Question about Maytag Washing Machines
Clean lint from a set of square holes in near the front gasket of a 2002 Neptune washer?
This is an older model purchased in 2002. There are drain holes which can be seen just below the rubber gasket around the washing bin. How can I clean them, the lint stays wet and is hard to remove. I always leave the door open when the machine is off but it never dries enough to vacuum out the lint. Even if I'm out of town for a week, the lint doesn't dry. Thanks!
    Master:
  • 560 Answers
Wet vacuum.
Posted on Nov 16, 2014
aborcass
  • 2651 Answers
SOURCE: LG TROMM Model WM2077CW-mildew on rubber
First and foremost you MUST use an HE detergent, HE(high efficency) is design specifically for fontloading machines.. and use little amounts of it, 2-3 tablespoons is all that is required to clean a full tub of clothing.
Jusst using less of regular detergent is not the same as using correct soap. the moldy smell and black filth when the front bellow is pulled back is actually residual detegent not being disovled in normal operation , all front loading washers are experiencing this issue, there is a new product on the market to help combat this problem and for the 1-2 months ive been reccomending no one has told me that it hasnt helpd. heres the link www.affresh.com
Posted on Apr 09, 2008
docjohn174
  • 943 Answers
SOURCE: Clothes smell like mildew
HI thanks for your question. My solution is 1 cup of vinegar, per wash load. In time, will solve your problem.thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt series washing machine front gasket mold
Hi.
The quickest way to solve your problem is to fit a new door seal.
Then each time you finish a wash, clean and dry the door seal.
At least once a week, depending on how often you wash, do a hot wash with powder, but no clothes in.
This is called a maintenance wash.
This should solve your problem.
The door seal probably got into its present condition because of several different reasons, namely:washing at too low a temperature-not using sufficient powder- amongst other things.
the mould is actually living bacteria, not a pleasant thought
Please positive feed back if you find this helpful
Cheers and good luck
Posted on Nov 24, 2008
jan mczeal
  • 632 Answers
SOURCE: M9503 washer dryer not draining before dry cycle.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Aug 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have an Affinity Front loading washer model
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 28, 2010
What is the best way to clean the mold off the door gasket
I use to have the exact same washer. When Maytag was Maytag before the merger with Whirlpool they suggested using a mixture of bleach and Sunlight power dishwasher detergent. You can also usually find a washing maching cleaner like Tide washer cleaner or Washer Magic. Run it on the longest and hottest wash cycle. Stop the maching during the wash portion and wipe the door seal down well with a rag and ware gloves. Also make sure that the little drain hole in the center of the bottom of the door boot (gasket) is not not blocked up with lint or anything. If your mold problem is really bad you might have to call a repair man out to replace the gasket and clean inbetween your inner and outter tubs.
Feb 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have mold all around the rubber gasket on the fromt of my LG washer. How can I eliminate this?
Problem:
The seal design on the washer traps water causing mildew to grow.
Solution:
If the door gasket has a small hole at the six o'clock position--it is clogged with soap scum. Use compressed air to blow this hole clear.
This allows water to drain back into the tub
If there's no hole--this is an older model LG which did not have this upgrade
Wiping the door gasket with a rag after the LAST cycle of the day helps prevent debris from accumulating. Some consumers add (1) teaspoon of bleach to a spray bottle with water--and spray the older type gaskets after the final laundry load finished--to keep the gasket clean.
Service manual and more HERE
Feb 10, 2011 | LG WM-1832C Front Load Washer
Can you put a patch on the rubber gasket of a frontloader? the hole is just above the drain hole by the front door.
Try using bicycle inner tube repair patch, because it has the same flexibility as the rubber gasket on door, make sure rubber on door is clean and dry before applying rubber patch
Nov 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
How do I get rid of the black mold on the door gasket?
If you take a bit of tilex mold/mildew spray and a rag, you should be able to remove it all.
Also , look down at the bottom of the front "gutter" just in front of the tub. There is a series of drain holes and clothes lint can build up a bit in here. take a towel and wipe the holes really clean . This will help keep the water draining out of the front and keep the moldy smell to a minimum.
One last thing, I've found with my front loader, that if I keep my wash loads to a medium full size instead of completely jammed full load size, the drain/mold issue is almost non-existent.
Hope this clean it all up for you!
Feb 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Our Maytag Neptune Front load Model MAH6700AW seems to alway have a wet or damp spot underneath or in front of the door. Where should I start looking for the leak?
the door has a series of small holes in the front bottom lip of the door gasket these are for drainage if they get clogged the door will drip water clean them and, remember to use HE soap
May 11, 2009 | Maytag Neptune MAH6700A Front Load Washer
Clothes come out soaking wet seams like it doesn't spin out the w
There are 3 possible places to look for filters as each machine is made differently –
1 If machine has a square flap fitted on the front filter maybe located behind this.
2 It could be located behind the front lower kick panel (remove panel to see).
3 Located inside the sump hose, this is the hose that is attached to the bottom of the
main tub.
Try this:
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Apr 10, 2009 | Maytag Neptune MAH6500A Front Load Washer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Maytag frontload washer i think it's a neptune
did you clear the code (press pause /cancel twice) or unplug the unit for 2 min ?
May 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Model and serial ##
I did finally get a working phone # for support from Maytag and thanks to her and my clever husband- did locate the HIDDEN #'s. She also recommended using the Affresh tablets to see if that helps, but could not confirm that there were any brushes catching lint or that it needed to be cleaned.  MODEL #  MAH3000DAWW front loader
Apr 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
