Question about Furniture
Where can I buy a slip cover for an oversized recliner?
I can't find one to fit the back is about 110 inches around.
How to Sit at a Computer?
  1. Push your hips as far back as they can go in the chair.
  2. Adjust the seat height so your feet are flat on the floor and your knees equal to, or slightly lower than, your hips.
  3. Adjust the back of the chair to a 100°-110° reclined angle. ...
  4. Adjust the armrests (if fitted) so that your shoulders are relaxed.
Oct 18, 2016 | Computers & Internet
How do i replace 2 3" springs on stratford recliner.
Get Recliner-Handles Sofa Spring Repair Kit for La-Z-Boy ...
? 1:37
www.youtube.com/watch?v=_hHUNVAQsk0
May 28, 2015 - Uploaded by Faith Rogers
Recliner-Handles Brand Replacement Sofa, Sectional, Couch, Love Seat, Recliner, ... This sofa seat spring ...
Replacement Recliner Release Handle For Stratford and ...
www.recliner-handles.com/replacement-recliner-release-handle-for-stratf...
This flapper handle will fit Stratford and Stratolounger recliners and others that ... 3 3/4 X 3 INCH INEXPENSIVE EASY WAY TO REPAIR YOUR RECLINING ...
Oct 31, 2015 | Washing Machines
Will my outdoor sofa fade in the sun?
Yes, it can happen if your sofa is not having that much efficiency to tolerate the harsh UV rays of the sun, it can fade up.
You can use high-quality recliners in place of a sofa which is very strong and comfortable. You can use it both for an indoor and outdoor purpose. One of the reputed online platforms that would provide you whole guidelines for these outdoor recliners is the Oversized Recliner.
Some of the best pieces of outdoor recliners are:
a. CARAVAN SPORTS INFINITY ZERO GRAVITY CHAIR
b. ODINA OUTDOOR BROWN RECLINER
c. HANOVER VENTURAREC VENTURA INDOOR/OUTDOOR
d. OUTDOOR WICKER ADJUSTABLE RECLINER WITH CUSHION
e. HANOVER STRATHMERE OUTDOOR LUXURY
bbce1276-8d6b-4b66-b012-807e1deccf67_1.6839e880af7f722fe97dec420e367e45-h0dw3nukocybzc2ldxpmk5v5-2-0.jpeg
Feb 13, 2013 | Furniture
What exactly is a recliner? How is it different from other chairs?
A recliner is a versatile flexible chair that more comfortable than any other chairs.
They are made up of fabric or leather and can be used for both sleeping and sitting.
You can get these recliners from Oversized Recliner, the best pieces available here are:
a. RECLINER GENIUS 360 DEGREE SWIVEL MASSAGE RECLINER
b. PULASKI BIRCH HILL
c. MONARCH SPECIALTIES IVORY BONDED LEATHER RECLINER
d. PULASKI HARMONY SWIVEL GLIDER
e. DIVANO ROMA BONDED LEATHER ROCKER
Aug 09, 2012 | Furniture
We live in a small apartment but would love to have a recliner to sit back and relax on when we come home from work. Is there such a thing as a smaller sized recliner that will not be as bulky and can fit...
Yes, you can a wide variety of small sized designer recliner in one of the best reputed place which is Loveseat Recliner.
Some of the attractive recliner available here are:
a. CLASSIC AND TRADITIONAL BROWN BONDED LEATHER RECLINER
b. COASTER HOME FURNISHINGS MOTION
c. RED LEATHER RECLINER CLUB CHAIR
d. SWIVEL GLIDER RECLINER CHAIR
e. ZERO WALL RECLINER CHAIR, and much more.
innovative-textile-solutions-plush-wing-recliner-protector-recliner-covers-5bjzt1amsw5yuu0bttpforya-3-0.jpg
What is the typical length of benches?
A Bench between 42 and 52 inches in length will seat two adults comfortably. A booth-style table with a 48-inch bench on each side will fit a family of three children and two adults. On average, benches have a height of 18 inches and a depth of approximately 17 1/2 inches.
Jul 25, 2012 | Exercise & Fitness
How many running watts will the saw take, I am buying a small generator and need to know the size I need.
The largest remington pole saw is an 8 amp model which would take about 900 W on a 110 v supply.
The 6 inch model takes 6 amps wich would be about 700 watt.
It's probably best to oversize your generator to about 2kva then you can use it to power lights and other power tools etc
Feb 17, 2011 | Remington Polesaw Wizard
My washer wont agitate or spin
If this machine is a drum type and NOT A TOP LOADER (There was no mention of the model) then the overload has possibly caused the drive belt to either break or jump off the drum pulley.
IMPORTANT: THERE ARE LIVE SWITCHES AND MAINS SUPPLIES WHEN THE COVER OF THESE MACHINES ARE REMOVED, DO NOT TOUCH OR TAMPER WITH ANY PART, UNLESS THE POWER IS OFF AND THE PLUG REMOVED FROM MAINS SOCKET.
If the belt has slipped off or has broken, it can be replaced by fitting the (new) belt around the motor drive pulley (small end) and refitting around the drum pulley, you can do this by feeding the belt around the drum pulley, by holding the belt in place and feeding onto the pulley (IT IS EASY TO GET YOUR FINGERS NIPPED BETWEEN THE BELT AND LARGE DRUM PULLEY WHEN ATTEMPTING TO FIT BELTS BACK - SO BE VERY CAREFUL)
Best of Luck!!
Jul 04, 2009 | Whirlpool LSR5132PQ Top Load Washer
Drivers side seat not working properly
hi this sounds like the coiled spring that is enclosed behind the cover where the recline lever is it has either broken or the pin it locates on has snapped or spring has for some reason slipped its fastening ? try removing cover and investigate the spring and its locator points
Dec 29, 2008 | 2006 Hyundai Sonata
Furniture Logo
101 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
