Question about Dryers
How do I remove the bottom mounts on the Lasko fan?
    Top Expert:
  • Dryers Master
  • 3,698 Answers
Www.laskoproducts.com
Posted on Nov 17, 2014
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
Fan will not turn on
Check to make sure the outlet that you have the fan plugged into isn't blown out. After that, there check to make sure that the motor isn't bad and the teeth aren't stripped. You will have to take it apart to test!
Aug 24, 2014 | Lasko 3016 Wall Mount Fan
Need to remove cover on LASKO tower fan Type TF3 to clean out dust accumulation. 2 of the retaining screw heads have no screw driver slot. How are these removed?
DO NOT REMOVE SCREWS OR TAKE APART.!!
according to what i have read because it is an ion fan it may damage it. i tried the canned air. not strong enough. i looked on u tube and tried what i found. get a leaf blower. yeah it works!!! i tried to put my foot on the bottom to hold it, i needed a bigger foot. ;-) the fan blew over. i had my son hold it and you should have seen all the dust that was in that thing!!.
Sep 01, 2013 | Lasko Dryers
My Lasko E20739 blower fan works but does not oscillate. The small 120V motor that does the oscillating seems to be the problem.Please confirm and advise where can I buy s replacement motor Peter
i don't think it's going to be a motor issue, these fans have a round plastic gear in them that commonly go bad. remove the bottom cover by removing (5) phillips head screws, then unwind the power cord from the cord holder rembering the path, then remove the (3) large phillips screws, then just slide the base of the fan off and the gear is right there. if the gear is bad, you'll know cause there'll be pieces of plastic everywhere and the teeth on the gear will be rounded off. have fun. oh, for the part, i suggest contacting lasko at www.laskoproducts.com
Aug 21, 2010 | Lasko Heating & Cooling
Lasko Box Fan Stinks!
same thing with my lasko box fan awful oil smell
Aug 05, 2009 | Lasko 3720 Floor / Box Fan
My lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
Jul 22, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Loud noises from Lasko fan motor?
The problem most likely lies within the fan motor of your Lasko unit. I just got fed up with my Lasko tower fan (model 2515) making a rumbling noise on and off and so I took apart the entire thing. I found the noise to be coming from the Decomin 2033014 motor in the unit. Took apart the motor and found that it is so cheap that it doesn't even have bearings! Just a few plastic discs on a spindle. I tried greasing the discs again but it didn't work. The only solution is to get a new motor. I am really disappointed in the quality of these Lasko fans.
Jul 07, 2009 | Lasko 2530 Elite WindTower Fan
Problem with a Lasko 3440 Floor/Box Fan.
light is on ,but there is no movement from the fan. I think I need a fan motor.Lasko 20" fan motor part #3440.
Mar 30, 2009 | Lasko 3440 Wind Tunnel Floor / Box Fan
How to reset Tilt Switch in LASKO Ceramic Heater 5540?
I don't have manual, it's a borrowed one. Several days later, I pushed the botton at the bottom several times, looks it solved my problem.
Feb 08, 2009 | Lasko 5540 Ceramic Compact Heater
How to open the casing
Question does the base underside have any removable screws that you can remove? If so, start from there. The top part of the fan should pop off with a screw driver. Exposing the screws securing the shell of the fan.
May 09, 2007 | Lasko 2115 Wind Tower Fan
Dryers Logo
29 people viewed this question
Top Dryers Experts
