Question about Montgomery Ward Sewing Machines
Where i can buy this part?
I have a sewing machine model uhtj1276 i need part that i do not know what its called- metal ring with plastic piece that moves bobbin, this part is located under the bobbin on the shaft, plastic part cracked.
    Master:
  • 560 Answers
Take a photo of the part along with the make and model of the unit to a local sewing machine place.
Or check online to see if the manufacturer has a parts diagram and listing.
Posted on Nov 16, 2014
NEED DIAGRAM FOR THREADING A KENMORE 158.19802 SEWING MACHINE
The threading on these Kenmores is pretty consistent from model to model (good machine, by the way!). Be sure to ALWAYS raise the presser foot when threading the upper thread--insures the thread seats in the tension disk.
14 Kenmore Top Threading FREE SAMPLE
How to thread Sears Kenmore Sewing Machine 158 12270 158
By the way, the metal projection at the top left of the machine regulates the amount of pressure the presser foot applies to the fabric and feed dogs. Push it down to increase the pressure--important when changing types & weights of fabric. To release the pressure, push down on the ring that surrounds the center projection piece. AND, when finished sewing, it is a "great" idea to always release this pressure button before walking away from the machine. Leaving it pushed down over a long period of time will eventually compress the spring and the pressure will no longer work like it should. Also, be sure to clean and oil your older Kenmore regularly. Use only fresh, good quality sewing machine oil or liquid Tri-Flow Synthetic Lube. Open the top, side, and bobbin area. Gently rotate or rock the handwheel and apply only 1-2 drops of oil every place metal rubs against metal. You can also lube the specific lever and dial mechanisms to keep them operating freely. Do NOT oil belts or plastic gears/parts. Doing this regularly, ie every 40-60 hours of sewing time, will keep your machine running smoothly and quietly and preserve the motor from over stress and possible burn-out.
Dec 31, 2016 | Kenmore Sewing Machines
HOW TO CHANGE THE OLD BELT ON THIS MACHINE
The one thing on a sewing machine that needs the most repair work is the belt. The sewing machine belt is a piece of rubber that makes the wheel turn and the needle go up and down in a sewing motion. If the belt is in bad shape, the sewing machine will not work. Sometimes while sewing you may notice a burnt rubber smell. When you smell this, you know it is time to change the belt. Changing a sewing machine belt is fairly easy; just make sure you have the proper belt.
Dec 08, 2015 | Sewing Machines
I'm not sure about what your explaining, If the bobbin drops into this part (plastic) it is called the bobbin carrier. If you take the carrier out and you see a metal hook going around and circles or bobbing back and forth this is called the hook. The bobbin carrier is most likely what you need. Try this web, they usually have everything: http://www.sewingpartsonline.com/instruction-book-janome-and-newhome-8000.aspx
Nov 16, 2014 | Montgomery Ward Sewing Machines
I dont know what the part is called but its like a plastic cog that fits on the end of the long metal shaft near the spool
Would help if you have a make and model of your machine. But call or email some sewing machine parts places... there are many online.
Feb 25, 2013 | Sewing Machines
MY BOBBIN CASE FELL OUT TWO PIECES HOW DO I PUT IT BACK TOGETHER
I assume you actually mean the metal ring that holds the small round case that the bobbin itself sits in. There are usually two arms that swing in to hold that larger metal ring in place and then there is a plastic and metal piece that sit behind the large metal ring. fit the plastic piece that may look somewhat like a scoop next to the metal piece that usually has the post the the bobbin fits onto and has a quite sharp tooth on it. The metal ring then goes on to hold those two pieces in place and the two arms swing in to hold the metal ring into place. The bobbin or bobbin case now can be put back in. Hint on metal ring placement: they almost always have a notch that goes at the very top where the arm on the bobbin case sits in when it is in place. You may find it easiest to do this with the machine laying on its back so you don't have to have 4 hands to hold everything in place while putting everything back in.
Feb 22, 2011 | New Home HF-2022
Plastic casing around the bobbin
That piece is a sweep that helps keep the hook clean. It is not necessary for the machine to use, I have thrown away many of them. If you can get your hook put back in you should be ready to go.
good luck!
Jan 30, 2009 | Necchi 3101 Mechanical Sewing Machine
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Bobbin thread getting caught
Check your Instruction manual - if you have taken the bobbin case apart to clean it, the shuttle must be reinserted with the little tab pressing against the piece you mention. It is under page 45 - "Caring for your machine" in my book. I missed it the first time I cleaned and oild mine.
Mar 21, 2008 | Singer 3962 Mechanical Sewing Machine
Singer futura model 900 sewing machine
Recently had same problem. Underneath the bobbin area on the bottom of the machine is a small white plastic piece that resembles a fan. Singer calls this the bobbin cam actuator. It is usually cracked along the sleeve that fits over the metal pin, bar? This is the mechanism that lifts the bobbin when it is wound. When its broken it can't lift the bobbin to be wound properly.
Nov 04, 2007 | Sewing Machines
Sewing Machines Logo
57 people viewed this question
Top Montgomery Ward Sewing Machines Experts
D. E. Hev
DavidinClt
Level 1 Expert
Are you a Montgomery Ward Sewing Machine Expert? Answer questions, earn points and help others
