Question about Ovens
Fan works but no heat - Ovens
  • Carl Knox
    Carl Knox Nov 17, 2014
    Thank you Ronald. The unit is a comfort zone electric heater, Model #cz2100c
  • Ronald Thompson Nov 17, 2014
    The question is listed in the "Stove" section. Is this a room heater?
    Master:
  • 560 Answers
Need a lot more information. Gas or electric? Make and model number, etc..
Posted on Nov 16, 2014
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
Double fan assisted oven, the fan is not working and no heat at all. Im assuming you dont get any heat at all if the fan is faulty? Can any one suggest any ideas?
Typically, the coils heat and the fan moves air/heat throughout the oven like Emergency Heat in a home furnace: 1st. check thermometer connections, 2. Look for reset button and reset...also, your electrical outlet, 3. make sure your coils are heating and if so look for faulty relays on your fan connections.
Feb 05, 2012 | Ovens
ZBF360X Electric Single Oven: fan oven working but no heat...
If the main oven fan is working but no heat it is most probably the ring element which is around the fan blade inside the oven.Check it is the element before you go and replace because there could also be an issue with the thermostat.Hope this helps.
Good Luck,
May 07, 2010 | Zanussi ZBF360X Electric Single Oven
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Cooling fan made loud noises then ovens stopped working.
If the fan is not working you need a new fan, if the fan is working but there is no heat you need a new heating element.
Dec 25, 2009 | DCS Ovens
Fan oven does not heat up. The fan works but oven doesn't reach temperature. It has been working fine
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element..
Dec 18, 2009 | Baumatic Ovens
The main oven dose not heat up the fan works and
The oven element will have failed due to the fan intermittently working.
You will\ need to replace both the element, and the fan motor, to ensure a satisfactory repair.
Please rate my solution.
Thanks.
Nov 15, 2009 | Ovens
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Oven is not heating...the convection fan blows, but no heat
If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
Plz rate this solution.
thanks.
Nov 08, 2008 | Bosch HBL 745 Stainless Steel Electric...
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Sep 04, 2007 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
