Question about Kurio 7" Tablet with 4GB Memory for Families and Kids
My kurio keyboard is not woring correctly, how do I fix it?
Push a key on keyboard and it types a bunch of different things instead.
Wheres the keyboard on kurio gone?
you have to erase and restall Kurio true The android settings. thats an update solution.
Jan 12, 2013 | Techno Source Kurio Kids Tablet With...
Wireless Keyboard HP RK713A not typing correctly
Try going to Device Manager. Right click on the Keyboard and choose Properties. Click on Update Driver as it might find something (let it look online also). Reboot the computer. If that doesn't work, go to Device Manager, right click on the keyboard, choose Uninstall, and reboot the computer. When the computer starts up and sees the keyboard and loads a driver(s) for it, it might fix it. Good luck.
Jan 15, 2018 | HP Computers & Internet
How to fix the at button on a keyboard
Usually you cannot "Fix" a keyboard as it's in the way they are made, if faulty the only option is replacement. However it may simply be a codepage thing make sure you have the correct keyboard selected, usually US, as other types will substitute other characters instead of the @ symbol?
Oct 13, 2011 | Microsoft Wireless Optical Desktop 5000...
When typing using laptop keyboard pressing the letters u,i,o,p,j,k,l,m numbers 4561230 instead appear pressing the numlock keys or combination of shift key does not fix the problem
simple keypad contain problem,check it ask the place of purchase,because inside the connection may be changed or the layer of keypad bottom always touched the point other thing the keypad bottom a layer is not seated correctly...
Dec 24, 2010 | Computers & Internet
My keyboard isn't typing most keys
I would reset the bios by using the jumper in the cabinet. Then make sure you have the correct type of keyboard selected and if all of that does not solve the issue, replace the keyboard.
Aug 23, 2009 | Lenovo Keyboard
Logitech keyboard,s keys are not working
Modern keypads arent as great as old ones where each key had its own switch and you could just open and fix it. new keypads have everything interconnected inside them. The only thing to do is buy a replacement, But if you really love this one keypad, you could try and clean it out with a blower and make sure the keys that are failing arent failing because of dust or unwanted debri.
Jun 20, 2009 | Logitech Keyboards&Mouses: Delux Plus...
Keyboard Doesn't Type Correctly
you probably have something (such as food)stuck under your keys, so when you push down it pushes the board further, so it hits multiple keys. otherwise, you bent your keyboard and need to bring it to a store and get it fixed
Jun 04, 2009 | Logitech Wireless Access Duo Optical...
Keyboard problem
Did it originally have a Japanese Keyboard? Maybe the Keyboard you installed is bad or the numlock or some other function key is enabled???
Nov 27, 2007 | Toshiba Satellite 1715XCDS Notebook
Kurio 7" Tablet with 4GB Memory for Families and Kids Logo
142 people viewed this question
Top Kurio Home Experts
john h
Tom Chichester
Are you a Kurio Home Expert? Answer questions, earn points and help others
