How can u tell if your heatpump is going out - Heating & Cooling
    New Friend:
  • 101 Answers
Overheating, making noises like a bunch of marble loss inside of it, not maintaining temp.
Posted on Nov 26, 2014
WIREIN HEAT PUMP FOR COOLING ONLY
You must wire Orange from heatpump low voltage wire to gether with your yellow s and you must have a common wire usealy common comeing out of heatpump should be black color than what ever color wire you have connected to common at t-stat and airhandler connect that to black wire at heatpump. To make sure blablack I s common follow wire up to board and it will be connected to C terminal now you will have ac all time. If you want heat remve Orange wire from reds at heatpump and you will get heat only.note when doing your wireing make sure high voltage is off to heatpump and airhandler hope this helps
Feb 27, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
How can I turn off the freeze protection this units are running in electric heat only is like 32 out side
32 deg s out strip heat will run and if you remove defrost your unit is going to freeze up. When that cold assuming you have a heatpump strip heat is needed .is it a threw wall heatpump?
Feb 18, 2015 | Heating & Cooling
My gas furnace and heat pump runs at the same time???
its likely the outside control unit board its supposed to only kick on gas only when the temp is at freezing..
or
the inside thermostat is not selected for heat pump, open it an look at the jumper / switch.
or just replace the thermostat , then return it saying you couldnt figure it out. :P
there are a lot more variables here after that you cant know how to check.
Nov 05, 2014 | Honeywell VisionPRO 8000 Programmable...
The fan on the AquaCal heatpump stays on when the water pumps turn off.
check pressure switch should work when pump on then off when pump off if ok bad control board
Dec 28, 2017 | Aquacal Heat Pump Pool Heater 120
Ok. heatpump change out, 17 year old rheem to adp air handler and weather king heatpump 3 ton outdoor. The wiring from the thermostat is killing me in the attic. I got the cooling side to work, and also...
If your heat strips come on with out the fan then you need to change the settings on the tstat for electric heat rather than gas. Or change the setting to where the tstat controls the fan. But, sounds to me like you have your tstat miswired. Did you wire in the reversing valve? Is the valve energized in heating or cooling? Tell me what colors land where at all three locations.
Jun 10, 2017 | Heating & Cooling
2005 s type jag a/c quit blowing cold air suddenly .just blows hot at any setting or on auto
hi,is this a heatpump or a ac unit only...if a heatpump ,there is a valve that switchs from heat tocool mode...go outside with unit running..put hand on big copper line,if it is hot your in heat mode..if cold your in cool mode....possible stuck change over valve if a heatpump...hope this helps...good luck...michael doctor airr appl.repair..843-384-8474...if need more assitance..call..its free...good luck
Mar 26, 2010 | Heating & Cooling
I Have a honeywell RTH2410 Thermostat I wired it without the blue wire which used to go to X on my old thermostat. Now it comes on with aux heat all the time and I have a Heat Pump. How can I fix this?
What was the old thermostat labels and the wire colors that went to them?
The typical heatpump wiring Terminals are:
R = Red = Hot side of Transformer
C-B-X = Common side of transformer Depending on brand of heatpump
Y = Yellow = Cooling Contactor
G = Green = Furnace Blower
O = Orange Reversing Valve Energize to Cool
B = Blue Reversing Energise to Heat Depending on brand of heatpump.
W2 = White = Auxiliary Heat
You need to be sure where each wire comes from when you connect them to the new thermostat.
The best way to do that is to go to the furnace and see where they are connected. R-Y-G are probably correct, you need to see where the Blue wire comes from and determine what the X terminal was on the old thermostat.
Dec 29, 2009 | Honeywell Electronic Programmable...
Heatpump A/C not working
First,Turn on the heat cycle (Not Emergency)and see if the outside unit come on,If not,and you don't have low voltage outside,Go to the inside unit and test the transformer,If you have low voltage from the transformer but not outside,It is the low voltage wires,If you don't have low voltage from the transformer,It's the transformer.If you have low voltage outside when in heat mode,but the unit won't come on,It's the contactor.Let me know if you need more help.
Please take time to rate this fixya
May 13, 2009 | Goodman CLQ36AR49 Air Conditioner
AC/Heatpump units cycle numerous times blowing ambient air.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
Disconnecting green wire from thermostate did allow furnace to run properly but every time I want to switch back to heatpump I must reconnect green wire again.Here is how wires are connected to...
Try this.
A T-stat.
Orange = O
Red = R (with existing jumper)
Black = C
Yellow = Y
White =W1 (Or AUG)
Green =G
At airhandler/furnace.
Green = blower wire (usually green, double check with schematic)
(Green should not go to the HP.)
Orange to HP
Red to red and to HP
black to blue (or C) and to HP
White to W
Yellow to HP. (It may also go to a "float switch" if installed. but that will just be a safety switch on the drain pan in case the line clogs and it overflows.)
The green is typically used for the blower motor. (furnace only)
The orange is used for the reversing valve. (changes from AC to heat, is located in the HP only)
Blue is typically used for common (or "C") but they may have changed it to black due to a broken wire, or other problems.
The only wires going to the HP should be
Red
Blue/black
orange
yellow
Orange should not be going to the furnace at all.
HP wiring should be
Orange to orange or O
Red to R or red
Blue/black to blue or C
Yellow to Y
Dec 09, 2008 | Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
