Question about Honda 2007 Pilot LX
Where is the shift interlock on a 2007 Honda Pilot?
I cannot shift my Pilot out of park
    Sergeant:
  • Honda Expert
  • 406 Answers
It's a solenoid normally underneath the shifter some may have an override which is a slot for insertion of key
Posted on Nov 26, 2014
2007 ford expedition won't come out of park from time to time
Problem with shift interlock , maybe . Shift interlock is a safety system that won't allow the gear selector to move from park to any gear unless driver is pushing on the brake pedal . Electroniclly controlled , brake switch , interlock solenoid , SJB - smart junction box ,wires etc.... Could set DTC'S - diagnostic trouble codes .
Apr 18, 2017 | Ford Cars & Trucks
My 2007 Honda Pilot will not shift out of park
Check the fluid level in the transmission.
Nov 16, 2014 | 2007 Honda Pilot
Interlock sensor Ford Fusion, Key Stuck
Do the brake lights work ?
Diagnostic Trouble Code (DTC) Chart
DTC Component Description Condition Symptom Action B2572 Brake Shift Interlock Brake Shift Interlock Output Circuit Failure The associated circuitry connected to the smart junction box (SJB) or fuse, or the SJB itself may have an issue causing a brake shift interlock concern. Brake shift interlock is inoperative or does not operate correctly. Go To Pinpoint Test A .
May 20, 2017 | 2007 Ford Fusion V6
Shift lock release honda civic 2008
Most likely you have a problem with the shift interlock solenoid located under the shifter. It gets its signal from the brake switch every time its pressed. If your brake lights come on when brake pedal is pressed, then you can assume the brake switch is o.k.
Dec 22, 2013 | 2003 Honda Pilot
My 2007 chrysler pacifica wont shift out of park.
SHIFTER LOCKED IN PLACE
  1. Remove the instrument panel cover below the steering column, then remove the steering column shrouds to gain access to the brake transmission shift interlock (BTSI) solenoid. The solenoid is part of the interlock cable assembly.
  2. Disconnect the wire connector from the rear of the BTSI solenoid.
  3. Insert the ignition key and turn it to the ON position.
  4. With the brakes applied, try moving the shifter out of the PARK position.
    • If the lever now moves freely in and out of PARK, perform the Circuit Test below.
    • If the shift lever still does not move from the PARK position, remove the BTSI solenoid from the shift lever assembly. If the shift lever now moves freely in and out of the park position, the BTSI solenoid is faulty and the interlock cable must be replaced. If the shift lever still does not move from the park position, the problem is in the shift lever assembly or the ignition interlock cassette
Aug 14, 2011 | 2007 Chrysler Pacifica FWD New Cars
Car stuck in park took cap off near gear shift to release it but when you put it back in park same problem . brake light switch not working
the brake light switch needs to be repaired first before you can accurately diagnose the shift interlock system. the brake light switch sends power to the shift interlock solenoid for the gearshift to release from the park position.
Jul 30, 2011 | Honda Pilot Cars & Trucks
07 accord want let me put into gear from park brake lights work fine
Looks like the switch that controls the transmission shift interlock may be bad. Below is instructions on how to bypass the switch and be able to change out of park until you can take care of what ever the problem is. I hope this helps and good luck.
May 19, 2011 | 2007 Honda Accord Sedan
My gear shift on my 2007 dodge magnum will not get out of park. Is there a way to temporarly fix it till i can get to a mechanic!?
The BTSI (Brake Transmission Shift Interlock) has a small spring retainer on the park safety. A small plastic tab breaks & releases the spring. This requires the shifter to be disassembled in order to be repaired.
If you are lucky, your brake interlock is the only problem. There is a bypass switch located beside the gear selector. Remove the small "cubby" bin located next to the gear shift by simply lifting up to remove. You will note a small access port and a pink button contained therein. Press the pink button to override the brake interlock.
If you still cannot shift into park, then the shifter must be removed for the spring repair. Even if yours is still under warranty, you will get another shifter that will eventually fail due to poor engineering
Sep 20, 2010 | 2007 Dodge Magnum SRT8 Wagon
Honda 2007 Pilot LX Logo
62 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
