Question about American Standard Plumbing
How to replace washer cartridge in bathroom tap
Cant turn of water keeps on
  • 352 Answers
Turn the faucet to the closed position. Turn off the water to the faucet. Remove the handle. The screw that holds it on may be under a plastic cover. Unscrew the large nut. Remove the cartridge. Put the new cartridge in the closed position. Look at the old cartridge and be sure the new one matches the old one. Insert the cartridge. Replace the nut and tighten. Replace the handle. Turn on the water.
Posted on Nov 30, 2014
3 Suggested Answers
  • 34 Answers
SOURCE: water keeps running even when turned of to the house
No problem on this one. Turn of the valve to the toliet just above the floor next to or behind the toilet. Go turn on a outside faucet. Is there still pressure? Wait a minute if it seems like there is still pressure to let the line pressure go down, what this is just water in the line left over. If the water stops on the outside faucet then the water is off. If you do not have a outside faucet then use a tub or a sink faucet. (if it does not stop then see part 2)....Keeping the toilet valve off remove the supply line from the toilet where it connects. This sould be the larger end. Is it is a flex line this should make it easyer. If it is a hard line like copper tubing, stop and go to the hardware store and a buy a flex supply line. This will make your job a lot easyer. After you remove the part of the line that connects to the bottom of the toilet then find a bucket place the end of the line you removed from the toilet into the bucket ( you may have to place the bucket at an angel to do this. Now turn the water valve at the wall for the toiel back on and drain the line. You may have to empty the bucket a few time but the line sould drain out.
( Part 2) If the water to the house is still on you need to go to the water meter and turn of the curb stop, this is going to be the valve inside the meter box ( if you do not have a well) and are on public water. You will need a cresent wrench, sometimes these valves can be hard to turn so you may have to use a little force. If you are on a well the you need to find the valve in you well house and turn it off. If you need more help or this did not solve this problem the repost and I will check back in a little while.
Posted on Feb 08, 2009
SOURCE: I have a Grohe bathroom sink fixture (not sure
need to replace washer how to pull stem out to get to washer
Posted on Nov 24, 2012
Replacing eurobath bathroom tap
If you want to remove the tap for replacing washer then you should detach tap by looses it's screw. You can also hire a professional to do this work easily.
Jan 02, 2013 | Home
How do i fix leaking tap, it is not the washer type tap
You either need washers, a control cartridge or a seal kit, depending on the brand.
Jan 31, 2012 | Home
The rinnai 20 Infinity is perfect but have recently noted a problem. I found the basin hot water tap in the bathroom begin dripping only when the kitchen hot water tap is turned on. I don't know how...
Some taps are designed to release excess pressure but it could just be a dodgy tap washer that leaks when the pressure of hot water in pipe work builds. Change the tap washer in your tap, see if it fixes it, if not it's just the design.
Jul 02, 2011 | Water Heaters
When hot water is turned on the pipes make this vibrating sound. i have two sinks in my bathroom. When I turn the hot water on on sink 2 the pipes vibrate. Sink 1 is fine.
There is a loose washer in the faucet...this flaps as the water goes through it and makes the vibration...
You either need to replace the faucet or the cartridge (washer) in the faucet that valves the water...
This will stop that vibration and hammering sound
heatman101
Aug 22, 2010 | Kohler Plumbing
Very loww water pressure when taking a shower, I've changed the shower head,but, water pressure continues to be low. I've got moderate water pressure in the face bowl in the bathroom and good to moderate...
It could be debris in the cartridge at the tap itself. Whther 2 cartidges or 1 , it wouldn't be uncommon for those to clog up as well, and it really doesn't take much to cause a decrease in flow. Turn water off to tap(s) and remove handles, then cartridges in behind with proper socket or wrench and inspect for debris inside hole cartridge came out of, as well as the cartridge.
Dec 29, 2009 | Home
Change tap washer
hi first turn of your water to the tap open the taps to empty water your mixer tap con now be pushed down and twisted to come out
Nov 10, 2009 | Home
No cold water from bathroom tap
Sounds like you need to replace your shower valve, especially if this is the only fixture in the house being affected. You could try to replace the cold water cartridge first. Hope this helps
Jul 06, 2009 | American Terminal Etc B 100 T Taps
Installation of washer/dryer combo with no taps available
hello you can buy washing machine taps that screw on to the main water pipe. what to do is turn your water supply off at the stopcock and get the your new tap and clamp it on to the water pipe and tighten it up.it will make a hole into the pipe and to the same with the other 1 when your done turn water supply on make sure you have no leaks good luck
shaun
Mar 28, 2009 | Haier HWD1000
Plumbing Logo
175 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Mike
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
