The button to lower the temp on my simple comfort thermostat doesn't always work. I either have to hold it down or press it several times. The other buttons work just fine. How do I fix this?
    Master:
  • 560 Answers
Replace the thermostat. Unlikely this is a serviceable part.
Posted on Nov 16, 2014
  • 3 Answers
SOURCE: Temp control moves on it's own
Mine was doing the same thing and it was really frustrating! I would come home and it would be 88* inside. I found out that this model air conditoner has had problems with moisture getting in the control panel and shorting it out when it's humid outside. I have the part number if anyone wants it. It cost me about $45 from Sears Parts.
Posted on Jul 08, 2008
SOURCE: Can not figure out how to control thermostat
If you take off the front control panel cover (simply prying off on the edge with finger) you will find 2 small buttons under the display panel, one being mode and the other being prog.
Press both simultaneously and hold down for 5 secs and the display will blink, press prog to advance to what you want to program, kinda like setting a timex watch. As I recall you can set degrees celcius or farenhight/ cycle/Hi/Lo etc.
Just keep in mind when you set using the up and down arrows:
flashing H means: at what temp do you want HEAT to kick in?
flashing C means: at what temp do you want AC (if you have it) to kick in....if no A/C fan simply blows air.
Hope that helps.
Posted on May 30, 2009
  • 22 Answers
SOURCE: Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Posted on May 06, 2010
SOURCE: Hi i have a simple
We're having exactly the same problem. I called ICM at 1-800-382-3113 and asked for tech support and they emailed the 2-page manual right away. I talked to Eric Wood, an Electrical Engineer there, and he sent it immediately. I hope this helps!
Posted on Apr 07, 2011
  • 3 Answers
SOURCE: Display is blank. Just moved in to
YES IT CAN BE THAT SIMPLE / CHANGE THE BATTS FIRST AND USE NEW ONES
NOT FROM AN OLD TOY!!
Posted on Oct 29, 2011
Simple comfort thermostat AT78100
I can't find that model, but when you set it where you want it, does it have a hold button? If so, press hold after setting temp.
Dec 07, 2013 | Heating & Cooling
My Honeywell thermostat won't set the heat above 75 degrees
ok fist thing is to press and hold the middle lower button and the arrow up at the same time and hold until the screen changes to a number. keep hitting next until you see 75 appear then arrow up to the temp you want and press done. That easy!
Oct 24, 2013 | Honeywell Programmable Thermostat Heater
Simple comfort 2200 thermostat not working properly
We have a Simple Comfort 2200 Electronic Thermostat and last night it quit blowing cool air and the # sign beside the air temp (the set to temp) starting blinking
Aug 11, 2012 | Heating & Cooling
I have a Friedrich thru the wall air conditioner with a wall mounted thermostat but I cannot seem to regulate the temp. with the thermostat. What happens when I press the up and down arrows.....does the...
It is not uncommon for the room temperature and the set temp. on the thermostat to be several degrees apart. The room temperature should go down when you set the temperature on the thermostat down to a lower number.Hope this helps you and thanks.
Aug 17, 2011 | Friedrich Heating & Cooling
I have never used central ac before - how do I set it? If it is on 75 will that cool the house? If I want it cooler, do I put it lower? like 65?
As to your question 'will 75 cool the house?' The answer is 'yes' - if the outside temperature is low enough. Typically speaking you can expect your central AC to cool a properly insulated house to a down to a temperature of about 20-25 degrees lower than the outside temperature. For example - if the outside temp is 95 degrees. You could expect to get your house down to 70-75 degrees. If the outside temp is 110 degrees then you could only expect to get the house to 85 or 90 degrees.
So .. as you can see - your 'inside' temp will be directly affected by the 'outside' temperature.
As to the operation of central air; it is very simple.
I would suggest that you not pay 'too much attention' to what you have the thermostat set on. A comfortable temperature - is a personal thing - so - I would set it somewhere - say 72 and see how I (and others in the house) was handling that setting.
If you want it 'cooler' just 'notch' it down a degree or two - if you need it a little warmer - turn it up a degree or two. Do this "fine adjusting" till you have the temperature setting you are comfortable with.
Usually the more you can leave your thermostat alone the better off you will be from a comfort position and an electrical useage standpoint. Obviously, the higher you have your thermostat set the 'less' it will cost you on your electric bill.
How high you set the temperature is a balance you have to come to based on how comfortable you want to be - matched with how much you want to hold down the electric bill.
hope this helps
Aug 14, 2010 | Honeywell Heating & Cooling
Thermostat resets itself to 85 degrees a couple hours after I set it to 74 degrees
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Jul 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
There appears to be a problem with the thermostat/control panel. It won't turn on/off with out removing power. Once turned on, cannot adjust temp or mode or anything.
What type of Thermostat is this? If it is a Comfort Control Center, four or five button, then turn off the thermostat, hold down the mode and zone buttons at the same time and turn the tstat back on. When EE appears on the screen, then release the button and see if it begins to work. If not, then we need to check the control unit in the AC. Hopefully it is just a simple reset.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Hope that helps.
May 03, 2009 | Heating & Cooling
Contour comfort control
normally, if you have a hold option, there should be a hold button which when you press again should un hold the setting. have you tried pressing the run button. this would eliminate all hold function and just run the programmed temperatures.
Feb 16, 2008 | Heating & Cooling
Honeywell thermostat RTH230B
Sound like you need new one... take a look on amazon ecobee3 Smarter Wi Fi Thermostat Remote Sensor. It's not worth repairing it..
Jan 06, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
240 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
