VIZIO 32" Mod# V0320E try to turn tv on sometimes it will come on on the first try other times you have to turn off and on 5/6 times before the pic .. comes on . I would like to have it fixed for us
VIZIO 32" Mod# V0320E try to turn tv on sometimes it will come on on the first try other times you have to turn off and on 5/6 times before the pic .. comes on . I would like to have it fixed for use in my sun room .(i bought another tv to replace this one ) Would it be worth the effort to have it fixed .Or how much would be max i should spend to have it fixed
    Champion:
  • 209 Answers
If the repair cost is more than 50% of the cost of the TV, then it probably is not worth it.
Posted on Nov 24, 2014
SOURCE: Vizio "no signal"
We just had this problem and it was the cable that came with the set. Once we replace this, it received a picture, however, now the volume and on/off does not work on the Verizon remote.
Posted on Mar 09, 2008
  • 19 Answers
SOURCE: Vizio L32 - Picture has turned red and pink.
YOU CAN BUY THE MOTHER BOARD FROM TRITRONICS.
ABOUT 200 PLUS SHIPPING. EVEN IF YOU FIND THE BAD IC
CHIP YOU CANT BUY IT.
Posted on Jan 01, 2009
SOURCE: Digital channels freeze
I also had this channel 5-1 freezing problem and spoke with Vizio support a few times. They thought the problem was the SSID code from the local CBS station and said they would try talking with them. I am not certain if they did this or not, but, as of mid December, my Vizio no longer has this problem.
Posted on Jan 14, 2009
circuitworld
  • 335 Answers
SOURCE: my vizio 32
First try plugging the tv into another wall outlet, see if the one its in now is off. Make sure the ac cord is well fitted into the tv and the wall outlet. If still no power (and no warranty left on the tv) remove the back cover and check the fuse if blown replace it. If the fuse is good then the power supply board needs to be tested. If you know someone who's technically savy let me know I'll walk them through some testing steps to find the problem. Get back too me..
This is the best I can do over the internet.......
please rate this answer when you can....
Posted on Dec 05, 2009
toolkits
  • 1099 Answers
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Posted on Jul 02, 2010
Vizio pop of death, no pic no sound just black screen,
You may need to use the actual plug this time. Unplug the unit from the wall and wait at least 90 seconds to replug it in.
Jul 27, 2010 | Vizio L32 32 in. LCD HDTV
Can I purchase a replacement screen for my vizio v0320e
you can try this place that sells lcd parts shopjimmy but typically the lcd screens cost more than a new TV does.
Apr 06, 2010 | Vizio L32 32 in. LCD HDTV
The screen on my Vizio television went blank. The
if you was trying to wipe your tv off with glass cleaner are something that can make your tv go to a black pic
Sep 22, 2009 | Vizio L32 32 in. LCD HDTV
I have a Vizio hdtv 32'' lcd the power button is yellow, when I turn the tv on the button turns green but thats all that happens no pic or sound the model is Vizio L32HDTV 10A
I would guess the power supply went bad. The Vizio parts store sells the replacement for $82. Cheap fix for a decent TV.
Replacing it only requires a moderate mechanical skill. Removing the screws from the case is the hardest part. Remember to unplug the TV before you attempt this repair, or contact a local repair shop. They may only charge a small fee to install it for you.
Sep 13, 2009 | Vizio L32 32 in. LCD HDTV
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
May 06, 2008 | Vizio GV42L 42 in. LCD Television
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Code for Vizio tv
Go to the VIZIO site - they post codes. Try these for Cox:
0030 or 1758 or 0178
Dan
Nov 15, 2007 | Zenith ZEN700 Remote Control
Televison & Video Logo
Top Televison & Video Experts
