My Mitsubishi TVs wd 82740 has no picture shows red light when turned on please help
2 Suggested Answers
  • 26 Answers
SOURCE: Mitsubishi wd-60735 no picture and red lamp light
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
Posted on Oct 07, 2011
Mitsubishi WD-73C11, blinking error code 48, replaced power supply board & still showing error code 48. Will not turn on,no sound or picture. HELP!!!!
Hello. I don't have access to the service manual at the moment, but you might want to check the lamp. Aftermarket lamps do not work in Mitsubishi TVs.
Jul 30, 2016 | Mitsubishi Televison & Video
My Mitsubishi tv WD 73734 won't show a picture you can hear sound and it powers on and off lamp light red and timer lighter blinking
No TVs will behave that way due to a timer. TVs only will display a nag screen telling you to reset the timer. If your lamp is more than 2 years old, it is suspect of failure. Be sure you buy a lamp with an Osram brand or Philips brand bulb inside. Any compatible(knockoff)lamps will not perform as they should. Mitsubishi DLP TV Bulbs
These folks sell original Osram bulbs in their lamps and they have a 6 month warranty. I use them myself for repairs and really have had great experiences with them.
Sep 09, 2015 | Mitsubishi WD-73734 73" Television
The status light just blinks and tv doesn't come on
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 03, 2012 | Mitsubishi Cinema WD-82740 82-inch 1080p...
Red light wont show picture
This is either a bad capacitor somewhere in the tv, or the very common power supply/high-voltage transformer.
Jan 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Oct 30, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Mitsubishi w52525 - replaced lamp and red light still on
could be the wrong lamp or not set right in housing or bad door switch.
May 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
New lamp, now color variation, dull picture and overheating
it sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Jan 23, 2009 | Mitsubishi WD-62531 Projection Television
Picture comes on than turns off and red light stays on
you can reset the tv to factory default settings , but before that I need more info ab manufacture date and purchase date you can find the first one on the back cover, if the tv has more than 5000 hrs of use problably the lamp, filter or fans can cause this problem, hope it helps you . let me know
Jun 10, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
