Question about Ovens
Whirlpool built-in single oven AKZ451/IX/01
Our oven is not reaching the correct temperature, in fact it will only go up to 150 degrees F. Could this be a thermostat, if so where can I buy one or is it likey to be something else
  • olliecopter Sep 07, 2008
    Whirlpool built-in single oven AKZ451/IX. Not getting up to temperature?
Changed the heating element. Quite an easy job. Problem fixed.
Posted on Oct 28, 2008
Bake element open not heating or the sensor is off. You copuld also have only 110 volts from a bad breaker sor shorted wire on the 220 side. It may be one of the fuses out if you have fuses as this will only turn on the Broil elemnet at half voltage 110.
Normal operation is bake elelment at 220 vlots and bake element at 110 volts. In preheat some elements are both on till temp reached and if the bake element is open (shorted out) the broil element stays on and never shuts oof until the temp is reached which it never will if the bake element is bad.
  • 248 Answers
If this is an older oven, check to see if it has a control knob or switch labeled "manual and "hold". Make sure it's set for manual. The hold setting maintains temp at about 140 degrees.
If not the case, is this gas or electric?
Posted on Nov 11, 2007
I have whirlpool oven akz451/ix/01. My element is square when I look for a new one they are all round ?? Will this work in my cooker ??
whirlpool service center /agent will have a correct element for your unit
the shape is probably for a more even heat distribution in the oven as it will cover the floor/ top area of the oven better
Nov 30, 2016 | Whirlpool Ovens
Whirlpool oven AKZ451/IX/01 display has intermittent display. How do I change it?
Open the oven door and look at the underside of the control panel.
Oct 19, 2014 | Whirlpool Ovens
I moved into a new flat and the AKP 239/01 IX stove was already built in and there is only user manuals in every other language except English!! The owner does not have it and no-one knows where it is! I...
google -- user manual for ( make and model of stove ) and download the pdf version
failing that go to places like Jaycar and buy an infrared thermometer
you aim this unit at where you want to read the temperature and it reads it
so aim it at the oven glass and you have the temp
or aim it at a hot plate and you have the temp
Sep 08, 2017 | Whirlpool Ovens
My Whirlpool AKZ451/IX/01 will not heat up correctly
I can fix this for you. Where are you residing please? Thanks David. "The Famous Forry'
Oct 20, 2017 | Philips Ovens
I have a Whirlpool AKZ451 built in oven that is not reaching temperature. The oven element appears to be working, could this problem be the oven temp sensor?
yes, or the oven control itself,make sure also to closely inspect the element itself for any "HOT-SPOTS" where its getting a high resistance area and not passing all the current needed to heat the element
Oct 29, 2009 | Whirlpool AKZ159IX Oven
Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
could be a blown element if not it could be a safety cut out or the stat
May 17, 2009 | Whirlpool AKZ159IX Oven
Problem with our oven
how to fit a heating eliment to a whirlpool akz451/1x/01 oven please
Feb 24, 2008 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
1,543 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
