Question about Home Security
<!-- from fixya rte -->How to order replacement pushbutton - Home Security
    Master:
  • 560 Answers
Contact the manufacturer.
Posted on Nov 16, 2014
How do i prevent accidental trunk opening on 2009 camry
To prevent accidental opening of the trunk caused by an accidental pressing of the "OPEN TRUNK" button on your keyfob, you can pull the cover that hides the wiring harness on the trunk (you can buy replacement plastic retaining tabs at an auto parts store if you break one) and look for the wiring harness. I cut the wire controlling the electronic trunk solenoid and soldered in momentary pushbutton that goes to the outside of the trunk. To open the trunk, I have to depress the pushbutton on the trunk and then press the "OPEN TRUNK" button on my keyfob. I also soldered in a bypass switch in parallel with the pushbutton in case I want to disable the extra security I get by having a pushbutton. It will cost you about $15 in parts (get a high quality, weather rated pushbutton) and about 3 hours of time.
Feb 12, 2012 | 2009 Toyota Camry
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
Jul 02, 2011 | 2003 Pontiac Sunfire
I installed Leviton 2591 switch (to replace a broken one). The switch is supposed to be "off" when untouched and "on" when held pressed down. My switch is behaving opposite. It is...
You have installed a "Normally Closed" (NC) pushbutton. You should replace it with a "Normally Open" (NO) pushbutton, sometimes called a "momentary" switch.
Jun 21, 2011 | Leviton Single Pole Pushbutton Switch -...
I bought a house with a Night Sentry Solid State Timer model # EJ341 and have no instructions on setting or programming the unit.
rapid Programming.
1. Move control lever to OFFCLEAR for at least 5 seconds
• red indicator light goes off
• all time settings are
erased.
2. Move control lever to ON.
• red indicator light will start
flashing.
3. Check a clock; then turn pushbutton time dial clockwise at least one click.
• stop at the half hour nearest to present time (note
AM or PM).
Note: When turning pushbutton time dial, do NOT
accidentally PRESS at the same time.
4. Press pushbutton time dial once to enter present time.
• red indicator light goes off (present time has been
recorded).
5. Turn pushbutton time dial clockwise to desired
ON time.
• red indicator light blinks with each click.
6. Press pushbutton to enter ON time.
• controlled light(s) will turn on.
7. Turn pushbutton time dial clockwise to desired
OFF time.
8. Press pushbutton time dial to enter OFF time.
• controlled light(s) turn off.
9. Repeat 5-8 for other on/off times.
10.Turn pushbutton time dial for at least 2 more turns
from the first ON time to complete this program
• red indicator light will turn on and stay on (steady
light means timer is in automatic).
Note: Pushbutton time dial does not turn
automatically after setting to indicate time of day
Aug 22, 2010 | Hardware & Accessories
I have a Samsung TV, about 12 years old and it has just started turning off or on when you try to raise or lower the volume, any suggestions? I have no other problems with the set if this can be fixed for...
I had the same problem with a Sony TV my problem was simply corroded pushbuttons on the front of the TV? I would try cleaning the pushbuttons or replacing them.
Aug 20, 2010 | Televison & Video
I need instructions to turn off service light in 1995 850 volvo
Keep pen and paper ready, as you might have to write down error-codes as you want to do this.
Turn ignition OFF
open the lids of the diagnostic sockets situated in front of the enginecompartment (by the fillercap for the windshieldwasherfluid)
Put the socket with a short lead on in the hole marked "1" on module A
Turn ignition ON
press the pushbutton on the top for about 1 second and WAIT.
The LED will blink in a sequence that indicates if there is any problems that need to be solved.
The led will blink 1 to 5 times, have a pause, blink 1-5 times , have a pause and blink 1-5 times.
Write down the sequence as you count the blinking. eg: 1-3-1
When one sequence is finished, you press the pushbutton again, and read the next code.
Repeat this until you read the first code again.
If the first code reads 1-1-1, all is OK and you can proceed.
After this you can reset the servicelamp:
Leave the connector in socket 1 on modula A.
Turn ignition OFF
Turn ignition ON again
Press the pushbutton for 5 seconds. Be patient.
Release the pushbutton and wait about three seconds, then the LED starts to blink rapidly
press the pushbutton for 5 seconds again and release it.
Turn the ignition OFF
Remove the connector from the socket, replace the lids and put the connector back in its rest.
Turn on ignition and start engine, the service lamp should not be on.
Any error-codes? Refeer to a Volvo-dealer.
Jun 30, 2009 | 1995 Volvo 850
How to remove main pushbutton switch from asko d1716 dishwasher
Hi I read your enquiry of how to remove the pushbutton swith.
You have to open the door, and remove the back panel of the door to release the front protecting cover panel. This is the only way to release the pushbutton. Do not forget to disconect the mains to avoid an electric shock.
Hope I have been of help
Nevd Fixya.
Feb 15, 2009 | Asko D1716 Built-in Dishwasher
OSD Main Menu
because of moiture pushbutton switch were conduct there for replace pushbutton switch and see result
Aug 15, 2008 | HP Pavilion F1703 17" LCD Monitor
35GT740 television
Have you tried to unplug the TV set for a half hour or so? If not see if that helps reset the set. If that does not work, make sure that none of the front panel channels buttons on the front of the TV set is not pushed in and stuck. Or if all this is checked and the TV set still scrolls, there is a problem in the remote sensor, or the front panel board will need to be replaced. Good Luck
Sep 10, 2007 | RCA 24V511T 24" TV
Menu wont work, continuos channel search
Usually, this means that something has spilled into the front of the set and has contaminated the pushbuttons. If one of the channel pushbuttons has fluid in it, the set will just sit there searching for channels and will not respond to any other commands. The computer thinks you are pushing the channel button and responds accordingly. When you push another button the computer does nothing because it thinks that you are pressing 2 buttons at the same time. The board should be cleaned and any contaminated pushbuttons replaced by a qualified tech.
Aug 23, 2007 | RCA F36715 36" TV
Home Security Logo
49 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
