Question about Montgomery Ward Sewing Machines
I have a sewing machine model uhtj1276 i need part that i do not know what its called- metal ring with plastic piece that moves bobbin, this part is located under the bobbin on the shaft, plastic part
I have a sewing machine model uhtj1276 i need part that i do not know what its called- metal ring with plastic piece that moves bobbin, this part is located under the bobbin on the shaft, plastic part cracked.
  • Jimmie Sill Nov 17, 2014
    this is a difficult carrier to find. the following web site probably will be a real help. you may also keep an eye on ebay for old sewing machine parts. this web will probably do it.
    http://www.statewidesewing.co/catalog/in... a Comment
  • Montgomery Ward Master
  • 627 Answers
I'm not sure about what your explaining, If the bobbin drops into this part (plastic) it is called the bobbin carrier. If you take the carrier out and you see a metal hook going around and circles or bobbing back and forth this is called the hook. The bobbin carrier is most likely what you need. Try this web, they usually have everything: http://www.sewingpartsonline.com/instruction-book-janome-and-newhome-8000.aspx
Posted on Nov 16, 2014
Testimonial: "it is a ring with grooved plastic on it that goes on shaft, that w hat i need."
  • george rudy
    george rudy Nov 16, 2014
    The part i need is on the shaft under the bobbin carrier that is greased.
  • george rudy
  • 84 Answers
SOURCE: Need to replace a bobbin cover plate
Here in Australia, the dealer would get it in for you. The 'manufacturer' / distributor usually don't get involved with customers! I'd find a dealer near you and ask!
Posted on Oct 23, 2007
RickE1
  • 202 Answers
SOURCE: bobbin compartment trouble
Put the needle in the up position. Tilt the machine back with one hand and lay the hook in its position on what is called the hookrace. The little ledge inside the the circle opposite the other part that moves. Then take the outer ring and lay that in over top of it. There is a small pin on the bottom that fits into a notch. The two small nubs should be on the outside, then click the two black knobs over those. Put the bobbin in the case and the thread through the notch up under the tension spring on the case. Looking at the back of the case, pull the thread and in most machines the bobbin should turn clock-wise. Now snap it onto the post.
Your good to go.
Good luck.
Posted on Jul 31, 2008
  • 3 Answers
SOURCE: I have a Husqvarna Emma sewing machine. The
I was able to gain entrance into the area by taking out 1 screw (star head), slightly pulling on the plastic compartment to cause a small opening. I then tilted the machine and the needle fell out. The screw is located on the rear of the sewing machine, right behind the bobbin compartment. A flat head screw is also needed to "Pry" open the plastic.
Posted on Apr 19, 2009
Zenqi
  • 208 Answers
SOURCE: Viking Husqvarna #1 + - A bobbin was stuck on the
The black plastic ring must be put back on with it oriented correctly. It can be a bit tricky, but experiment different ways.
Another small part may have come off too. If you can't get it, a Viking tech can do it for you without much trouble.
Posted on Jul 11, 2009
SOURCE: BOBBIN WINDER WON'T WIND
bobbin wont wind on sewing machine
Posted on Dec 08, 2010
Where i can buy this part?
Take a photo of the part along with the make and model of the unit to a local sewing machine place.
Or check online to see if the manufacturer has a parts diagram and listing.
Nov 16, 2014 | Montgomery Ward Sewing Machines
How do i adjust bobbin tension on singer 4210
Open bobbin area and look at your bobbin carrier for a tiny metal screw that holds down a metal piece to the plastic carrier. Tighten the screw. Be careful though...the plastic can strip.
Sep 16, 2012 | Singer Inspiration 4210 Mechanical Sewing...
My bobbin case came out of my sewing machine and I can't get it back in correctly. The bobbin case moves around. I have a singer cg-500/550
I just had this same problem and although i could not find the answer online, I managed to fix it.
If you look at the bobbin case there are 3 different tabs sticking out.
First you need to have tab #1 under the main part of the machine, and #3 over top of the small twisted metal piece below the bottom fabric gripper.
The hard part is to get the second tab into the proper spot. I circled the piece that you need to move in red. If you move the little piece by pushing it with a flat screw driver, you can line up the bobbin case so that tab #2 is under the metal piece and the bobbin case will be properly set.
Don't give up! It wasn't easy to get it back but I did it, I'm sure you can too!
Apr 27, 2011 | Singer CG754 Mechanical Sewing Machine
MY BOBBIN CASE FELL OUT TWO PIECES HOW DO I PUT IT BACK TOGETHER
I assume you actually mean the metal ring that holds the small round case that the bobbin itself sits in. There are usually two arms that swing in to hold that larger metal ring in place and then there is a plastic and metal piece that sit behind the large metal ring. fit the plastic piece that may look somewhat like a scoop next to the metal piece that usually has the post the the bobbin fits onto and has a quite sharp tooth on it. The metal ring then goes on to hold those two pieces in place and the two arms swing in to hold the metal ring into place. The bobbin or bobbin case now can be put back in. Hint on metal ring placement: they almost always have a notch that goes at the very top where the arm on the bobbin case sits in when it is in place. You may find it easiest to do this with the machine laying on its back so you don't have to have 4 hands to hold everything in place while putting everything back in.
Feb 22, 2011 | New Home HF-2022
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
Plastic casing around the bobbin
That piece is a sweep that helps keep the hook clean. It is not necessary for the machine to use, I have thrown away many of them. If you can get your hook put back in you should be ready to go.
good luck!
Jan 30, 2009 | Necchi 3101 Mechanical Sewing Machine
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Bobbin thread getting caught
Check your Instruction manual - if you have taken the bobbin case apart to clean it, the shuttle must be reinserted with the little tab pressing against the piece you mention. It is under page 45 - "Caring for your machine" in my book. I missed it the first time I cleaned and oild mine.
Mar 21, 2008 | Singer 3962 Mechanical Sewing Machine
Singer futura model 900 sewing machine
Recently had same problem. Underneath the bobbin area on the bottom of the machine is a small white plastic piece that resembles a fan. Singer calls this the bobbin cam actuator. It is usually cracked along the sleeve that fits over the metal pin, bar? This is the mechanism that lifts the bobbin when it is wound. When its broken it can't lift the bobbin to be wound properly.
Nov 04, 2007 | Sewing Machines
Sewing Machines Logo
57 people viewed this question
Top Montgomery Ward Sewing Machines Experts
D. E. Hev
NOEL
NOEL
Are you a Montgomery Ward Sewing Machine Expert? Answer questions, earn points and help others
