The fan works but no heat is coming out of the unit
  • 148 Answers
Need more info
Posted on Nov 23, 2014
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Should the fan come on the outside unit when the heater comes on?
If you have a heat pump unit then yes because the AC is working in reverse and makes heat from the outside unit. If you know you only have electric heat only then no.
Feb 11, 2015 | Heating & Cooling
Heil epm36f19a1 runs but no heat
Fan relay is stuck among other things. The thermostat turns on the combustion air fan and puts power to the spark unit. If the burner comes on after the temperature in the heat exchanger rises the indoor fan will then come on. After the thermostat comes to temperature the power to the gas valve which shuts off the burner. Then after the heat exchanger cools a bit the indoor fan will stop. That's the sequence of events. look at the switches that control the fans. There is a wiring diagram somewhere on one of the panels that access the unit for service.
Mar 06, 2013 | Electronics - Others
I have a Goodman a/c, furnace outdoor combo unit the the fan won't come on for the furnace. When I set the thermostat to heat, I can see the two heating coils come on, then glow bright orange for about 20...
To me it sounds like you need a fan limit switch to sense temperature increase and turn your fan on. At least you know that everything else is working. With out a schematic I can not tell you what type of limit this would be but I would look for a sensor either mounted right above the coils or beside them.
Have you looked on the inside of cover plate for heating and blower compartments.Often times they will put a wiring diagram there. Wished I could be of more help. Thank you
Jan 20, 2011 | Goodman Heating & Cooling
Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
May 28, 2009 | Heating & Cooling
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
Heating not working like it should
The fan for the A/C should blow harder than in heat. The fan should be on high for cool and low for heat. You can change the heat setting for medium but I would not recommend it because it may make heat coming out feel less.
Nov 21, 2008 | Heat Controller Thru-Wall/Window Air...
Blower fan will not come on when set on Auto in heat mode.
the fan is controlled by a fan center or a stack switch. as burners light and heat up the spring sensor on the bulkhead above burners heats up and turns and a a point energizes the indoor fan if it gets to hot the burners go out on safty. sounds like a fan control is bad tap on them gently and they sometimes break loose but if not then have a pro replace fan control and test heat exchanger.
Oct 24, 2008 | Ruud UBHC Air Conditioner
Heating problems
It sounds like the unit is going into a defrost cycle, which is normal for heat pumps and means all is working ok when it gets around 35 or colder they start to do this more often when the red light goes back off , the outdoor fan should come back on. You may also notice steam (may look like smoke) coming from outdoor unit. Is that what happens??
Jan 15, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
