Question about Hoover Vacuums
Dismantle a hoover 5110 heritage
No suction through to dust canister, I need to dismantle to unblock.
reddevil6
  • 1673 Answers
SOURCE: Poor suction-need to know how
I assume this is a Hoover Bagless, if poor suction, the hose or dirt inlet by the brush roll may have a clog. The filter inside the dirt container may need replacement. Some had a screw to take out to remove the cover for the filter, the one under where hte dirt container sits. Alos the belt may be stretch and won't turn the brush roll under load. Having the model number would help.
Posted on Apr 20, 2008
SOURCE: Dyson has lost suction and loud noise from base(?),
I had the same problem, from right out of the box. Now that I just threw mine out, I see this site that indicates there's a fix for it:
http://ths.gardenweb.com/forums/load/cleaning/msg0415060828462.html
And search for other sites isung "dyson grinding" or similar.
Since I was an early adopter (had one as soon as they came stateside), I did not have the benefit of countless others having the same problem, I just attributed it to a junky design, since so much else about this vacuum was poorly designed, like the seals, hoses, etc.
Give them a call, and good luck! I might rescue mine from the heap and do the same.
Posted on Apr 08, 2009
  • 34 Answers
SOURCE: no suction throught the hose
sounds like its blocked stick the broom handle thru it , there might be something plugging the hose under the bottom at the connection
Posted on May 22, 2009
  • 5 Answers
SOURCE: I have no suction with my Hoover Mach 5 vacuum.
I had a similar problem. Two things to try. There is a lock symbol on the canister you need to ling it up with the mark on the top (the silver part has a line on it). It can be assembles 3 different ways. Also I over looked the sticker in the back of the canister compartment indicating a filter in the top of the canister compartment. There is an orange lever there to release the filter. Hope this helps.
Posted on Jun 18, 2009
nwj2468
  • 76 Answers
SOURCE: My Bissell cleanview is NOT suctioning well, all
did u check the filter above the dirt cup?
twist the yellow piece and wash the filter
Posted on Aug 22, 2009
How to empty canister hoover 18v stickvac
twist the container anti clock wise 1/4 turn and it comes off
arrow directions on body of the unit
Clue here
following problems under warranty , I took mine in for repairs and found that the design fault did not allow for the section from the head to the canister blocking up which resulted in an over heated motor
The fix is a redesigned head that has a removable section that allows access up the suction tube to the canister for cleaning of the small tube section
indications are --doesn't appear to have enough suction
Talk with your hoover service agent and consider replacing the old head with the new model
Apr 13, 2018 | Hoover Vacuums
Top filter keeps clogging up??
Just make sure the rubber gasket is secure at the bottom of the dirt cup if it rides up the dirt will go straight up to the filters
here is the hepa that should be change when it is dirty
Hepa Filter Hoover U5780 WindTunnel Bagless 93002360
Dec 07, 2015 | Hoover U5780900 Bagless Upright Cyclonic...
We have a dirt devil that when the canister is engaged, it no longer has suction. The canister is empty. Thoughts?
you turned the switch to blow instead of suction
remember them days .. no .. i do
Jan 12, 2015 | Hoover Vacuums
Hoover heritage 5110 vacuum cleaner manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Hoover model by clicking the link below.
http://homeappliance.manualsonline.com/manuals/mfg/hoover/5110.html
You can purchase a wide variety of high quality Hoover replacement parts for your Hoover vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Hoover
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 03, 2014 | Vacuums
The 70210 is a few months old. It doesn't ****. There is suction going into the canister, but it's not reaching the hose. I've ensured there's no blockage in the hose, blown it clean with...
IF you can use a broom stick to run through the hose to make sure that there is nothing in it, then you need to check the output filters. They get plugged up with fine dust particles and the suction is reduced. The output filters can usually be rinsed out.
Dec 18, 2017 | Hoover UH70210 Bagless Upright Vacuum
Dust bag was full and have changed it but not getting proper suction since bag change - why?
The extension tube is probably blocked. Check for suction with all the tubes off - if there is suction now then the tubes are blocked - be carefull not to damage them if you poke things in the unblock them.
Feb 13, 2011 | Miele Revolution 600 Bagged Canister...
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Hoover Windtunnel Canister Belt
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
I vacummed some sheetrock duct up with my hoover elite cyclonic.. i dumped the canister to empty the dirt and dust, but now theres not as much suction... is there any other area I should be cleaning... or...
do not put the filter in water, it will ruin it. if banging out the filter did not work than you should probably replace it, sheet rock dust is very fine and will easily clog most filters.
Aug 20, 2009 | Vacuums
Vacuums Logo
54 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
