Question about Whirlpool duet Washing Machines
My whirl pool duet sport washer wont start or unlock. there is no error code displayed. it comes on you pres start and it stays that way, not doing anything. does anyone have answer?
It comes on, i press start and it doesn't do anything.there is a sound like it want s to start but it doesn't
    Master:
  • 560 Answers
Unplug the unit for a few minutes to see if it resets.
Posted on Nov 16, 2014
4 Suggested Answers
  • 240 Answers
SOURCE: Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Posted on May 02, 2009
  • 107 Answers
SOURCE: whirl pool duet washer, will not drain error code
F02 means long drain time exceeded 8 minutes. The problem is most likely a clogged Filter screen. Remove lower front panel you will see a white filter before the pump assembly. Place a towel or a tray under the filter assembly. Open the filter and remove any blockage from the filter. The other could be a kinked hose but it is usually a blocked filter.
Posted on Nov 01, 2009
rickead1
  • 1998 Answers
SOURCE: i have a whirl pool duet washer with error code
try this:
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Posted on Apr 29, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Whirl pool duet sport the door is locked and it wont let me open it
You can remove the lower panel. Have to drain the hose - water rushes out...and then reach up insie the washer where the door latch is, there will be a ring that you can pull on that releases the lock.. Got that much done...but the beeping continues... Be sure to unplug the machine first!
Nov 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirl Pool Duet Sport WFW8300SW00 leaks water from the detergent drawer after about 30 seconds of water running...please help!!
the water pressure is to high turn the tap down and wind the front feet right up. very common the water comes in to fast and splashes over the tray & down the front panel that will rust. replaced over 100 front panels still under warranty due to this problem.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer with an f du error code. do you know what that means
That's a door unlock error. The machine will display that code when after trying 6 times to unlock the door, it still won't unlock.
Oct 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirl pool duet washer with error code
try this:
Or
Apr 28, 2010 | Washing Machines
Whirl pool duet washer, will not drain error code f 02. When drai hose is lower to floor water comes out slow
Nov 01, 2009 | Whirlpool Washing Machines
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
