Question about Dishwashers
Electrolux dishwasher fdb2310lcc1 flashing cl on display
Dishwasher starts fine. at the 63 min. mark the display flashes a CL. d.w. will not go past this point. continues to run. have to cut off manually. have tried to power down control board to see if it would reset. this did not work.will I have to replace both boards or replace the latch.contacts inside door latch look to be in good working order. what to do ?
  • Official Brand Answer
  • 4,342 Answers
Hello sandy miller, thanks for your post!
From my understanding your Electrolux dishwasher is flashing "CL". Typically, that stands for close door it could be an issue with the control panel, door latch, or door strike. I would recommend having a professional technician come out to properly diagnosis your dishwasher to avoid any unnecessary part purchases. Hope this helps. -Matt
Posted on Nov 19, 2014
  • 1003 Answers
SOURCE: unit won't start it just flashes CL (the door is closed)
REPLACE POWER CONTOL BOARD
Posted on Jan 18, 2008
aborcass
  • 2651 Answers
SOURCE: Replace Control Board?
control board sounds like alikly source, been known to have problems with their display boards as well though.does your unit have a display board on the front maybe 2in.x 3in. square inlay? or is ti just kinda all part of the push button leds
Posted on Feb 23, 2008
ginko
  • 19396 Answers
SOURCE: Electorlux dishwasher flashing CL
Error CL means that the child lock had been activated.
To unlock the machine you should put your finger up inside the handle and locate a slider switch, then push the switch to to the left side.
Posted on Oct 24, 2008
  • 159 Answers
SOURCE: Flashes "CL" to close door when it is closed and won't start
The "CL" is telling you that "Child Lock" is on.
Nothing will happen until it is turned off.Information on this is in the booklet that came with your dishwasher.
Posted on May 29, 2010
Daniel S
  • 4323 Answers
SOURCE: On the display is a flashing CL, according to the
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Posted on Nov 26, 2010
Why won't my dishwasher start?
Thank you for your inquiry, friend!
Based off the information you have provided "CL" stands for close door. If you continue to experience an issue with the "CL" error code I would recommend having a professional come out to your home and diagnose your appliance. "CL" could be a problem within your door switch or main control board. Hopefully this is helpful. -Matt
Aug 28, 2014 | Electrolux Dishwashers
Why does display flashes "cl"?
Good Afternoon Friend,
I understand the display is flashing "cl" on your Frigidaire dishwasher, model# GLD2450RD. The "cl" code you are seeing is stating to close your dishwasher door. The status indicator lights will also flash to indicate current cycle status. If the door is closed, try pushing it in just to make sure. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire GLD2450RD Built-in Dishwasher
CL trouble light flashing
If you reset the unit from the household circuit breaker and it doesn't change, then contact a professional to have the main control board repaired.
Aug 19, 2012 | Electrolux Frigidaire Professional Series...
Our dishwasher continuously flashes "CL"
Hi trrhodes,
I believe the CL you are getting means "Child Lock". Under normal circumstances there should be no activity at all on your machine.
Please do the following:
- On the Facial Panel (Where the buttons are located), look for 2 buttons marked together with a line, it should also have a face of a child somewhere on that line.
- Press both these buttons together for 3 - 5 seconds, this should reset the Child Lock.
Kind Regards :-)
Jacques
*If you found this solution helpful, please rate it
May 23, 2011 | Dishwashers
On the display is a flashing CL, according to the manual the latch is not closed. Tried several times to close the door and push the normal wash button. Nothing happens, only the CL light is on. Tried...
Hi
Daniel
Nov 26, 2010 | Frigidaire PLD2855RFC Dishwasher
The door switch has failed. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the process will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
May 21, 2010 | Frigidaire Dishwashers
How do I cancel the child lock on dishlex dishwasher 2005 model
Hi, ours is the 403 model but im guessing it will be the same operation for ur 302 mod, In prog selection mode press and hold start for 5 secs, indicator lights should flash then CL wiil appear to indicate child lock on........ in this mode by pressing and holding any button for 5secs will temporarily give you access to program setting and control an will auto reactivate after 15 secs, ..... too disengage permanently firstly you must temp unlock as above then press and hold start for 5 secs, CL should display with a long beep to indicate CL is off..
Cheers Jeff QLD
Apr 21, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Frigidaire pld3460rdc1 the dishwasher flashed CL when the door is closed.
The CL is letting you know that the door was closed. If it continues to show CL it means you need to close and latch before the cycle will run. If it just flashes your okay.
Mar 10, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Oct 24, 2008 | Frigidaire 24 in. FDB2321REC Stainless...
Dishwashers Logo
277 people viewed this question
Top Dishwashers Experts
