Question about Troy-Bilt Squall 2100 208 cc 21-in Single-Stage Gas Snow Blower 31AS2T
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
  • 802 Answers
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Posted on Nov 16, 2014
Where is spark plug located on Squall 2100, 4 cycle,208cc ohv?
You will have to drop the back panel. See picture also add a link to your manual.
Troy Bilt Snow Thrower 31AS2T5F711
Feb 15, 2016 | Troy-Bilt Squall 2100 208 cc 21-in...
Chute on Troy Bilt single stage snow thrower won't turn
CHECK TO SEE IF THE ICE FROZE I THE CHUTE YOU MAY HAVE TO PULL THE COVER OFF THE TOP THIS SOUNDS LIKE THERE MIGHT BE ICE BUILD UP ALSO AFTER THE COVER IS PULLED OFF CHECK THE GEAR THAT TURNS THE CHUTE BY TURNING THE HANDLE
Feb 26, 2015 | Troy-Bilt Squall 2100 208 cc 21-in...
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
My Troy bilt squall 2100 snowblower does not idle steady. It races and slows while idling.
It sounds like the carb needs cleaning and readjusting, or the fuel filter is clogged. Good-Day! Remove and clean out carb, it may be dirty inside.
Nov 13, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
How do I drain the oil from my Troy bilt 2100 squall snow blower so I can change the oil?
You need to remove the lower panel to access the engine. In the engine blow-out, the oil drain plug is numbered 77 (bottom of the crank case).
25256884-5livr0uqynklw3svefpqfefw-2-0.png 25256884-5livr0uqynklw3svefpqfefw-2-2.png
Oct 26, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Troy-bilt starter seized
Remove starter, and see if it will turn over by applying 120v to starter. If it wont work. Starter is bad. Good-Day!
Mar 13, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Snow blower runs rough, backfires
Clean the choke asembly and air filter .
Dec 26, 2013 | Troy-Bilt Squall 2100 208 cc 21-in...
Troy bilt sequall 2100 will not start. has new plug
Is the gas making it TO the new plug? Pull it over a dozen or so times on full choke and then pull the uh to see if its wet meaning the engine is getting fuel. Also make sure the safeties and off switches aren't preventing it from starting
Nov 18, 2013 | Troy-Bilt Squall 2100 208 cc 21-in...
Troy-Bilt Squall 2100 208 cc 21-in Single-Stage Gas Snow Blower 31AS2T Logo
206 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
