Where I the reset button on a 1988 mpls mn 55422 Honeywell boiler?
2 Suggested Answers
  • 659 Answers
SOURCE: hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
Posted on Apr 07, 2009
Where can I find Miele disahwasher parts Minneapolis, MN
Call Miele technical service at (800) 999-1360. You can order parts there. I think they are open M-F 8 am to 8 pm eastern time.
Oct 20, 2014 | Miele Dishwashers
Boiler ignition failer
Try adjusting the gas to air mixture and flow rate. I don't work well in very cold weather, either. I think that's fairly typical. Even a diesel engine is difficult to start in cold cold weather. Perhaps heating the room where the boiler is would help or at lest insulate the room well. Including stopping any drafts that may be causing a windy condition in or around the combustion chamber.
Feb 06, 2014 | Honeywell Triangle Tube Prestige Solo 110...
Recently i have serviced my boiler . After the service I am not able to control the heating system using thermosta /danfuss tp25 .I mean the boiler is not responding when the temprature button is...
it must be a honeywell look ware the reset button is on the right side that's ware the thermostat
wire is it will say thermostat
look to make sure the wires are not touching that will make it just run for no reason
i don't no if you have a (boiler) (forst hot air) i may need a little more info if that doesn't work
hope this helps
good luck
bob
May 10, 2011 | Heating & Cooling
Can't get the thermostat to turn on. The batteries are good, but the thermostat won't turn on when I slide the thing from off to the heat. I have a Honeywell MPLS, MN. thermostat (this code was found at...
Try with following link:
Honeywell thermostat website: http://yourhome.honeywell.com/home/Applications/SmartSearchResults.aspx?searchkey=thermostatfor heating b>
Dec 09, 2010 | Heating & Cooling
Hot water boiler will not ignite
Apr 07, 2009 | Water Heaters
Honeywell T403A1174 suddenly doesn't appear to call for heat
some times inside the boiler on the internal pipework you will see little sensors, on the central heating piping there sometimes is a thermastic sensor on side of flow pipe with a little reset button on ? i guess with the problem you said the poiler locked out and the pipe work overheated ? this is a safety feature on some boilers not, all and easerly reset via this button ?
Jan 31, 2009 | Honeywell Water Heaters
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
My boiler most of the time don't star until I push the switch in the pressuretrol (honeywell) PA404A1033. After I activate the turn on and off regular for some hours but later again don't star until I...
Looks as if your boiler is over firing (extended run) you probably have a faulty sensing thermostatic probe causing this the switch you are resetting is a safty pressure switch it is designed to keep the pressure from building which could cause the boiler to explode.
Nov 12, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
