Question about Maytag Model E2l Vintage Wringer Washer With Pump Still In Use
How do I check the lubricant level
What grade of lubricant is needed, and where do I put it?
You empty the lub out
and wash it out with petrol a few 10ml at a time and move it around
then once flushed out
you replace the oil with the makers recommeded fill level
and that is from the manual
https://www.google.co.uk/search?q=Maytag+e2ls+oil+fill&ie=utf-8&oe=utf-8&gws_rd=cr&ei=CNaIVKT0HNGR7AbD_4GwBQ
Posted on Dec 10, 2014
Engine loud
If this is knocking is coming from within the engine, some possible causes could be using too low grade of fuel (regular vs plus or premium if your vehicle calls for higher grades), some timing issues, needing to replace your spark plugs (may have incorrect or worn out plugs), or plugs & wires if your vehicle has both (some do not), some internal combustion issues, or possibly even problems with rods/bearings. How's your oil pressure??? Are your gauges reading low? This can be a cause! Sometimes vehicles will "knock" if the oil level drops too low, or it may not knock until the oil in the engine has been depleted. (You could be facing serious engine problems if this happens!) If you keep your oil checked and at the accurate levels, and keep it and the filters changed regularly to ensure "clean" oil in your engine, this helps with lubrication of the engine parts, helping with lessening of the wear and tear on the engine, as well as extending the life of your engine. (It is also helpful to let your engine idle for a little while and warm up before driving (especially with rapid acceleration habits) to allow the parts to become lubricated, especially in cold weather). If you try upgrading to plus or premium fuel in your car, and it doesn't help, make sure your engine oil level is okay. If you're unsure, ask your mechanic to check things out for you. You may just need a good tune up. Regular service and maintenance is essential for your vehicle's engine and major components, and also to lengthen the life of your vehicle, especially the older your vehicle is and if it's considered a "high mileage" vehicle. I'm no mechanic but I grew up in a family of mechanics and do know a few things about vehicles. Hope this helps!
Mar 01, 2014 | Chrysler Cars & Trucks
HI I AM LOOKING FOR A FOOD GRADE SEALANT THAT CAN BE USED ON THREADS ON A PIPE USED FOR A VERY LIGHT GRADE OIL
Here are a three places that sell food grade lubricants-
www.webstaurantstore.com/.../food-grade-lubricants-and-food-safe-lubri.
- www.lowes.com/pd_403826-75041-10340_0 and
Oct 07, 2013 | PERMATEX NON-CHLORINATED BRAKE & PARTS...
5 speed manual transmission
SAE 75W85, GL-4, approx. 2.0 Litres.
Re check oil level after test drive.
May 09, 2013 | Toyota ECHO Cars & Trucks
I have a dryer that is vibrating quite a bit. It has been vibrating at least some for a while because it put a hole in my linoleum I moved the drver, made sure it was level and currently have put heavy...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me,
Dec 04, 2010 | Dryers
Oil is comong out of crank case breather,oil level in motor is correct
make sure u hav correct grade lubricant-the oil maybe to thick or double check level to make sure its not too high
Aug 30, 2010 | Honda CRF 450 R Motorcycles
How to drain and put new transmission oil on my chevrolet aveo 2005 manual transmission?
you dont ---end of story it should never need changing on a modern vehicle ,unless you take the drive shafts out to do a clutch then you top it up through a filler plug at halfway level on the gearbox ,Dont make work .
Aug 17, 2010 | 2005 Chevrolet Aveo
Have a 99 model....been setting awhile and I just put a new battery on and was looking at the oil window and looks like I need to add some....lost my manual...what kind of oil should I use.
Remember to stand the bike upright before checking the oil level, if oil is needed you should speak to the shop who did your last service. Ask them the grade of oil they use as a standard, purchase some new oil and top up as nessesary. If you did the service yourself and you can't remember the type and grade of oil you used, it would be best to change it and enter the details into the service book. Remember to always check the oil level standing upright as the oil level on the side stand will be totally different.
Jul 17, 2010 | 2001 Suzuki VL 1500 Intruder LC
What is the ticking sound when you first start the engine. it goes away when engine is revved
you need to verify if your vehicle is low on oil ,in need of a oil change or what grade of oil ,you need to rule these out first and then go from there,hope this helps
Dec 11, 2009 | 2004 Jeep Grand Cherokee
What type of oil,oil filter and transmission fluid do i need? for a straight, 5 speed 93 jeep wrangler?
Jeep Wrangler/YJ 1987-1995 Repair Guide
Engine Oil
Fig. 1: Be sure to select the proper API quality classification and SAE viscosity grade of engine oil (10W-30)
Oil FIlter (K&N sample)
HP-2004 work for 2.5L and 4.0L
Manual Transmission
The level of lubricant in the transmission should be maintained at the filler hole on all manual transmissions. This hole is on the right side. When you check the level in the transmission, make sure that the vehicle is level so that you get a true reading. When you remove the filler plug, lubricant should run out of the hole. Replace the plug quickly for a minimum loss of lubricant. If lubricant does not run out of the hole when the plug is removed, lubricant should be added until it does. Replace the plug as soon as the lubricant reaches the level of the hole.
Fig. 1: Manual transmission fill and drain hole plugs
DRAIN AND REFILL
Remove the drain plug which is at the bottom of the transmission. Allow all the lubricant to run out before replacing the plug. Replace the case with the correct viscosity oil. All manual transmissions use SAE 75W-90 API quality Grade GL-5 gear lubricant. Tighten the fill hole plug to 27 ft. lbs. (37 Nm).
I hope help you with this (rermember rated this help) Good luck.
Oct 12, 2009 | 1993 Jeep Wrangler
Maytag Model E2l Vintage Wringer Washer With Pump Still In Use Logo
156 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
