Question about HP LaserJet 5 Printer
<!-- from fixya rte -->How do I increase the display brightness - HP LaserJet 5 Printer
  • HP Master
  • 1,915 Answers
If you have an older model laserjet there is no adjustment for the display brightness. Either there is dirt on the inside of the display which can be fixed by taking the control panel apart, or the display is failing.
Posted on Nov 17, 2014
Screen not bright auto-brighness not working
To increase the brightness, either swipe up from the bottom to get the control panel, and increase the brightness there (slide the slider just below the 5 circles to the right) or go into Settings > Display and Brightness> Increase brightness using slider. You can also turn on the auto brightness from here if it is off, or turn it off if it is not working like you want it to.
May 13, 2016 | Apple iPhone Cell Phones
Adjust screen brightness
go to start-->control panel--->display--->adjust brightness
i need to know what operating system you use this will work for only Vista and 7 and 8 and 8.1
Oct 10, 2014 | IBM ThinkPad T40 2373 Notebook
How do i increase the screen brightness HP elitebook 8530p
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1 Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2 Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3 Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4 Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5 Click "Change Advanced Power Settings."
Step 6 Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7 Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8 Click "Plugged In" and set its brightness percentage.
Step 9 Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10 Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Hope this helps!
Apr 28, 2014 | HP EliteBook 8530p Notebook
Bad home key on thinkpad g41 keyboard is there an alternate way to increase brightness?
Try using Thinkvantage Application to adjust as follows:
ThinkVantage Control for Display Brightness
  • 4 Click the "Start Menu," then click "All Programs" and locate the "Access IBM" program group.
  • 5 Click "Thinkpad Configuration" and click "LCD" to open the brightness control dialog. Select the brightness from the drop-down menu and click "OK."
  • 6 Click the red "Exit" button in the upper-right corner of the Configuration utility to close it.
Read more: How to Adjust the Brightness on an IBM ThinkPad Display ' eHow.com http://www.ehow.com/how_5818403_adjust-brightness-ibm-thinkpad-display.html#ixzz277iQ4g48
Sep 11, 2012 | IBM ThinkPad G41 Notebook
Brighten display screen
Normally, on the keyboard of your netbook, there is a "Fn" key next to the bottom left "Ctrl" key.
after you finish booting up and have the screen veiw, press and hold the "Fn" key, then at the top there are a row of "F' keys, usually the F6 key is the key you would press to increase the brightness of your display. Each time you press the key the brightness should increase, if you press it pass the maximum brightness it will go back to a low brightness and then increase in brightness each time you press the "F6" key.
Remember, you have to hold down the "Fn" key as you press and release the "F6" key.
**** Luck
Aug 27, 2011 | Samsung NC10-14GW Notebook
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
How do I adjust the brightness? It's too much?
By following these steps u can adjust the brightness
Step 1
Press "Menu" on your LCD's display panel (usually below the screen). Various display options will be shown on the screen.
Step 2
Select brightness from the options. This is usually indicated by a sun. Use the "+" and "-" buttons on your display panel to increase or decrease brightness.
Step 3
Select contrast from the options. This is usually indicated by an oval half black and half white. Use the "+" and "-" buttons on your display panel to increase or decrease contrast.
Thank you
Mar 28, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Display of amilo L6825 has no brightness
please try increasing your display brightness by using the fucntion + brightness keys on your keypad several times
try replacing the battery for the battery problem
if u dont want to replace the battery then get the cells changed from an elec. shop
hope this solves your problem
Jul 10, 2009 | Computers & Internet
Need best settings for a Panasonic TH-50PZ85U
As with any display best settings are up to the user.
Some general rules about adjustment of a video display device apply
1. if the display is too bright you would decrease brightness by turning it down
2. if the display is too dark you would increase brightness by turning it up
If a display is too bright it will shorten it's life span so you want to keep the brightness down
Contrast must also be adjusted in the same manor
You should increase color saturation to suit your self
Increasing the color saturation too much will decrease the life of the display and look ugly
so you want to add just enough color to satisfy your taste.
Loch Hiam :-)
Sep 14, 2008 | Panasonic Televison & Video
HP LaserJet 5 Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
