Samsung flate picture tube pin no 1&2,6&7,7&nc short.how do it release the short?
Board power supply ok,then check the tube is short.
circuitworld
  • 335 Answers
SOURCE: Samsung FP-T5084 No picture
For a 50 inch plasma....its worth it, in my opinion y-boards cost around $149 to $189
Posted on Nov 03, 2009
Testimonial: "Thank you. your feedback was appreciated. Theres a lot of value in getting an expert opinion whether to fix or not to fix."
  • 2318 Answers
SOURCE: Does anyone know which connector to plug into on power supply
Double check all the connections from the AC line and from the power supply to the other circuit boards. The connectors you are mentioning are identical as per the picture below.
If you need a new power supply, you can find one from this link.
Posted on Dec 04, 2009
Testimonial: "I have a few more questions that I would love to ask Jaime867. He produced a drawing of my circuit board within minutes and was a big help. Thanks"
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
  • 6 Answers
SOURCE: HPT5054 50 in. HDTV-Ready Plasma Television: Samsung HPT5054X/XAA - No picture, Sound OK, Have ...
It's not the x main. 90% of the time it's a y buffer that goes out. It's usually the top buffer. 3/4 of the time the buffer takes out the y main board too. You cannot just replace the y-main or buffer because it will just burn out the other within seconds. Also about 1/4 of the time it'll take out the top transformer on the power supply too. The solution? First disconnect the power to the y main board. turn on the television and check the voltages coming off of it. Careful it's high voltage 208V! Remember it's DC too. Then disconnect the buffers from the y main board. You can try powering the y-main up to see if the little LED lights up. This does not indicate it's working though but it'll tell you if it is possible to fix. The fixes for these boards is only for electronics guys. It usually involves replacing 1-3 capacitors and 1-4 FET's. Since a bad buffer can take out a good y main in seconds it's usually recommended that one replace all 3 boards at the same time. It's a $250 fix. How do I know all this? I've now repaired 5 of these televisions. I owned one and spent close to 600 repairing it. I bought misc parts and broken sets online for months before I had 2 different repair guys walk me through the process of repairing them. I had so much cash tied up in parts that I bought 3 more dead sets and repaired them to justify all my spending. I've never had an x board fail. I've had EVERY top buffer fail. I've had all but 1 y-mains fail. and 1 lower buffer fail. I've also had the y buffer fry it's top chip, blow a capacitor and FET on the y-main, and fry the top transformer on the power supply before my eyes. It only took 5 seconds. Replacement of the 3 y boards will almost always fix the sound but no picture problem. Hope this helps!
Posted on May 26, 2010
  • 8457 Answers
SOURCE: We have Samsung LCD model LN26A450C1D, which is
The tv Tuner board is dead,that the board,where the brocasting incomming signal cable connected into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Jul 22, 2010
Testimonial: "Thanks for quick response! I will try. "
Samsung UN55B7000WF RED LIGHT FLASHES CLCIKING SOUND BACKLIGHT FLASHES
Hi Ab7775,
1. Pl check st by 5 or 3.5 volts.
2. If it is ok, check power on 5 or 3.5 volts. Is power on voltage stable ? If this is pulsating with cliking sound, it is the main board. Otherwise it should be the power supply.
3. Please also check all the other voltage for short with ground.
You can also check the power supply board separately. Remove the connector going to main board. Put a 1k res between st by and power on pin. Plug in the ac, if all the voltage appear, your power supply is ok.
I am on line if possible please do this checking and let me know the result.
Good luck.
Aug 09, 2016 | Samsung Televison & Video
No picture,good sound
If everything else works - there is sound and high voltage (static on the screen) - but there is no picture (including no on-screen menus), this limits the likely area of problems is the video output circuitry or CRT filament connections. Check to see if the CRT filaments are glowing. If they are not glowing, check for bad soldering on the CRT neck board and around the flyback transformer. Where the picture is erratic - coming and going entirely or changing brightness suddenly, with power off, remove the picture tube socket (carefully!) and clean the pins with fine sandpaper and use contact cleaner on the socket. This source of bad connections can result in a variety of erratic symptoms. Check for bad solder connections on the CRT neck board
Jul 15, 2008 | Toshiba TP55H60 55" Rear Projection...
Amp keeps blowing fuses
Blowing fuses, was caused by many thing.
Short of rectifier,resistor,elco,tube heater,tube pin, and also trafo itself (primary or secondary winding). It must check step by step.
CAUTION :
THIS IS HIGH VOLTAGE AREA.
RISK OF ELECTRIC SHOCK THAT CAN KILL.
DON'T DO THIS IF YOU ARE NOT TECHNICIAN OR NOT FAMILIAR WITH VACUM TUBE CIRCUIT. THE CIRCUIT MAY STILL CONTAINS ELECTRIC SHOCK EVEN IF IF THE AMP IS NOT POWER PLUGGED.
The simple steps (see picture) are:
  1. Disconnect all connection from secondary of power trafo (PLV,PDCH,PACH and PHV).
    Power ON the amp. If fuse is not blowing,trafo is good.
  2. Power OFF the amp. Unplug the cord.
    Connect PLV1-PLV2-PLV3 (this are Bias voltage,+/-15VDC and Backlight PCB voltage) to power trafo.Power ON the amp. If fuse is not blowing,PLV circuit is good.If fuse blowing,there are parts is damage (dioda,elco,7815/7915,resistor) in this PLV circuit.
  3. If step 2 is good,go to next step.
    With PLV circuit stay connected,connect PDCH 1-2 and PACH 1-2 to power trafo. Power ON the amp.
    If fuse is not blowing,PDCH and PACH circuit is good and all tubes heater/filaments are lights after a few seconds.
    If fuse blowing,there are parts is damage (dioda,elco,tube heater pins) in this PDCH/PACH circuit.
  4. If step 3 is good,go to next step.
    With PLV,PDCH,PACH circuit stay connected,connect PHV 1-2 to power trafo.
    Power ON the amp. CAUTION: HIGH VOLTAGE AREA is ON.
    If fuse is not blowing,PHV circuit is good.
    If fuse blowing,there are parts is damage (dioda,elco,tube pins) in this PHV circuit.
Notes:
  • Steps had to be done sequentially from 1 to 4, not upside down.
  • If tube/heater pin is short,it can't be repair. The tube must be replacing.
  • PDCH circuit is voltage for V1-2-3-4 heater/filaments.
  • PACH circuit is voltage for V5-6-7 heater/filaments.
  • Always replace fuse with same type.
Oct 02, 2015 | Peavey 6505 Plus 120W Guitar Amp Head
Lightening strike on samsung TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 20, 2014 | Samsung UN55D7000 55 in. 3D LCD TV
Samsung Plasma won't power on
this is not a capacitor problem. set is only 18 months old - has something to do with x y sustain boards not allowing smps to power on the high voltages.
May 27, 2013 | Samsung Televison & Video
I have done all that you saud to do. Now the problem I have is the computer will not turn on at all. It's like the power has been turned off from inside the operating progam. I have windows 7, is this...
Phase 1
After power button pressed, computer will detect 5 components :
1. Power supply - OK (enough power)
2. Main-board - OK
3. Processor - OK
4. Memory - OK
5. Video Card / VGA - OK
== beep sound .. (1 time) or on the monitor, display appears BIOS ==
The characteristics of damage to power supply
1. Power supply fan does not spin
Video power supply fan not spinning
If the power supply fan is not spinning, the possible cause of damage to power supply. Solution, replace the power supply.
How to check the damage to power supply
2. Power supply is weak (resulting voltage power supply can not turn on the computer or the voltage is less)
The characteristics of damage to the processor
Normal fan without processor
Normal fan with processor
Based on experience, the possibility of damage processors is very small. To check for damage to the processor, install the processor to another computer (for comparison).
The characteristics of main-board damage
Because the new main-board, so the possibility of the main-board damage, very small. The characteristics of damage to the main-board, when the power button is pressed
1. Power supply fan not spinning
2. Processor fan is not spinning
3. Casing lamp is not lit
4. Main-board lamp does not light
The characteristics of the memory damage or dirty memory
1. The characteristics of normal memory, but installation is not correct or dirty
When the computer is turned on, the sound
Solution
Picture a
Release Memory
Picture b
Clean the memory slots with a brush
Picture c
Clean the gold layer memory with a pencil eraser
Picture d
Reinstall the memory correctly
The characteristics of damage to video cards
Solution, remove the video card, clean the gold layer with a pencil eraser.
I hope this information helps.
Oct 23, 2011 | Computers & Internet
Hello I have monitor samsung Smatron 7Ei the fault is that the picture is very dull with less contrast and bright. CRT heater volgate is ok. Secondly there is a heavy noice when i start it by power...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is ....picture becomes dull (less brightness & less contrast --- that noise is from EHT )........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily.....
Apr 18, 2011 | SAMTRON 55V 15" CRT Monitor
Samsung LN-T4665F when powered on picture is ok for 4 secs or less then screen goes black. Sound ok. I think the video is there just no back-light. Following some online advice I replaced the power-supply...
You more likely to need to backlight inverter boards, thpower supply should have 24vdc for the backlight inverter board, the 24vdc power supply get the trun on command from the controller board, that is what should have been checked first. So look for 24v or measure it directly on the inverter board connector pin. The invereter board also has a couple surface mounted fusesYou can get the inverter board here but make sure to match the number: http://www.shopjimmy.com/catalogsearch/result/index/?q=LN-T4665F+&limit=100
Dec 14, 2009 | Samsung LN-T4665F 46 in. LCD Television
Flashing power light
Check for these power supplies on the Sub deflection board first on the right side of the board there are two Connectors one is a 12 Pin connector CN803 From the top of the connector the wires should read;
30V
Gnd
Gnd
-30V
8.5 V
8.5 V
Gnd
Gnd
-8.5 V
Gnd
Gnd
13.5V
Next is the connector below that one which is a 10 pin connector CN802 they should read
11.7V
11.7V
N.C
Gnd
CTL
Gnd
34V
34V
Gnd
Gnd
Next is a 14 pin connector on the top left side of the board CN801 those should read
34V
34V
Gnd
Gnd
-8.5V
Gnd
8,5V
8.5V
Gnd
13.5
NC
12.5
12.5
Check those supplies and see if they are correct or if any are missing
Mar 09, 2009 | Samsung HCL4715W 47" Rear Projection...
Picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Dec 31, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
