Question about Bose Audio Players & Recorders
AV 321 Media Center has a hum. Can stop momentarily with disc drawer open? I think I will need to send this in??
Made in Ireland. serial# 027752352570466AZ. Power to 120v AC
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 166 Answers
Check for faulty capacitors inside unit
Posted on Dec 01, 2014
snakehead
  • 1074 Answers
SOURCE: Stuck Disc
I sould hope by now you have already taken your set to be repair your gears inside are either broken or striped .blessing from belize goodluck.
Posted on Mar 23, 2007
Zenodilodon
  • 145 Answers
SOURCE: Media Center disc tray will not open.
This is a common problem with optical drives. There is a small band/pulley inside that connects the ejection motor to the gear action, This reduces stress on the gears and it helps with smoother motion while running. The issue comes in where the band/pulley becomes worn out and loosens a bit and this causes a reduction in friction against the spindle the band/pulley is on. You may need to get a new band/pulley for your optical drives ejection system in your media center. The whirring sound you happen to hear it the ejection motor spinning but its not catching on the band/pulley.
Posted on Mar 12, 2010
Testimonial: "Thank you so much. Your explanation makes sense. Now we know what needs to be checked out. "
SOURCE: Disc drawer won't open and sometimes doesn't power off
The disc drawer is broken, there are motors that open the drawer (what you hear when turned on and off) and it must of got damaged by a cd or some other way. If you want to open it, pry it open with your fingers or screwdriver. I had to take the 5 cd holders out to see the problem and there was a cd that jammed everything. But you might not have that, take a look. And the "bye bye" thing is normal but not if it wont go off at all.
Posted on Jun 23, 2010
ib_yang
  • 1098 Answers
SOURCE: Bose 321 media center dvd
Hi.
Please clean the lens with a dvd cleaner kit. The kit contain a dvd and a liquid cleaner. Use first the dvd cleaner and if the problem persists, use the liquid cleaner.
Thank you for using Fixya!
Posted on Nov 29, 2010
electricdime
  • 434 Answers
SOURCE: My Bose AV 321 Media Center works except for the
Try to clean the DVD drive lens with a Lens cleaner CD. These are available at your local department stores such as Kmart. It looks like a CD but it has a brush attached to it. Just insert the cleaning CD and let it cycle a couple of time and then remove it. If this does not work then your DVD laser could be going bad.
Posted on Dec 02, 2010
Playing fine but when is off is still plying
Control buttons on the Media Center may need to be replace by a Bose service Technician.
Sep 26, 2015 | Bose Av3-2-1 Series Ii Media Center...
Disc tray will not open?
There could be a disc jammed in the tray. The humming sound is the tray open/close motor trying to work
Jan 16, 2013 | Bose Av3-2-1 Series Ii Media Center...
DVD/CD door stuck on Bose 3 2 1
On the 321 systems turn off the power and unplug the power cord from the bass module. Wait 5 minutes and plug it back in. Then, simply hit the "stop/eject" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
Thanks to Matthew O;Neil for the the tip,...Italo
On a Lifestyle system with a tray that won't open, try this: Turn off the power to the system and unplug the power cord to the back of the media center itself. Wait 5 minutes and plug it back in. Then, simply hit the "open/close" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
If this does not work, then call Bose when you are home with the system at 800-367-4008.
Nov 05, 2008 | Bose (321GS) System
Bose Model 321
the bose will not play anew dvd comes up need paasword
Aug 08, 2008 | Bose Wave Radio
DVD Tracking problem
Contact Bose with the serial number from your media centre. they'll send you a software update disc free of charge which WILL solve this problem
Jan 15, 2008 | Bose 3·2·1 II System
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
HUSBAND DESTROYING 321 SYSTEM LOL
Turn the switch off on the rear of the Acoustimass module (subwoofer); wait 30seconds; turn on, system shows "Bose 321"; as soon as this disappears, press "Open/Close" button. If the drive hasn't failed, the drawer will open. It's worth contacting Bose to check the system software is up to date - if it isn't, they'll send an update disc free of charge.
If this doesn't give the disc back, contact Bose for a repair - it could have happened if the disc was accidentally put in upside down. Otherwise, the drive may have failed - this could happen to any make of product, no matter what the cost or make, that's why you have a warranty.
Nov 20, 2007 | Bose 3·2·1 II System
66 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
