Question about Drills
<!-- from fixya rte -->How i can reset my hilti service light te 56 - Drills
  • 152 Answers
SOURCE: hilti te 10 switch problem
You may research your area for a Hilti service center / dealer or order your part directly from
www.hilti.com
or call (866) 445-8827
Good luck
Aduz
Posted on Mar 15, 2009
rowdy45176
  • 2176 Answers
SOURCE: service light
You can reset the light. What you need to do it remove the handle assembly from body of tool. The contacts will unplug. Then plug the cord in and pull the trigger and sometimes the light will blink, while holding the trigger in the on position unplug the cord. reinstall the handle and the light should go out. Sometimes you have to pull the trigger while plugging cord in but this should work. and then while holding unplug cord.
Posted on Sep 21, 2009
Testimonial: "excellent, tried it out and it worked... thanks very much :-))"
  • 123 Answers
SOURCE: hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
  • 61 Answers
SOURCE: I have a Hilti TE 905 AVR the service light came
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Posted on Dec 13, 2009
SOURCE: service light on
Hilti TE 706 is not having any carbon brushes... its a brushless SR motor. this indicator normally comes after 150 working Hrs. and then machine automatically stops to avoid damage of the internal parts.
In this situation it is advisable to send that machine to hilti service center for normal service and oil changing. and at that time service person will reset that service indicator by connecting machine to computer.
Posted on Dec 25, 2009
Is there annybody in the netherlands with a service reset tool SRT from HILTI?
Mogelijk is er voor de powertool een hack the vinden door hilti service reset tool op google of YOUTUBE in de zoekmachine in te vullen voor mogelijk enkele corresponderende voorbeelden tja marketing technische truukjes te veel Hilty is op zich niks mis mee mogelijk is de overstap op DUSS powertools voor de toekomst een betere optie
Aug 23, 2017 | Hilti Drills
I need a parts diagram for a hilti hammer drill TE-56
Request the diagram directly from Hilti.
Feb 06, 2017 | Hilti Drills
Hilti te 56 combi hammer not working
The gears inside that engage the chisel points to move back and forth are either not alligned properly or are stripped. You'll have to open up the hammer to see what, exactly, is the problem.
Sep 20, 2012 | Dewalt D25330K 2KG Sds Plus Demolition...
How to reset service light on hilti te 76 atc??
Only factory service can reset certain faults.
Test kit is available to run drill without electronics.
Sep 17, 2012 | Drills
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
Hitli te 905 avr. light is on. any idea what it
Jul 16, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
I have a Hilti TE 905 AVR the service light came on and it stopped working. Is there a troubleshooting guide to fix and reset this. Also, schematics can be found at:...
Jul 08, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Hilti 76 p atc
Hi . The solution offered by rowdy (pull the trigger and hold it until light goes out) will only work on older machines, the newer machines have more complex electronics that need reseting using an optical reader which plugs into a PC , you will also need the Hilti ODA Software. this is not available to the general public. you may have to send it back to hilti for service and reset. this is free if the machine is less than 2 years old.
Jul 02, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Service light on
When the service light comes on in a normal Hilti all you need to do is replace the brushes,....however on a te-706 there are no brushes to replace, you will need to contact Hilti and have them service it.
Nov 14, 2008 | Drills
Drills Logo
235 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
