regards,
Rick
Jan 03, 2009 | Dryers
To hook the plug into the back of a whirlpool stove, the stove has black white/black black. I have ground black white red
blk is hot white is neutral on your side blk and red are hot white is neutral and ground is earth ground hook earth ground to the body of the range neutral goes to the terminal block
May 22, 2008 | Whirlpool Kitchen Ranges
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
