Question about Hotpoint Dishwashers
Dishwasher has no power and water is still at the bottom. What's the parolem
I started the dishwasher on a cycle. It's now stopped no power and water is in the bottom of the dishwasher. What is the problem
    Scholar:
  • 120 Answers
Could be something as simple as your circuit breaker which is usually seperate from other breakers, so always look for the easiest solution first. If you have no lights, if your dishwasher is like most with indicators for cycle selection, then it is a power issue. If no noise at all, sounds like no power.
Good luck,
Asthma-Free-Home.com
Posted on Nov 16, 2014
  • Mike Sullivan
    Mike Sullivan Nov 25, 2014
    If it is not circuit breaker, then check to see if water is in bottom of tub, if so, as in, it is not draining, then it will not allow more water to enter with next cycle. If this is the case, siphon out water if you have a wet vac, or simply use a turkey baster to syphon out water, once level is down, the protective float switch shoudl allow dishwasher to turn back on. If not, it could be control panel issue, and as mentioned, if you have cycle LED light inicators, and they are off, then it may be the problem. If it does start back up, then you have a clog, common issue with almost all dishwashers. It is easy to clean, just pull off bottom mesh screen and you should see clog at the drain port, Usually it is obvious, but if not, try using wet vac at port to pull out food particles. Good luck, ORGANIC-DIRECT.com
  • 3422 Answers
SOURCE: Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Posted on Jan 29, 2008
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
  • 6 Answers
SOURCE: DISHWASHER IS LEAKING A LOT OF WATER
Draing Problems:
To fix your draining problem you need to check the air gap(if you have one) , check if there is voltage going to your drain pump during the draining cycle. If there is voltage coming to your water pump and the dishwasher is still not draining then the problem could be a clogged drain hose, a clogged air gap or a bad drain pump. if there is no voltage detedcted on the drain pump during the drain cycle, then it could be a water level-switch/solonioed , wiring, or a control board problem.
Good luck.
Mr Engineer
Posted on Aug 11, 2008
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
buddymcl777
  • 67 Answers
SOURCE: Water in bottom of dishwasher
The emptying valve is probably partially blocked with a piece of debris or bone. It can be cleared manually usually if you can get at it with a pair of needle nose pliers or tweezers.
Posted on May 03, 2009
Goodluck,
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
What can cause and lg dishwasher to not fill water and stop and show le code
Please try the plain VINEGAR in the bottom of your dishwasher. It cleans out the pipes. When you start the machine it automatically starts to drain whatever water has been left from previous cycle. When this cannot happen, due to blocked outlet pipe, it will not precede with the wash cycle. Adding the vinegar, leaving it a few hours, or overnight (hey, I left it for a week one of those times!), it is enough to liquify any heavy fats in that pipe...enough to start the cycle and the normal draining gets reinstated.Hope this helps you, it is such a pain to go & choose another dishwasher to fit into the space allowed & that has all the functions you need. This 'fix' cures all my dishwasher blues! Havagreatday!
Sep 21, 2014 | LG LDF6810ST Stainless Steel Built-in...
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
Dishwasher not completing cycles
see this causes and fix it. God bless you
If the cycle doesn't complete, check these:Water-heating cycleTimerWater-heating cycleMany dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. TimerTimers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. 9_25_2012_6_48_09_am.jpg
Sep 24, 2012 | Dishwashers
All my lights on the front of the dishwasher are blinking at me & stops running after 3 minutes into the cycle. What is the cause of this & of course, I am two months past my warranty. Help.
If three lights are blinking (normal, heavy, quick)... I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
Jan 27, 2012 | Samsung DMT300RFW Builtin Dishwasher
Power point dishwasher - not washing dishes
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | Dishwashers
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Nov 02, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Dishwashers Logo
64 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
